Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 09-20-2011, 12:24 PM   #1
xwhit3devilx
xwhit3devilx's Avatar
Fan#: 86578
What I Drive: 2012 Focus SE SFE
FF Reputation: 2 xwhit3devilx Good Standing Member
Adding a sub/amp to a 2012 with video!
I already posted this on the 2012 forum and sorry if this is already been discussed. Figured I'd just share a video I made on what's involved in adding an amp/sub to a 2012.
The link is here if you're interested
In case the part about the battery confuses you here is a link to the part you'll need. (This is not the one I used but looks/functions the same)
And this is the sub I used.
xwhit3devilx is offline
Fan#: 1
Old 09-21-2011, 01:35 AM   #2
BigFuzzyArchon
Fan#: 87167
What I Drive: 2012 SE Hatch Sport Package
FF Reputation: 1 BigFuzzyArchon Good Standing Member
What line out converter did you use? I think from what I have read the Audiocontrol LC2i is the best one to get unless you are adding all new speakers then the LCQ-1 is better.
BigFuzzyArchon is offline
Old 09-21-2011, 03:48 PM   #3
xwhit3devilx
Fan#: 86578
I just used a Scosche Loc80. It was $20, and since the Focus head-unit only has 25 watts per channel its more than adequate.
Old 09-21-2011, 08:07 PM   #4
diesel_travis
diesel_travis's Avatar
Fan#: 88087
What I Drive: 2012 Focus Sedan SE 203a
FF Reputation: 1 diesel_travis Good Standing Member
Nice find on the hole near the master cylinder, I was hoping I wouldn't have to drill the firewall, thanks!
2012 Oxford White Sedan SE, 203A + winter + moon + manual
Ordered: 7/16/2011, Acquired: 9/1/2011
diesel_travis is offline
Old 09-22-2011, 12:09 PM   #5
BigFuzzyArchon
Fan#: 87167
I am just concerned about the bass rollover where the factory stereo turns down the bass as the volume gets louder. Also my subwoofer is 250watts.
Old 09-22-2011, 06:55 PM   #6
FordBass
Fan#: 89775
What I Drive: 2012 Black SE Sport
FF Reputation: 1 FordBass Good Standing Member
When i get my focus i am going to have to add a subwoofer without changing the head unit... this might be tough....
I am observing all possible options........
FordBass is offline
Old 09-23-2011, 08:33 PM   #7
BigFuzzyArchon
Fan#: 87167
So I am not exactly sure why I can't use the stock terminal. It goes up, so what? Why can't I add my amp wire?
Old 09-23-2011, 10:41 PM   #8
xwhit3devilx
Fan#: 86578
Well if you can make yours fit go for it. I'm not sure, maybe mine was broken somehow when it went in for repairs; there was no place for me to attach it.
Old 09-27-2011, 06:32 PM   #9
BigFuzzyArchon
Fan#: 87167
And where do you connect the remote turn on lead? Fuse box in the trunk?
Old 10-03-2011, 09:22 AM   #10
diesel_travis
Fan#: 88087
I connected my + to the terminal on the metal plate just in front of the battery where the alternator hooks in with a bunch of other large-fused items. I'll take a pic when I get a chance.
Getting the battery out was fairly easy, I couldn't believe how light it was actually. But getting that plastic box out that it sits in was a huge PITA.
Thanks again for pointing out that unused grommet, I fit my 4 gauge perfectly through there. Although getting it through the hole in the other side was a bit tricky. I taped a nail set to the end of my wire and it helped feed it through the second hole which was a little bit lower.
Now I just have to snake it through the rest of the car and also tap into the speakers for the signal...
