Tire Pressure - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-14-2011, 05:26 PM   #1
glockoma
glockoma's Avatar
Fan#: 89451
What I Drive: 2012 FF Ti
FF Reputation: 1 glockoma Good Standing Member
Tire Pressure
Long time lurker, first time poster. I just received my 5-door and was curious what psi others are running in their tires? The Continentals that came with the 17" polished alloys indicate a max of 51psi - currently set at 40psi.
Two-thirds of my commute is highway and I have been averaging ~38mpg although I did manage to squeeze out 51mpg (no stops, 40-50mph for approx. 15 minutes).
glockoma is offline
Old 09-14-2011, 05:33 PM   #2
Kabigon
Fan#: 88299
Points 4,566, Level 43
Points: 4,566, Level: 43 Points: 4,566, Level: 43 Points: 4,566, Level: 43
Level Up 8% Completed
Forum Activity 14%
FF Reputation: 11 Kabigon Great Standing Member
You should use the recommended tire pressure (35 PSI) as a guideline.
I usually set the tire pressures to 2~3 PSI greater than the recommended pressure.
Kabigon is offline
Old 09-14-2011, 05:38 PM   #3
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
A good place to start is what ever the sticker on the door jam recommends. The tire rating is the safe maximum pressure the tire can handle.
Dgc333 is offline
Old 09-14-2011, 05:40 PM   #4
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,078, Level 34
Points: 3,078, Level: 34 Points: 3,078, Level: 34 Points: 3,078, Level: 34
Level Up 19% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
I have the 18" summer tires which recommend 39psi. I was wondering if it would be dangerous to drive with about 5psi more than this? Do you think there would be a noticeable difference in gas mileage - especially at lower speeds?
PratoN is online now
Old 09-14-2011, 05:42 PM   #5
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,900, Level 76
Points: 13,900, Level: 76 Points: 13,900, Level: 76 Points: 13,900, Level: 76
Level Up 63% Completed
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
to ff.com
as stated above 35 psi is normal
the reading on the sidewall of the tire is the max the tire can handle, however this is set by the manufacture of the tire. The 35psi that ford stated for the car, which gives you the proper footprint where the tire meets the road, this insures proper traction, tire wear, and fuel economy, always set tires at what the car manufacture says, Never set your tires at the max rating on the sidewall.
SkyPilot is offline
Old 09-14-2011, 05:55 PM   #6
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 3%
But...but... hypermiling and such? (I've never tried, but I'm tempted to)
Old 09-14-2011, 06:01 PM   #7
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,726, Level 78
Points: 14,726, Level: 78 Points: 14,726, Level: 78 Points: 14,726, Level: 78
Level Up 69% Completed
Forum Activity 12%
FF Reputation: 16 Elizabeth Great Standing Member
I have found having the front tires at 5 to 8 PSI higher than the rear gives the actual equal tire footprint.
The front of a front engine car IS HEAVIER, and thus the tires, to actually have the same footprint oval, fronts have to have higher pressure than the rear.
Also with too much pressure in the rear tires, the ride gets really choppy.
So if you are trying to save gas with higher pressure in the tires...
If the recommended all around is 35, go 37 rear, 42 front. Even 43 front
(A V-6 i would go 8 pounds heavier front than rear, with a small four banger, like the Focus, four to six pounds more air front is great.)
If you want a good ride, then stick to 36 instead of 35 rear, and 40 or 41 front.
I am using 41 front, 36 rear and the ride over concrete is MUCH better than 38 all around.
I may go up to 43 front and 36 rear just to try it out. (When the front steering is very 'light' then your front tires are too high a PSI)
IMO the 'even' all around tire pressure is for simple folk not to get confused.
(Feel free to dis' me for that comment, no problem, I stick by the reality of actually measuring the contact oval and IF YOU DO, the front PSI will be higher to aquire a similar oval contact patch (the golden ring of tire pressure, read up on it...), as I said, by anywhere from 4 to 8 pounds.. in a front engine car. ALWAYS
Elizabeth is online now
Old 09-14-2011, 06:09 PM   #8
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 3%
Originally Posted by Elizabeth View Post
I have found having the front tires at 5 to 8 PSI higher than the rear gives the actual equal tire footprint... Feel free to dis' me for that comment, no problem, I stick by the reality of actually measuring the contact oval and IF YOU DO, the front PSI will be higher to aquire a similar oval contact patch...
Wow - I took a automotive design class last semester and for all of the "contact patch" talk we went over, we never talked about higher pressure in the front tires. But it makes sense to me!
Old 09-14-2011, 07:25 PM   #9
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Forum Activity 8%
true, hypermiling is a different story, in order to do hypermiling you will need to set your tires higher to get the best results. While I will admit a higher set psi will get you better mileage, there are many more factors in how you drive in order to get the same result of higher mpg's. But consider this the higher pressure puts more wear on the middle of the tire, resulting in premature wear. also with less rubber on the road less traction, while this isn't an issue with dry roads, when it rains you have a much higher chance of hydroplaning than if you had your tires set at the recommended setting due to the size of the foot print.
You make a very valid argument here. and while I do agree with most of what you have said, and it is true that a higher will result in a better ride typically, but once again your making a smaller footprint with the road. Yes there is more weight up front, and yes it has a larger foot print due to the weight, but going again back to traction, since the car is front wheel drive you will get more traction, and the majority of the breaking is done with the front breaks as well. So with a higher pressure up front making the foot print smaller, it could affect traction negatively, and increase breaking distances.
SkyPilot is offline
Old 09-14-2011, 11:12 PM   #10
wag4513
wag4513's Avatar
Fan#: 87744
What I Drive: 2011 Acura MDX
Points 377, Level 7
Points: 377, Level: 7 Points: 377, Level: 7 Points: 377, Level: 7
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 wag4513 Good Standing Member
Keep in mind the recommended pressure is with the tires cold. Driving the car with the tires flexing raises the temperature and increases the pressure. In hot weather the tire pressure can go much higher than the recommended pressure. Also, if the tires are too hard (over inflated) they are prone to damage from rough roads, curb and junk on the street.
Silver Titanium, 401A, Tuscany Red,
Winter Package, 17" Polished Wheels,
Nav, MFT, Sync, and Parking Assist.
Ordered July 19th, Built August 12th,
Delivery estimate 8/29 Picked Up Car on 9/9
wag4513 is offline
