Disable PATS and replace ECU without reprogramming? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-03-2011, 05:14 PM   #1
JD_Hupp
Fan#: 83431
What I Drive: 2002 White LX
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 1 JD_Hupp Good Standing Member
For my 2002 Focus LX automatic with 80,000 miles, I replaced my ECU with a used one ($50 at eBay) to troubleshoot a tranny problem, but then I had to pay the dealer almost $300 to copy information out of my old ECU and write it into the replacement. (Though that also included $30 to program a second key.) Then the replacement ECU developed the same problem indication as the old one (a short).
So after I figure out what's causing the short, I'm staring at the prospect of replacing and reprogramming the ECU again.
Once the replacement ECU was installed, the car wouldn't even start until it had been reprogrammed, and I understand that this was due to the PATS.
Can I disable the PATS and use a replacement ECU without reprogramming it? In other words, is the programming only needed to set up the key/PATS info?
JD_Hupp is offline
Old 10-03-2011, 08:19 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
I have a way to bench flash but depending on your ECU code most PATS switches dont work in the SCT tuning sofftware and by the time you bought a flasher and shipping (399.00 and 20.00 shipping) it would be cheaper to have Ford do it
If you get the correct ECU they wouldnt charge you anything but the key/pats , There is a code on the ECU that tells what ECU it is and what ECU you have to use it cant just be for a 2002 Focus ECU
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 10-19-2011, 02:53 PM   #3
PStroked444
PStroked444's Avatar
Fan#: 83309
What I Drive: 03, Silver, 2.3L, ATX, 4dr,
FF Reputation: 1 PStroked444 Good Standing Member
I dig this post up cause I am curiouse. (sp) So, if I get a ECU same code and same "bin" example (3s4A-12A650-AAC) I wont have to get the keys flashed. Or whatever the process is for changing an ECU out? Or can you explain how the process works in simple terms for me. Thanks!!
CJ
Take time to think it through... Because your next thought might be put to action.
PStroked444 is offline
