Cracked thermostat housing?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-06-2004, 08:09 PM   #1
biederboat
Fan#: 9840
What I Drive: 2000 ZTS
Points 878, Level 15
Points: 878, Level: 15 Points: 878, Level: 15 Points: 878, Level: 15
Level Up 78% Completed
FF Reputation: 1 biederboat Good Standing Member
I have searched some earlier posts and believe I may have a cracked thermostat housing but wanted to make sure before I tear into it. The car is a 2000 ZTS w/ 68K. No noticable leakage when warm or cold but have seen a puddle under the car on two occiasions. One time, I had coolant dripping from the bottom of the tranny bell housing that looked like it was traveling down from the thermostat housing. Is this a common repair item? I can't see anywhere else that it might be leaking from.
It also seems to be sporadic as to how much coolant it leaks and when it happens.
Thanks,
Biederboat
biederboat is offline
Old 10-06-2004, 08:16 PM   #2
d3bilhan
Fan#: 12408
What I Drive: 2002 Silver ZX5
FF Reputation: 1 d3bilhan Good Standing Member
It isn't that hard to pull the thermostat off and inspect. Most likely you have a bad gasket that you would be replacing since you pulled it apart.
Support Our Troops!
Drive like you mean it!
[img]
d3bilhan is offline
Old 10-06-2004, 09:55 PM   #3
slammedfoci
slammedfoci's Avatar
Fan#: 2137
What I Drive: 2000 Bright Amber Metallic ZX3
FF Reputation: 1 slammedfoci Good Standing Member
I bought a brand new housing from ford and i leakes right were the top and bottom halfs are molded to gather. Took it back and he gave me anothe one for free. The second one worked. Can you do a pressure test. I did a pressure test and you could see the coolant seping out of the seam. I think it was about 50.00 to 60.00.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover
EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights
INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed
slammedfoci is offline
Old 10-07-2004, 01:37 PM   #4
steedazts
steedazts's Avatar
Fan#: 5244
What I Drive: 2001 Black ZTS
FF Reputation: 1 steedazts Good Standing Member
yea dude its the housing! mine did the very same thing that POS is plastic, it wil be around $40 to $50 not big deal!
steedazts is offline
Similar Threads
Thermostat housing leak 02_zxFIVE General Technical Chat 53 01-21-2013 09:02 PM
HTPerformance Zetec / SVT / ST170 / RS Thermostat Housing HTPerformance Ford Focus & General Car Chat 105 04-12-2011 06:27 PM
Plastic thermostat housing woes & fix Olympiadis General Technical Chat 2 05-05-2010 05:08 PM
HTPerformace Billet Thermostat Housing rnap_83 ZETEC Performance (2000-2004) 25 10-28-2009 11:47 AM
:: Cracked Thermostat Housing Assembly :: ..:: sleestak ::.. General Technical Chat 8 08-11-2006 09:35 AM
