18" vs 17" Rims - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-18-2011, 09:35 PM   #11
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Originally Posted by hotleadsingerguy View Post
Or you could try to avoid potholes and not hit them at high speeds? I live in Cleveland, which is *relentlessly* known for its potholes and constant construction (because of our harsh winters and hot summers the roads wear out quickly). I've never dented a rim from a pothole. Why? Because I slow down before making contact so that it doesn't do damage.
Either way, the tires that come with the 18" wheels on this car actually have quite a bit of sidewall and a large amount of overlap. You'd have to *really* hit a pothole to actually damage a wheel.
If you think 35mm sidewall is a lot of sidewall, you're insane! That is NOT a lot of sidewall! 50 is a good medium between lower profile and meaty tires. The 17"s on my SEL feel amazing, the car is very capable through tight cornering without being harsh on the driver.
Also, while the 18" wheels and handling package can handle turns better, how often are you going to be throwing this car into the corners? You don't need an autocross capable setup, so why bother? Harsh ride and expensive tires/wheels? No thank you, already went that route and paid over $600 for a set of tires on my Mazdaspeed 3.
Also, small tidbit... the 17"s will net you a much nicer turning radius, as the 18"s require a steering limiter to avoid rubbing.
Sonic Crew #28
feta_mgp is offline
Old 09-18-2011, 09:38 PM   #12
me2000
me2000's Avatar
Fan#: 85106
What I Drive: 2012 Ford Focus Titanium
FF Reputation: 1 me2000 Good Standing Member
I gotta say the turning radius with my 17"s is amazing. I got several compliments one time when I had to make a very sharp turn around on a narrow road.
me2000 is offline
Old 09-18-2011, 10:04 PM   #13
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,019, Level 33
Points: 3,019, Level: 33 Points: 3,019, Level: 33 Points: 3,019, Level: 33
Level Up 80% Completed
Forum Activity 12%
Well, ! Is that why my turning radius is so bad? Are these easy to remove?
PratoN is online now
Old 09-18-2011, 10:40 PM   #14
e350 coupe
Fan#: 84808
What I Drive: 2010 E-350 Coupe/2012 Titanium Htbk
FF Reputation: 5 e350 coupe Good Standing Member
Originally Posted by Elizabeth View Post
Generally wheels with 50 series tires are not gonna have too many problems.
The 17" wheels with 50 series tires is the ideal setup IMO for big size, vs not rubber band tires.
So i am happy with the compromises on my Focus with the 17" wheels and 215.50.17 tires.
The amount of air in the rear tires is more important for ride, that is the tire size.
And i would say having to use 39psi in the 18" is going to be a harsh ride over any bad pavement.
The base psi for the 17" tires of 36psi is pretty good compromise between solid feel and soft enough not to annoy.
For that i would say go with the 17's
Also when you have to buy tires. the 17" wheels are going to have more optiona and better pricing.
45 series 18"s cost a lot more than 50 series 17's for the same tires.
below is the link for my particular preferred comparision for my 17" 2012 Ford Focus tires. All the info:
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
PS and just because one particular tire of a brand is best in a catagory, does NOT mean others of that brand are any good at all. Conti is #1 here, but the brand has dogs rated at the bottom of the ratings in other areas.. so do your homework!
I think that people are mis-interpting what the size of tires actually are.
On the 18" wheel option the tire is a 235/40/18
235 is the tire section width in mm
40 is the sidewall height percentage in relation to width
and 18 is the rim diameter in inches on which they are mounted
in this case tire section width is 235 mm and sidewall height is 40% of the width, or 94mm
(3.70")
when we compare this to the 17" wheels which are 215/50/17
the tire section width is now 215 mm (20mm less)
50 is the height of the sidewall as a percentage of width.
and the diameter is now 17"
for 17" oem, the sidewall height is 50% of 215mm or 107.5mm (4.23")
thus the difference, between 17" and 18" oem wheel package is 13.5mm or .531 of an inch.
this difference is about 1/2" in sidewall height which if you double it accounts for the difference between 17 and 18 inches.
e350 coupe is offline
Old 09-19-2011, 10:37 AM   #15
cobie56
Fan#: 84403
Originally Posted by PratoN View Post
I'd probably recommend the 17 rims" - I have the 18" rims which come with stiffer springs. While it looks better and can handle turns better, if you're going to be doing a lot of commuting I think you'd appreciate the softer ride.
i read on this site that the SEL and Ti have the same spring rates, the only diff being larger 18" wheels and stiffer shocks/struts on the Ti
Is this correct?
cobie56 is offline
Old 09-19-2011, 11:21 AM   #16
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
Is this correct?
There are a few threads that explain this. I believe the standard Ti and SEL have the same spring rates. However, the titanium handling package comes with 18 rims, stiffer springs than the 17 titanium tires, handling struts (revalved or something) as well as steering limiters to prevent rubbing due to the wider tires.
You can check the other threads if you want the exact part nubmers...
Old 09-19-2011, 12:20 PM   #17
Triton46
Fan#: 79089
What I Drive: 2002 Nissan Maxima SE
FF Reputation: 1 Triton46 Good Standing Member
Originally Posted by Kryssa View Post
If you are considering the Handling Package with the 18"s that includes the full size spare, understand that the full-size wheel, takes up a lot of additional cargo room that would otherwise be yours to fill with cargo. The floor is raised up at least an additional 3-4". That is why I stuck with the 17"s on my Ti.
Good point, Thanks!
Triton46 is offline
Old 09-19-2011, 12:45 PM   #18
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
True. But you can always take out the spare and spacer if you REALLY want the 18" rims. I'd only recommend this if you have AAA and nowhere to go. As for myself, I'll just deal with limited trunk space.
Old 09-19-2011, 12:52 PM   #19
ssn666hawkbill
ssn666hawkbill's Avatar
Fan#: 12657
What I Drive: 2012 Titanium Blue candy
FF Reputation: 0 ssn666hawkbill Newbie
in my Ti, full size spare is 215/55/16's... atleast its not a donut, but full size to me is atleast same OEM on my Ti with 18's... oh well
ssn666hawkbill is offline
Old 09-19-2011, 12:56 PM   #20
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,299, Level 28
Points: 2,299, Level: 28 Points: 2,299, Level: 28 Points: 2,299, Level: 28
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
Originally Posted by e350 coupe View Post
235 is the tread width in mm
Incorrect. The first number of a tire size is known as the nominal width and is measured sidewall to sidewall, not tread width.
Just curious as to why nobody is going for the 16s. I find them to be a very happy medium between handling and ride comfort. There's also less rotational mass which = faster acceleration and better mileage (as minimal as it may be).
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
