Easiest way to install push button start? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 09-08-2011, 11:17 PM   #1
davindeadly
davindeadly's Avatar
Fan#: 84075
What I Drive: 2009 Sangria Red SE
Points 431, Level 8
Points: 431, Level: 8 Points: 431, Level: 8 Points: 431, Level: 8
Level Up 62% Completed
FF Reputation: 1 davindeadly Good Standing Member
Wouldn't the easiest and most hassle-free way of installing a push button start system be taking the wire that goes from the ignition switch to the starter and putting a button of some kind in between them?
You'd still need your keys and all of that good stuff, but would this not work?
Let me know what you think asap.
davindeadly is offline
Old 09-09-2011, 02:11 AM   #2
A.D.D. Focus
Fan#: 80847
What I Drive: 2006 Blue ZX4 SE SAP
FF Reputation: 1 A.D.D. Focus Good Standing Member
i dont think this would work because ignition is a momentary switch and you would have to hold your key in ignition mode or start and not just on. you would also have to push your push button switch while you hold your key in start.
someone correct me if i am wrong but i think that answers that question.
this is a guess but i think you might have to rewire ignition so it does not work with the key in ignition only. when it is in the "on" position power is supplied to all of the switched power accessories and whatnot and if you had a momentary switch or button installed in place of ignition the car would start when you push it...
so long story short i think you would have to cut the ignition wire and hook it up to a momentary switch instead of ignition>button>start like you said.
it would go from stock (key turned to on>power is supplied>key turned to ignition> start car)
to this (key turned to on>power is supplied>push button instead of turning key to ignition>start car)
i could make a wire diagram but i dont really want to sorry. and also this is just based on my knowledge of switches and electricity from looking around online and stuff, i dont have a push button start but that was my best guess, hope it helps
A.D.D. Focus is offline
Old 09-09-2011, 10:53 AM   #3
davindeadly
Fan#: 84075
Points 431, Level 8
Yeah, I see what you're saying.
I didn't think about that at first.
So it'd be more like, tap into a live 12 volt wire (more than likely the one running to the ignition switch as well), run it to the switch, then tap into or cut the wire that goes from the ignition to the starter and run that to the button?
Thanks for the reply though.
Old 09-09-2011, 11:19 PM   #4
dmoney52806
dmoney52806's Avatar
Fan#: 68719
What I Drive: 09 graphite WRX stg 2
FF Reputation: 1 dmoney52806 Good Standing Member
you can do this! a guy did it in his 05 (maybe 07?) by wiring the push button in place of the cigarette lighter, came out real clean, try to search for it
i should also add all he bought was a push button start off ebay for a few bucks and then the general wiring connectors you'd need, so maybe 10 bucks
Selling my motorcycle, Help me get back into the FF community!
dmoney52806 is offline
Old 09-10-2011, 02:50 PM   #5
davindeadly
Fan#: 84075
Points 431, Level 8
Haha. I'm gonna do it with in the next couple weeks. I gotta get my funds back up after spending all my money on my LEDs for the car.
The only problem with the lighter thing is, I actually use mine for my phone charger. So, I was thinking about rigging it up so the button was in my ash tray, and when you pull the ash tray out the button pops up
We'll see how it goes.
Old 09-13-2011, 11:40 PM   #6
hockeyfreek42
hockeyfreek42's Avatar
Fan#: 53956
What I Drive: new 2014 ST!!. 2002 blacked out zx3
FF Reputation: 3 hockeyfreek42 Good Standing Member
http://www.focusfanatics.com/forum/s...threadid=66373
Li Foci
2008 Car Show Places: 1st[bootyshak
hockeyfreek42 is offline
Old 09-14-2011, 01:10 AM   #7
xBigone101x
xBigone101x's Avatar
Fan#: 89090
What I Drive: 2013 Focus ST
FF Reputation: 1 xBigone101x Good Standing Member
by a car that already has one in it lol
xBigone101x is offline
Old 09-14-2011, 06:16 PM   #8
davindeadly
Fan#: 84075
Points 431, Level 8
Lmao. I wish it was that easy, $25 for a button is easier than $20k for a car with a button in it.
Old 09-20-2011, 09:13 PM   #9
boostdfocus
Fan#: 87465
What I Drive: 2004 Silver ZX5-T
FF Reputation: 1 boostdfocus Good Standing Member
Right under the steering column, behind the knee panel, tap your button into the solid red and the grey/black stripe wire.
Multi-Focus Owner: 04 ZX5 Zetec 5 Speed: Boostd with 16G at 7psi (13.8 at 104 missing 4th) , Toms tune,fully gutted interior; 2014 Tuxedo Black Escape S: snorkel delete, muffler delete (wifes ride)
Zetec Crew#376
boostdfocus is offline
Old 12-16-2012, 02:05 AM   #10
TheDude
Fan#: 107335
What I Drive: 2002, black zx3
FF Reputation: 1 TheDude Good Standing Member
You could do what I did. Take the ignition switch completely out canceling out the use of the key you have to remove it so your steering wheel doesn't lock up. Run all your accessories to a toggle switch and run the ignition wire off a push button or straight from the starter solenoid to the push button. This way you can turn all your accessories on if you need just that. You can not wire them all together including the ignition cable because it will constantly try to start your car so you will be grinding out your starter. It is a pretty simple process you just have to find out what wires do what and run your new power and ground for the toggle and your all set.
TheDude is offline
