Two magazine shoots in one show!!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-05-2004, 08:42 AM   #1
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
Talking Two magazine shoots in one show!!!!
I took the 6 hour trip to the NMRA World Finals in Bowling Green, KY and not only won a couple of trophies with my 'Stang, I got two magazine photo shoots!!!! 5.0 Mustang and Super Fords (finally) and Mustang Enthusiast. I am soooo darned happy. The car even dropped off the edge of the trailer and ruined the mufflers the first day, but I still am just so happy, that a little money for new mufflers is nothing.
TORQUERULES is offline
Old 10-05-2004, 10:23 AM   #2
TORQUERULES
The Professor
Fan#: 1083
1
Old 10-05-2004, 10:24 AM   #3
TORQUERULES
The Professor
Fan#: 1083
2
Old 10-05-2004, 10:27 AM   #4
TORQUERULES
The Professor
Fan#: 1083
3
Old 10-05-2004, 11:01 AM   #5
pio
pio's Avatar
Fan#: 198
What I Drive: 2014 focus electric
FF Reputation: 2 pio Good Standing Member
Buy-Sell-Trade Rating: (7)
how fast is your mustang...
and what does it have?
My focus is not even a shadow of what it once was...
pio is offline
Old 10-05-2004, 11:59 AM   #6
TORQUERULES
The Professor
Fan#: 1083
Haven't raced it, but you can check out my web site for more info.
Old 10-05-2004, 12:00 PM   #7
TORQUERULES
The Professor
Fan#: 1083
Mustang Tech Specs
1987 Medium Yellow LX 5.0 Coupe
Owner: Matt Wells. Ripley, WV. Occupation: High School Teacher
*All work except paint performed by Matt and Hank Wells (aka WELLSpeed High Performance).
Engine and Drivetrain:
Block: Stock roller
Bore: 4.00 inch
Stroke: 3.00 inch
Displacement: 302 cid
Crank: Stock; balanced, polished & deburred, chamfered oil holes, ATI damper
Rods: Crower Sportsman; balanced, 5.4 inch
Pistons: Ross ultra-lite; balanced, small domes & zero decked, 11.5:1 compression, Speed-Pro low-tension rings
Oil Pan: Steeda 7 Qt baffled with crank scraper
Cooling: Ron Davis aluminum radiator, Flex-a-lite flex fan, Stewart water pump, FRPP oil cooler
Cam: “BIG” Comp Cams hydraulic roller with Erson high-rpm lifters
Heads: Edelbrock Victor Jr.; Bennett Racing high-rpm hyd.-roller race valve springs, Comp Titanium retainers, Harland Sharp 1.6 roller rockers, Crane 1-piece chrome-moly pushrods
Valves: 2.05/1.60
Intake: Edelbrock Victor 5.0 EFI
Throttle Body: Accufab Race 85 mm
Mass Air Meter: C&L 80 mm with a custom 4 inch intake pipe
Power Adder: Custom 50-300 hp nitrous system (600 hp on dual stage setup) utilizing an NX Gemini-Twin Plate and NX Stage V Iceman solenoids, grill mounted purge 
Fuel System: Mallory 110 FI pump, twin Mallory filters, Magnafuel regulator, Vortech fuel rails, FRPP 36 lb injectors, Ground Pounder pick-up, -10 /–8 supply and –6 return lines
Headers: MAC 1 3/4 inch long-tube headers
Exhaust: 2 1/2 inch Bassani off-road x-pipe, 3 inch Race Magnum mufflers, no tail pipes
Transmission: FRPP “Z” T-5, SPEC aluminum flywheel, SPEC Stage IV High-RPM clutch and pressure plate with lightening option, FRPP aluminum driveshaft, Pro-5.0 shifter, urethane mount
Rear-end: 8.8 with Auburn Pro differential, Moser axles, 4.30 gears
Electronics:
Engine Management: A9L computer, custom Autologic 4-position chip from JMS
Ignition: Mallory HyFire VI Multiple Spark Discharge CD box, MSD Pro Billet distributor, Accel 300+ coil, FRPP wires, NGK Iridium plugs
Gauges: Autometer Phantom Speedometer, Tachometer, Shift-Lite, fuel level, volts, oil pressure, water temperature, fuel pressure. Edelbrock nitrous pressure
Other Controls: Custom switch panel for nitrous plus “stuff and things”
Suspension and Chassis:
Front Suspension:
K-Member: Modified stock; welded seams, custom solid motor mounts for 1 inch lower engine
Control Arms: Ground Pounder tubular
Springs: Ground Pounder coil-overs; road-race spec.
