Deleting the tumble flaps - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2011, 01:26 PM   #11
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
Originally Posted by felixthecat View Post
Say, Ronnie your car will run & sound great w/ your new exhaust installed! What are you trying to do by deleting the tumble flap's? You will probitley gain some top end, but at the exspense of lower end torque, specialley w/ your header & exhaust system. You have a 20 motor, so it's going to be more noticeably than a 23 motor.
Just open up the intake a little more. Have it tuned like the add on intakes. Get rid of a few of the extra gadgets that control and monitor the flaps.
Just tear it up i guess
It's not important to win, it's important to make the other guy lose.
BowerR64 is online now
Old 10-09-2011, 07:42 AM   #12
BowerR64
BowerR64's Avatar
Fan#: 78699
ok i found the plugs, i need to pickup a few more and that part is out of the way.
Now im stuck on the 2 items mounted to the intake.
One is the actuator, should i just leave it connected and functioning? I mean how will it know if its working or not?
I also have this thing below the IAC which looks alot like the MAF its bolted to the main intake runner and has a little tip that fits down into the air stream. Is it another air sensing module of some kind? I dont think anyone has ever talked about it or what it does.
Says: 4S4G-9F479-AB on it and a google search says is a "MAP" sensor. I guess ill need to leave that?
There is a vac line in the center front of the intake that goes down under and around into this other unit and that goes into the actuator.
I would think since im not using the actuator thing that controls the flaps (if thats even what is called?) i could bypass it unless it throws a code the cossie doesnt use any of this stuff so i would think i wouldnt have to for this mod either?
Old 10-09-2011, 08:37 AM   #13
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
The sensor is the MAP. The other thing you have circled is the solenoid that works the tumble flaps. You can see the vacuum line that goes from the solenoid to the diaphragm. Since your deleting the tumble flaps you don't need any of this stuff. Yo do need the MAP sensor though. However, you definitely going to need a tune and you're definitely going to a CEL until you have a new tune file loaded.
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 10-09-2011, 03:09 PM   #14
BowerR64
BowerR64's Avatar
Fan#: 78699
Yeah i already talked to Tom about it, so i dont need them hooked up?
What if i just hook them up normaly but i remove the arm that connects to the tumble flaps? The solenoid with the 2 vacuum lines on it one comes out of the intake goes into the solenoid then out to the diaphram and that has the arm that rotates the flaps. I could just remove the arm and then everything would still function or think its functioning but not actually move anything.
I would rather remove everything for less clutter
Old 10-10-2011, 03:25 PM   #15
Bwinkelsas
Bwinkelsas's Avatar
Fan#: 50224
What I Drive: 2007, Screaming Yellow, ZX3 SES
Points 915, Level 16
Points: 915, Level: 16 Points: 915, Level: 16 Points: 915, Level: 16
Level Up 15% Completed
FF Reputation: 2 Bwinkelsas Good Standing Member
Since you took out the tumble flaps, finish it off and take the rest of it out. Dtecs have way too much junk/clutter on the motor. Removing them should deffinitly help air flow in the higher rpm.
1.706 / 7.720@91.13 / 12.381@96.84 letting off.
Stock Motor, why hate on the 2.0?
More power and new numbers to come soon...
Bwinkelsas is online now
Old 10-10-2011, 03:37 PM   #16
BowerR64
BowerR64's Avatar
Fan#: 78699
Yes they do, and while i was at it i cut off all the crap on the intake as well.
There is vacuum inlet lines in 2 different places im not going to use, im going to fill those. It also had tabs and push in connector things scattered all over the thing ive cut all those off. Also the intake runners have these little fins on the top front i cut those off and sanded them all down.
I have a few more things to do then im going to paint it and throw it on. Im thinking Wednesday. My brother got an exhaust in today so we will do that first then finish mine up. Hope i can get a fune tunes in it before the weekend.
Old 10-10-2011, 05:03 PM   #17
PSUrivie
PSUrivie's Avatar
Fan#: 67329
yeah you don't need any of it. It's all gets taken out when you install a Cossie also.
PSUrivie is offline
Old 10-10-2011, 06:19 PM   #18
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
this is a cool thread. the 2.3 intake mani has two of those vacuum things, one for tumble flaps and one for runner length control. its an even more cluttered and tight fit. i just pulled mine over the weekend for the pcv delete. pulling PSUrivie's '09 2.0L mani was a lot easier i thought.
Posted via FF Mobile
Jgrove998 is offline
Old 10-10-2011, 07:26 PM   #19
BowerR64
BowerR64's Avatar
Fan#: 78699
Well after buying my exhaust and a new cluster with a tach im tapped on my budget or ide go and get a dyno run before i put this one on.
Ill have it all painted up and finished tomorrow. Maybe i can put it on later if my brothers exhaust on his car goes ok.
maybe next month i can do that.
Old 10-12-2011, 04:11 PM   #20
Outlaw5.0
Fan#: 84300
What I Drive: 2011 Ford Focus SES
Points 445, Level 8
Points: 445, Level: 8 Points: 445, Level: 8 Points: 445, Level: 8
Level Up 90% Completed
FF Reputation: 1 Outlaw5.0 Good Standing Member
Don't match the head to the intake, you may cause more problems by doing that.
By all means let us know what kind of power you gain, and if you lose any fuel economy.
Outlaw5.0 is offline
