12 Volt Outlet Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2011, 09:33 PM   #1
Bradkap
Fan#: 89782
What I Drive: 2012 grey metallic, titanium hatchb
Points 773, Level 14
Points: 773, Level: 14 Points: 773, Level: 14 Points: 773, Level: 14
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 1 Bradkap Good Standing Member
Is there any way to adjust the 12 volt outlets so that the power to them shuts off when the engine is shut down ? I do not want to have to remember to always turn off NY appliances.
Bradkap is offline
Old 09-11-2011, 09:42 PM   #2
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Why wouldn't they shut off? They don't shut off immediately when you remove the key, but they do shut off, otherwise they would be sapping battery life...
Sonic Crew #28
feta_mgp is offline
Old 09-11-2011, 10:16 PM   #3
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
Its not going to drain your battery. Unless you're running a power inverter with your home office running on it without the engine (alternator) running.
Posted via FF Mobile
BetaDnB is online now
Old 09-12-2011, 12:37 AM   #4
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Regardless, the accessory power doesn't stay on. It does only until you open the doors and get out of the car. Why would the 12v outlets be on the constant?
Sonic Crew #28
feta_mgp is offline
Old 09-12-2011, 02:02 AM   #5
Bill3rAIL
Bill3rAIL's Avatar
Fan#: 89058
What I Drive: 2012 SE 5Dr Hatch Silver/2002 Dodge
Points 434, Level 8
Points: 434, Level: 8 Points: 434, Level: 8 Points: 434, Level: 8
Level Up 68% Completed
FF Reputation: 2 Bill3rAIL Good Standing Member
I think my aux power stays on also. My GPS stays on and I have not tried to wait until it self powers down to verify that it loses power.
Bill
Bill
2012 5 Door Hatch SE
203A & Sport package with 16" wheels
Bill3rAIL is offline
Old 09-12-2011, 05:12 AM   #6
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
This following is taken from the service manual. The power control for both 12V outlets is the same as the demand lamps.
The BCM provides automatic shut-off of the courtesy and demand lamps after a time-out period when the ignition is OFF. A timer in the BCM starts when:
• the ignition changes to OFF,
• any door or liftgate/luggage compartment lid becomes ajar,
• an UNLOCK button of the RKE transmitter is pressed,
• a door is unlocked using a key, or
• the door lock switch is pressed.
When 10 minutes (30 minutes for demand lamps) have elapsed, the BCM automatically shuts off voltage to the lamps. The timer restarts (voltage is restored if the BCM is in battery saver mode) if:
• the ignition changes out of OFF,
• the UNLOCK button of the RKE transmitter is pressed,
Kabigon is online now
Old 09-12-2011, 06:27 AM   #7
Bradkap
Fan#: 89782
Ok thanks everyone. In my Hondas everything shuts down when the car shuts off. I tested the Focus and the 12 volt outlets remain on for at least 5 min. I will do a longer test to see what happens.
Bradkap is offline
Old 09-12-2011, 08:14 AM   #8
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
I my 2004 I can charge my phone with the car off, Never caused any issues.
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 09-12-2011, 10:03 AM   #9
scottjl
Fan#: 86588
What I Drive: 2012 StrlGry 5dr Ti
FF Reputation: 1 scottjl Good Standing Member
common misconception (and frequently posted...) the usb and 12v ports only stay on for about 10 minutes after you exit the vehicle. if you're looking to join the DBC you'll have to find another way.
scottjl is offline
Old 09-12-2011, 02:42 PM   #10
dasilvarsa
dasilvarsa's Avatar
Fan#: 89551
What I Drive: 2012 2.0 Gdi Trend
FF Reputation: 2 dasilvarsa Good Standing Member
Can confirm without any doubt that the power outlet stays hot for some time after the car is locked and then switches itself off. (30 minutes later)
Did the experiment tonight with a garmin navigator.
Once the key fob is pressed to unlock doors power is restored.
2012 Focus 2.0 GDI Trend (RHD Euro Focus with US Engine)
dasilvarsa is offline
