Idling like crap and oil soaked spark plugs! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-06-2011, 08:37 PM   #1
snipes040
Fan#: 90614
What I Drive: 2000 silver
FF Reputation: 1 snipes040 Good Standing Member
Question Idling like crap and oil soaked spark plugs!
ok I have a 2000 with a zetec engine and I just changed the spark plugs because the car is shaking and vibrating at idle. I found that two of the spark plugs were pretty wet with oil and the other two looked fine. When looking at the engine from the front the two spark plugs that had oil on them where the first two from the right side of the engine. Any ideas on how to fix the idling and oil issue?
thanks
snipes040 is offline
Old 10-06-2011, 08:45 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
First off, the most likely cause of the uneven idle is occasional misfires due to the oil and crud mixing up your spark. You need a new valve cover first. That will repair the oil problem. You'll also need an oil change after the job if you DIY, and new spark plug wires.
Then if you still have a problem, we'll go from there. You can inspect the PCV vacuum hose while you're in there because that's a common culprit of low/rough idle.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 10-06-2011, 08:51 PM   #3
snipes040
Fan#: 90614
ok so I would need to replace the valve cover and the valve cover gasket and that would fix the oil problem? Just making sure I am understanding this, I'm assuming the valve cover is pretty easy to replace.. just 10 bolts that are holding it on..?
Old 10-06-2011, 09:20 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,790, Level 73
Points: 12,790, Level: 73 Points: 12,790, Level: 73 Points: 12,790, Level: 73
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 99%
Valve cover gasket is leaking, and it'll abuse the thermostat housing as well if not replaced....
Fix that, clean things up, & you should be fine....
sailor is offline
Old 10-06-2011, 09:43 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 10-06-2011, 09:56 PM   #6
snipes040
Fan#: 90614
oh ok thanks guys I will replace the gasket this weekend. hopefully that will fix the problem. Thanks !!!
Old 10-06-2011, 10:06 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Ooops, I wrote that wrong guy, I meant valve cover gasket, not the valve cover itself. It should still be good unless it's cracked somewhere. There are little rings around the spark plug tubes, and it seems that's the first place that starts leaking.
Don't forget spark plug wires too. I recommend that you get the lifetime warranty plug wires from whatever parts store you prefer. That's really handy for people who use their cars regularly- not race cars- because you can change the wires any time you have an engine running problem and cross that off the list.
Be eclectic.
