Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 09-22-2011, 01:42 PM   #1
Aquaman78
Fan#: 63887
What I Drive: 2003 Silver Focus
FF Reputation: 1 Aquaman78 Good Standing Member
changing rear brake shoes on 03 Focus
I was working on my brakes last night and got the front pads changed but could not, for the life of me, get the drums off to change the rear shoes. What needs to be done to get the drum off to gain access to the inside?
Aquaman78 is offline
Fan#: 1
Old 09-22-2011, 05:16 PM   #2
Als RS8
Als RS8's Avatar
Fan#: 53271
What I Drive: maroon lx
FF Reputation: 1 Als RS8 Good Standing Member
get a chiltons repair manuel at the nearest auto parts store and it has step by step instructions on how to do this ,i had done it a couple times and i could not have done it with out the repair manuel. they cost about 20 dollars and are usually a book on the focus at autozone or checkers!!if you cant find that respond and ill give you step by step instructions out of my repair manuel!!
[SIZE="1"]!![/SIZ
Als RS8 is offline
Old 09-22-2011, 06:11 PM   #3
Als RS8
Als RS8's Avatar
Fan#: 53271
remove dust cap
then remove hub nut
[SIZE="1"]!![/SIZ
Als RS8 is offline
Old 09-22-2011, 06:39 PM   #4
ABFORDGUY
Fan#: 89202
What I Drive: '90 Miata wife has the 2012 Ti
FF Reputation: 2 ABFORDGUY Good Standing Member
Hope this helps, sorry it won't let me paste in the pictures. I am not a tech, but this is from the workshop manual
Removal
All vehicles
Remove the parking brake control boot.
Detach the boot clip.
Remove the boot.
NOTE: Make sure the rear brakes are at a cool temperature.
Release the parking brake control to its lowest position.
Loosen the parking brake cable adjustment nut until there is no tension in the cable.
Remove the retaining clip.
Loosen the adjustment nut.
Remove the wheels and tires.
Vehicles with anti-lock brakes
Detach the wheel speed sensor.
All vehicles
CAUTION: Do not remove the brake drum by means of the hub retaining nut.
Remove the brake drum and hub assembly.
Remove the hold down springs.
Remove the pins.
CAUTION: Do not damage the wheel cylinder boots.
Disconnect the shoes from the wheel cylinder.
Detach the shoes from the anchor block.
Hold the wheel cylinder pistons in place with a rubber band.
Disconnect the parking brake cable.
Push the lever inwards.
Disconnect the cable.
Remove the lower return spring.
Remove the upper return spring.
Remove the primary shoe from the strut and brake shoe adjuster.
Pull the shoe outwards.
Disconnect the strut.
Release the strut.
CAUTION: The strut support spring is under tension.
Detach the secondary shoe from the support.
Move the strut downwards.
Detach the parking brake return spring.
Installation
All Vehicles
CAUTION: Make sure that all mating surfaces are clean of foreign material and debris.
Clean, check and apply silicon dielectric compound grease to the backing plate contact points.
Install the strut support to the secondary shoe.
Install the parking brake return spring.
Move the strut upwards.
Install the primary shoe to the strut and brake shoe adjuster.
Install the strut.
Push the shoe inwards.
Rotate the adjuster fully clockwise.
Install the upper return spring.
Install the lower return spring.
Install the parking brake cable.
Connect the cable.
Remove the rubber band holding the wheel cylinder pistons in place.
Connect the shoes to the wheel cylinder.
Connect the shoes to the anchor block.
Install the hold down springs.
Install the brake drum and hub assembly.
Install the wheel speed sensor.
All Vehicles
Install the wheels and tires. For additional information, refer to Section 204-04.
NOTE: The internal auto adjuster must be set and the brake shoes centralized to the brake drum.
Rotate the rear wheels and apply the brake pedal four times.
Carry out parking brake cable adjustment.
ABFORDGUY is offline
Old 12-21-2012, 02:46 PM   #5
PRSman25
Fan#: 103893
What I Drive: 2001 Black ZX3
FF Reputation: 1 PRSman25 Good Standing Member
Dear god that sounds like such a load of work just to change the damn shoes. Any tips to make it easier?
PRSman25 is offline
Old 12-22-2012, 01:03 AM   #6
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
FF Reputation: 1 drewts86 Good Standing Member
The drums just get frozen in place. Not a lot I can really suggest here, they are just a PITA to get off. I used a couple of tools from the body shop I used to work in; but you could do the same thing I did and use something like a screwdriver and hammer and tap on the lip near the inside portion of the rotor. Takes a while to get anywhere, definitely a full six-pack kind of job. I almost gave up and changed the fronts and left the rears the way they were.
drewts86 is offline
Old 12-22-2012, 04:37 PM   #7
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
You generally don't have to mess with emergency cable, I didn't on either of mine. You take out four bolts on the BACKSIDE of the brake assembly, they are very easy to round the corners off of. You need a quality socket there, twenty dollar socket set will have you with car at the dealer's when you round the heads off bolts. The drum and hub and stub axle all come off as one part.
amc49 is offline
