2003 focus svt won't start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-22-2011, 07:54 PM   #1
Mitchg1983
Fan#: 90154
What I Drive: 2003 focus svt
FF Reputation: 1 Mitchg1983 Good Standing Member
I have a 2003 ford focus svt. It was in storage for 6 months and I had the batty disconnected. When I hooked everything back up it will not start. When I Put the key in ignition it beeps a lot at me and then I get all the normal lights, the odometer works fine as does the radio. I took the battery to the shop and they said it fully charged. When I turn the key I get a very fast series of beeps and nothing hapens, the engine makes no noise. After that none of the normal lights come back on except for the airbag light I believe. I have to disconnect and hook the battery back up to get the lights to come back on in the dash. Is this an electrical problem I will have to get the car into the shop to fix?
Mitchg1983 is offline
Old 09-22-2011, 08:48 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Even though the battery measured as being fully charged at 12+V, it doesn't mean it has enough cranking amps to turn the motor over. You really need to have the battery load tested.
You can try substituting a known good battery or jumping the vehicle with cables. If the car sat for 6 months - depending on where - you may have some corrosion and moisture problems in the electrics. Clean the battery posts and ground connections and make sure everything is tight.
But really, it just sounds like your battery isn't up to snuff.
BC_ZX3 is offline
Old 09-22-2011, 09:03 PM   #3
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,734, Level 58
Points: 7,734, Level: 58 Points: 7,734, Level: 58 Points: 7,734, Level: 58
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 9 ViperThreat Good Standing Member
make sure the battery in your key is up too.
ViperThreat is online now
Old 09-22-2011, 09:40 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
Umm... what battery? The PATS system doesn't rely on any external battery to enable starting, if that's what you're suggesting.
It's a transponder.
BC_ZX3 is offline
