ZX5 engine stumble when stopped, help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-27-2011, 06:30 PM   #1
pumafeet10
Fan#: 37417
What I Drive: 2003 Yellow ZX5
Points 611, Level 12
Points: 611, Level: 12 Points: 611, Level: 12 Points: 611, Level: 12
Level Up 22% Completed
FF Reputation: 1 pumafeet10 Good Standing Member
Recently installed an AEM SRI on our 03 ZX5 zetec auto, shortly thereafter i noticed the car would idle rough and somewhat stumble when I was stopped at a light.
Not sure what it might be, but plugs and coil look fine and there are no problems other wise
Also other then the intake the car is stock
I had also be recommended to replace the DPFE sensor, as i might have hit it and damaged it while installing the intake? not sure but it is in the general area
Not sure if there might be a problem with the EGR, do they seem to have problems getting clogged and not flowing enough?
Thanks for the help
pumafeet10 is offline
Old 09-27-2011, 06:59 PM   #2
three_X_Z
Fan#: 883
What I Drive: 2000 ZX3
Points 819, Level 15
Points: 819, Level: 15 Points: 819, Level: 15 Points: 819, Level: 15
Level Up 19% Completed
FF Reputation: 1 three_X_Z Good Standing Member
There are two places that have caused this on my car. One is the classic PCV tube that comes out of the back of the intake manifold. Its the biggest of all the vacuum lines coming out of the manifold. It often fails right at the spot where it connects. Kinda collapses on itself and causes a vacuum leak. The other one that I've had is a small leak in one of the plugs on the back of the intake manifold. Basically feel around down there with the engine running and see if your finger gets sucked into something.
three_X_Z is offline
Old 09-27-2011, 07:05 PM   #3
pumafeet10
Fan#: 37417
thanks for the idea, anything i can check is a good lead, but wasn't thinking that would be it
thanks
Old 09-27-2011, 07:59 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
When you fit any type of SRI you must clear the previous "learned" adaptive fuel strategy settings from the ECU. Did you disconnect the battery after installing the intake for 5 minutes or more? Most SRI instructions tell you to do this.
Once the new intake is fitted, let the car simply idle for a few minutes. If you are still having idling problems after a reasonable amount of driving time has elapsed, you have likely unintentionally introduced a vacuum leak into your intake system. Check the intake tube to throttle body connection clamp in particular and also where the MAF screws into the intake tube. Both areas must be air tight as they are behind/near the MAF sensor. Airflow after the MAF isn't compensated for by the ECU.
If the car ran fine before your modifications, don't go chasing other possible causes until you've rechecked your work.
BC_ZX3 is offline
Old 09-27-2011, 10:26 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,752, Level 73
Points: 12,752, Level: 73 Points: 12,752, Level: 73 Points: 12,752, Level: 73
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 99%
X2 - Couldn't have said it better!
sailor is online now
Old 09-30-2011, 12:47 PM   #6
pumafeet10
Fan#: 37417
Everything has been checked over, and the battery was disconnected form the entire install time, so plenty of time to reset the ecu.
I checked for leaks using some soapy water to watch for air bubbles but nothing,
I'm not just randomly searching, as there is an abundance of sensors that are in the area and could have been disrupted during install, that were fine before, like the dpfe sensor.
If it was the Maf it would be causing a problem all the time, no?
It only happens when we are stopped, which is why I was leading to the dpfe as it is vacuum operated with the erg, possibly not getting enough flow at idle
Old 10-19-2011, 12:04 PM   #7
pumafeet10
Fan#: 37417
replaced and rechecked clamps, checked maf and all is good.
still cant figure it out
Old 10-19-2011, 12:44 PM   #8
alz focus
Fan#: 67546
What I Drive: 2002 Blue SE
Points 975, Level 16
Points: 975, Level: 16 Points: 975, Level: 16 Points: 975, Level: 16
Level Up 75% Completed
FF Reputation: 5 alz focus Good Standing Member
Use brake or parts cleaner to check for vacuum leaks. Soapy water is not going to do anything but get sucked in in there is a leak.
Spray while car is idling, if revs jump, focus on that area for the vac leak.
Al
2002 Focus SE Zetec ATX
2000 Focus SE SPI ATX
2006 Freestyle SEL AWD
alz focus is offline
Old 11-15-2011, 07:38 PM   #9
pumafeet10
Fan#: 37417
So the problem persists...
My wife was driving to work this morning and in stop and go traffic, the car stalled. The cel and brake light came on..
No code was there to be read, so still unclear as to what is wrong, really need to get this figured out
Old 11-15-2011, 09:56 PM   #10
pumafeet10
Fan#: 37417
Checked for leaks with brake clean and soapy water to see if there are any air bubbles, and nothing.
Sprayed a bunch of Maf cleaner into the intake, enough that the car stalled but ran fine after I started it again.
Plugs, wires and coil are fine and uncorroded so not sure what it could be.
There does seem to be a very tiny stumble at idle, but am really unsure
Took the car for a drive and could not get it to stumble when the brake was applied