Sway Bar: Suspension Techniques
Steering: Flaming River 15:1 manual rack and shaft, Ground Pounder bumpsteer kit, Maximum Motorsports solid mounts
Struts: Monroe Formula GP with Ground Pounder caster/camber plates
Brakes: Power Stop cross drilled rotors, Lincoln 73 mm calipers, Hawk pads
Wheels and Tires: Centerline Billet 17x8 inch with Yokohama A520 245/45/ZR-17
Rear Suspension:
Control Arms: HP Motorsport Mega-bite Jr. lowers, modified stock uppers with urethane bushings
Springs: FRPP M-5300-C
Panhard Bar: Modified BBK
Shocks: Monroe Formula GP; no quad shocks
Brakes: SSBC slotted rear rotors, Porterfield pads
Wheels and Tires: Centerline Billet 17x8 inch with Yokohama A520 255/45/ZR-17
Chassis Stiffening: Steeda chrome-moly subframe connectors and custom chrome-moly G-load brace
Exterior:
Color: 1987 Specific Ford Medium Yellow
Hood: Cervini’s 3 inch cowl-induction
Rear Spoiler: Cervini’s Mustang Anniversary Wing
Lights: Clear fronts, Black ’87-’93 GT rears
Other: Running Pony emblems, Saleen front filler panel, sunroof, and few nicks and dings from driving (yes, it is driven whenever I have the chance!)
Interior:
Seats and upholstery: Flo-fit front buckets with lumbar support, rear seat (and door panels) covered in matching Flo-fit material
Shifter: Pro-5.0. with a Hurst stick and button T-handle
Instrumentation and other controls: Autometer Phantom, custom panel with aircraft switches
Steering wheel: Grant billet with leather wrap
Bling: Billet window switches and panels, billet HVAC control knobs, billet door handle bezels, billet steering tilt handle, billet coat hangers, billet door lock knobs, billet parking brake handle, chrome fire extinguisher
Coming Spring 2005:
331 cid stroker shortblock (12.5:1 compression, Scat lightweight rotating assy., FRPP Sportsman 302 block w/main girdle), Comp Cams solid roller cam, Bassani 1 3/4-1 7/8 inch long-tube headers (ceramic coated), Bassani 3 inch off-road x-pipe (stainless), Bosch 42 lb injectors, Pro-M Shorty 80 mm MAF, etc..
Feel free to visit my website:
www.geocities.com/mattsstang87
Old 10-05-2004, 01:05 PM   #8
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Very cool.. Glad you made it..
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 10-05-2004, 01:27 PM   #9
Lil Skeet
Lil Skeet's Avatar
Fan#: 8013
What I Drive: 2001 Light Sapphire Blue ZX3
FF Reputation: 1 Lil Skeet Good Standing Member
It looks like I have to go to Barnes&Noble to get some new reading material. Congrats
Lil Skeet is offline
Old 10-05-2004, 01:28 PM   #10
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Awesome stang.... wow....
Quick question, how did you get a CUSTOM MEMBERS TITLE with only 493 posts?
Chad (S2)
S2 is offline
Similar Threads
~~Focus in the Field 2009~~Aug 29-30th!!! beat3rfocus Great Lakes Fanatics 328 08-27-2009 01:47 AM
All American Car Show 7-31 FlyFord Fanatics: SoCal 0 07-27-2004 11:05 AM
Focus Fanatic Magazine ZTSRacer Ford Focus & General Car Chat 43 04-06-2004 11:09 PM
