Power Steering Failure on brand new 2012 Focus - Page 4 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 12-05-2011, 09:40 AM   #31
smizak
Fan#: 92058
What I Drive: 2012 Black SEL
FF Reputation: 2 smizak Good Standing Member
Doesn't the computer log error codes? I can't believe that in a car with so much sophisticated electronics that it doesn't store those codes in a log somewhere. Even my '04 Jetta did that.
smizak is offline
Old 12-05-2011, 09:47 AM   #32
NYCZPlan
Fan#: 90535
What I Drive: 2012 Grey Focus
FF Reputation: 1 NYCZPlan Good Standing Member
Yes, the logs show failures in the power steering control module, with "code U3000" for "internal failure" recorded.
NYCZPlan is offline
Old 12-05-2011, 09:52 AM   #33
smizak
Fan#: 92058
Then there is no excuse for them not to replace it. That's insane.
I just bought one two weeks ago, no problems except for the glitchy MFT, but these threads are making me nervous. That is a bad failure.
smizak is offline
Old 12-05-2011, 10:08 AM   #34
NYCZPlan
Fan#: 90535
They refuse to replace it, in fact state that they won't attempt any repair until they can reproduce the error. Since the error has occurred randomly(3 days after I purchased the vehicle, then 33 and 28 days later, respectively) this means that unless they keep the car for a month and drive it once a day, odds are the power steering won't fail for them when they test the car.
NYCZPlan is offline
Old 12-05-2011, 10:21 AM   #35
smizak
Fan#: 92058
How the hell do they explain away the error codes?! It failed, there is computerized proof that corroborates your claims. Did you tell Ford that?
smizak is offline
Old 12-05-2011, 10:25 AM   #36
NYCZPlan
Fan#: 90535
The error codes were noted by their technician when I brought the car to be serviced(all of this is in the paperwork). Ford's position, as stated to me, is that no action will be taken unless they can reproduce the issue.
NYCZPlan is offline
Old 12-05-2011, 10:27 AM   #37
KimberChick
Fan#: 91809
What I Drive: 2010 Toyota Tacoma DoubleCab
FF Reputation: 1 KimberChick Good Standing Member
file an NHTSA complaint. You can do that online. I could understand them saying that they have to reproduce it if there was no code stored serving as proof of an error, but there is. This sounds like a dealer that doesn't want to do the work.
Have you tried another dealership?
KimberChick is offline
Old 12-05-2011, 10:38 AM   #38
NYCZPlan
Fan#: 90535
When I wrote "Ford's position" I should've mentioned that this meant both Ford the manufacturer and the dealership where I took the vehicle for service. Both took the same position.
The NHTSA is a good idea but I'm guessing that it will take a long time and many complaints from different people before there's any action from them.
NYCZPlan is offline
Old 12-05-2011, 10:46 AM   #39
smizak
Fan#: 92058
On my Volkswagen, there was a CEL and the engine felt a little funny. The light turned off before I could get it to the shop, but I took it anyway. Sure enough, there was a stored coded for the rear oxygen sensor failing, they replaced it without question and free of charge. That is precisely why codes are stored, most problems are intermittent.
I'm having a hard time believing that Ford would refuse to help when the computer is telling them that the module is failing. All they would do if it did fail for them is read the code anyway, it seems redundant.
Natasha, if you're here, is that really Ford's stance? The problem has to happen in front of them, even when there is electronic confirmation of the customers claims? I could understand a smaller electrical issue, but steering failure? That just seems grossly negligent of your customers safety.
smizak is offline
Old 12-05-2011, 12:29 PM   #40
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
FF Reputation: 15 a_2000_se Great Standing Member
.........they replaced it without question and free of charge. That is precisely why codes are stored, most problems are intermittent.
If the problem was in the harness instead of the module, replacing the module would do no good. Or if the problem wasn't really a problem but rather a failure in fault monitoring circuitry then....... you just have a problem in customer confidence.
"Natasha" works for Ford and is Ford........ $$$$
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
