Fun with PlastiDip! - Page 260 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-17-2012, 08:50 PM   #2591
Continuous
Continuous's Avatar
Fan#: 84970
What I Drive: 2004 SVT ZX3 Infra-Red
Points 1,035, Level 17
Points: 1,035, Level: 17 Points: 1,035, Level: 17 Points: 1,035, Level: 17
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 Continuous Good Standing Member
Well I was gonna use dip because it peels off where as the night shades junk doesn't why wouldn't the dip peel off after a couple coats like normally?
Infra-Red SVT ZX3
Continuous is offline
Old 12-17-2012, 08:53 PM   #2592
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Because, it takes several thick coats of plastidip if you want it to peel off. Go try it, see if you can peel it!
Hatch Nation #8
September 2012 Ride of the Month
katiekay is online now
Old 12-17-2012, 09:05 PM   #2593
Continuous
Continuous's Avatar
Fan#: 84970
I was gonna do a black out setup since the smoke doesn't really look that great on the tails and if I do a bunch of coats it's fine cause I was planning on that to begin with.
Infra-Red SVT ZX3
Old 12-17-2012, 09:09 PM   #2594
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
If you do a bunch of coats of plastidip, you will not see any light shining through. I have also said that previously. Go ahead, ruin your lights, I am done talking to ya!
Good luck and Happy Modding!
Hatch Nation #8
Old 12-17-2012, 09:11 PM   #2595
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
Level Up 0% Completed
FF Reputation: 7 VonKrause Good Standing Member
Honestly due to the thick nature of plastidip I would avoid it on the tails. The added layer could cause the heat buildup inside the fixture to get to the point of melting the plastic. It happened to a friend of mine with very heavy vinyl on his.
If you are going to tint the tails I suggest either nightshade or smoked vinyl. If you or someone you know is good at vinyl application it is removable and if you don't, learning experience?
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
Old 12-17-2012, 09:12 PM   #2596
Continuous
Continuous's Avatar
Fan#: 84970
Man relax I just don't understand how this process will ruin the lights. I've seen some that were done with about 3-4 coats and when the lights are turned on you can see through them. And I was a detailer before and I know how much Nightshades can ruin lamps because you need a special paint inhibitor to remove that stuff but on top of that it can remove the red color of the lenses.
Infra-Red SVT ZX3
Old 12-17-2012, 09:13 PM   #2597
Continuous
Continuous's Avatar
Fan#: 84970
I get that point of it I am just definitely staying away from the Nightshades stuff had a really bad experience removing that. Any places you would recommend for finding a smoke vinyl?
Infra-Red SVT ZX3
Old 12-17-2012, 09:15 PM   #2598
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Lamin-X is what I used, I botched one, but the other turned out great! They have different shades that you can use, so when I do peel off the botched tail, I am replacing both with a different shade. Once you get the hang of it, it's very easy and reversible!
Good learning experience too.
Hatch Nation #8
Old 12-17-2012, 09:18 PM   #2599
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Yea hear you on that, I stayed away from Nightshade just in case I wanted to go back to stock. Not too sure where a good place to pick some up for cheap would be, got a guy to do it here locally that does that sort of thing. I know that a local guy just got some you might ask him where he got it. (Screen name is SvviftSVT on here) I personally am a huge fan of the vinyl.
"2nd Gen problems"
SR #233
Old 12-17-2012, 09:21 PM   #2600
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Looks great! Daniel used a roll that was not pre cut, but he is definitley used to working with vinyl. Props for that!
Here is Lamin-X in the second to the lightest shade
EDIT: that is the tail that I botched, look up at the top corner closest to the rear window and you can see the line going down. The other one looks perfect!
Hatch Nation #8
