What have you done to increase MPG? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2011, 01:09 AM   #1
SimonSellsAustin
SimonSellsAustin's Avatar
Fan#: 90594
What I Drive: 2012 Sonic Blue SE hatch.
FF Reputation: 2 SimonSellsAustin Good Standing Member
Arrow What have you done to increase MPG?
I'm considering doing a few mods like Ram air, remove the second muffler and possibly and underbelly pan. Comments, suggestions=?
"May the wind always be at your back and the sun always upon your face and may the wings of destiny carry you aloft to dance with the stars."
~ Boston George
SimonSellsAustin is offline
Old 10-09-2011, 01:19 AM   #2
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
underbelly pan would be negligible I think... the whole front end of the car is pretty much covered, and the rest is pretty well designed.
might as well go with a short-ram or cold air intake if youre gonna plan on modifying the setup at all, will probably net you better increase anyway, just my .02.
Sonic Crew #28
feta_mgp is offline
Old 10-09-2011, 01:33 AM   #3
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,318, Level 46
Points: 5,318, Level: 46 Points: 5,318, Level: 46 Points: 5,318, Level: 46
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Premium gasoline has netted me around 3mpgs more a gallon.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 10-09-2011, 01:42 AM   #4
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Contrary to that, premium gasoline net me about 3mpg less a gallon when I ran it. I've switched back to 87 and now see better fuel economy.
Sonic Crew #28
feta_mgp is offline
Old 10-09-2011, 01:59 AM   #5
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,172, Level 61
Points: 8,172, Level: 61 Points: 8,172, Level: 61 Points: 8,172, Level: 61
Level Up 8% Completed
Forum Activity 10%
FF Reputation: 11 Joeywhat Great Standing Member
The BEST way to increase fuel economy is to learn your car, find where it likes to be for the best mileage, and keep it there. How you drive will impact fuel economy so much more then any add on...especially one that you pay $100+ for...it's going to take a LONG time to recoup those costs with the rather small gains you may or may not see.
Hatch Nation #29
Joeywhat is online now
Old 10-09-2011, 02:17 AM   #6
SimonSellsAustin
Fan#: 90594
I've switched back and forth... I've gotten mixed results.. I need to do more testing before I can verify the increase.
~ Boston George
Old 10-09-2011, 02:50 AM   #7
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,802, Level 78
Points: 14,802, Level: 78 Points: 14,802, Level: 78 Points: 14,802, Level: 78
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 19%
FF Reputation: 16 Elizabeth Great Standing Member
Mobil One Advanced Fuel Economy Oil 0W20. (available in some places for a five quart bottle for $23. instead of the $8 a quart..)
(Standard Motorcraft filter is fine)
Keep all window and roof closed on highway
Increase FRONT tires to 44psi (you will NOT even notice it over bumps.. but the car will corner better) the rear leave stock, or only one or two at most psi higher. If more you WILL be really feeling the wacks from the overly stiff tires.
This is assuming you have 17" or 16" wheels. I do NOT know what increasing the 18" tires would do...
Avoid streets with stop lights or stop signs. Every one you stop at cuts mpg drastically. Even if a longer route, if it has no stops, will be worth it.
If you are planning on buying wheels, the smoother the surface, the better the mpg. So five spoke are like the worst for churning the air. A nice smooth moon cover would be the best.
Covering the rear wheel openings is a big mileage gainer..
Lowering the car should also give some gain.
reset your stock mpg meter often. The meter will give tremendous insight into what adds to the mileage, and what kills it.
By resetting it, you let it change way more for small changes in the actual mpg being used.
With a manual tranny you absolutely want to be in the highest gear the car car be driven in at any time. For me fifth is good at 32mph.
If you have to go up a hill though, downshift!
(I think this is why the auto is said to get better mileage.. because most stick drivers cannot keep it in the lowest gear like an auto can.
And it has it's own rules to upshift. A person has to guess if it is best to downshift.
Slower is better. The best i can drive seems to be below 47mph. Which is just 2mph over the freeway legal lower limit of 45mph...
I like 35mph streets
I drive 55mph in the 65 freeways. have for a few years..
Really sllooooow starts from stoplights and signs.
(folks LOVE to jump off the line.. too bad.. The worst are idiots who are tailgating so close they panic when i shift, and the car slows down for a split second..)
Interesting how some folks will also slow down when i am on the freeway. like they do not have the guts to do it, but would if another is doing it..
Then tailgaters, i used to despise them, but now i find them to be helping me get better gas mileage, i do not hate them as much.
Elizabeth is online now
Old 10-09-2011, 07:19 AM   #8
Red 2012
Red 2012's Avatar
Fan#: 85244
What I Drive: 2012 candy red SEL; 2005 Freestyle
FF Reputation: 1 Red 2012 Good Standing Member
really simple... bought a touted high milage car ... drive like normal...
= better milage ... actually we seem to drive a bit more aggressively in the 2012.
currently am running test of 2000 mustang 6 vs 2012 hatch ... after a few more tanks of gas and rotating driving/cars between wifie/me will report results.
Already wifie has preference for 2012 ... as more fun to drive and more lively. but mustang sounds better even though it's a six.
Red 2012 is offline
Old 10-09-2011, 11:12 AM   #9
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Agreed with Red here, I drive it like normal without worrying heavily about how I drive and I'm getting the EPA estimated mileage. That said, I have a long stretch of 55mph road to work and back and never seem to jump over 30 for very long... hoping when I finally take the car in for "The Works" having everything checked/replaced/topped off will help me out a bit, fresh oil should help, once all the crud from break in is drained out.
Sonic Crew #28
feta_mgp is offline
Old 10-09-2011, 11:21 AM   #10
Bill3rAIL
Bill3rAIL's Avatar
Fan#: 89058
What I Drive: 2012 SE 5Dr Hatch Silver/2002 Dodge
Points 434, Level 8
Points: 434, Level: 8 Points: 434, Level: 8 Points: 434, Level: 8
Level Up 68% Completed
FF Reputation: 2 Bill3rAIL Good Standing Member
I have been driving extremely conservative to increase mileage.
Like JoeyWhat stated, a $100.00 add on will take a Looooooong time to recoup your cost and even longer to see the benefit.
Read Elizabeth's post about driving habits.
I was driving a 2002 Dodge B1500 at 12MPG...No matter how I drove, the best was about 14MPG. My gas cost is about 1/3 of the Dodge with the Focus.
Bill
2012 5 Door Hatch SE
203A & Sport package with 16" wheels
Bill3rAIL is offline
