Thermostat housing upgrade - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 09-06-2011, 10:29 PM   #1
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
FF Reputation: 1 JBotone Good Standing Member
Is there a how to for the thermostat housing upgrade? I looked through the how-to, and could not find one. I have just done mine, and would be willing to post, if you think it is needed.
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger 463,000 miles.
JBotone is offline
Old 09-07-2011, 10:35 PM   #2
JBotone
JBotone's Avatar
Fan#: 78479
Here is a quick how-to for the upgraded thermostat housing from Tousely Ford.
The kit the send is complete except for the brass plug you will need to fill the extra port on the housing.
Make sure car is stone cold before doing this.
1) Remove battery cover and disconnect battery and remove.
2) Remove battery tray.
3) Drain antifreeze from radiator. (Loosen reservoir cap to help it drain)
4) Remove coil cover & spark plug cover.
5) Loosen vent hose from valve cover.
6) Unplug connector from coil pack (I used a little flat head screw driver to loosen the clip.)
7) Unplug coolant sensor connector.
8) Unbolt capacitor next to coil pack. (7mm socket)
9) Unbolt coil pack. (I did not unplug the spark plug wires, it moves out of the way easily once unbolted.)
10) Remove coil pack bracket (3 Torx bit bolts, there is also a wiring harness attached to the bracket, loosen the vinyl clip, and you can then pull out the bracket.)
11) Remove all four hoses from thermostat housing. (I used channel locks, and the battery tray being removed made this a lot easier, I tried it once with it in place.)
12) Unbolt thermostat housing. (3 10mm bolts)
(As a side note, I had very little antifreeze drain out when I took the hoses and thermostat housing off, thank goodness, I hate a mess. I had a drip pan in place just in case.)
13) Clean head surface where thermostat housing is mounted.
I put the thermostat housing together before I mounted it on the car.
14) Install brass plug into extra port, using a little Teflon tape, and snug it up tight.
15) Put o-ring on thermostat, slide it into housing, and put on thermostat cap, tighten down the 3 supplied threaded screws. (This is a god send, next to the self taping screws on the original housing) You don't have to crank these down, they stop when they are tight enough.
16) Install supplied temp sensor. I used a little Teflon tape on this as well. 19mm wrench fits the sensor.
17) Bolt new housing onto the block. I could not find exact torque specs on this..I called Steve at Tousley, and his recommendation was to use a 1/4 drive ratchet, and tighten them until snug. (Worked like a charm.)
18) Back fill the cooling system with the hose that attaches to the back side of the thermostat housing. Fill until it starts coming out of the housing, and attach the back hose.
19) Attach remaining hoses.
20) Reverse steps 1-10. (Leaving coil cover off to check for leaks.)
21) Fill reservoir, and here is the procedure from the service manual, from Steve @ Tousley Ford.
According to the service manual,
Backfill the system through the heater hose off the back of the thermostat housing until coolant comes out of the fitting on the housing. Then replace the hose.
Then fill the degas tank and replace the cap, start the car, heater control to hot, A/C off, heater fan off.
Run the car at 2700 rpm for two cooling fan cycles to bleed out all remaining air.
In my experience you don't have to wait the full two fan cycles, as long as you have strong heat and the degas tank is full you should be good to go.
22) Check for leaks, once you are satisfied with it, replace coil cover, and take it for a test drive.
JBotone is offline
Old 09-11-2011, 07:27 PM   #3
sldghmr
sldghmr's Avatar
Fan#: 56236
What I Drive: 2004 SVTF, 2003 F-350, 1967 GT-500
FF Reputation: 6 sldghmr Good Standing Member
Thanks for the write up on this... I can't see the pics (maybe it's my work computer, will check again when I get home). This upgraded thermostat housing, is it metal? or plastic again? I've crossed 110K miles so starting to replace EVERYTHING a little at a time....
#449 of 1978 - Black on Black
JRSC w/BBK, McNews's tune, ORP, K&N air, R3d_RovrZX3 3rd brake conversion w/blinkers, FRPP strut tower bar, cross drilled rotors, HPS pads, SS brake lines, lit door locks, Torsen LSD, Centerforce clutch & flywheel...
sldghmr is offline
Old 09-12-2011, 07:09 AM   #4
JBotone
JBotone's Avatar
Fan#: 78479
It is still plastic, but seems to be made better. It's biggest benefit is having everything machine threaded, temp sensor, plug, and thermostat cap bolts. It's a HUGE improvement. I think the only aluminum one I have found would be from HTP, and they are quite pricey.
I will try and repost the pics, I think it was my bad on that one. There are only three, and not extremely detailed, basically before, off, and after..LOL I got to working, and forgot to take all the pics I should have.
JBotone is offline
Old 01-16-2012, 10:28 PM   #5
SWEGER
SWEGER's Avatar
Fan#: 88926
What I Drive: 2003 Infra-Red ZX5 SVT
FF Reputation: 1 SWEGER Good Standing Member
Where do I get this upgraded housing? Is it a Ford part or aftermarket? Part number? Price? Thanks in advance
2003 Infra-Red ZX5 SVT - Cheap Spectre intake (don't judge, was on there when I got it), Hawk HPS pads front/rear, Russell SS lines, Goodyear Eagle GT 215/45/17
"If guns cause violence, then all of mine are defective" - Ted Nugent
SWEGER is offline
Old 01-16-2012, 11:32 PM   #6
JBotone
JBotone's Avatar
Fan#: 78479
Call Steve at Tousley Ford, he puts a nice kit together for around $120 I think
I don't have my receipt handy. I am very glad I did it.
JBotone is offline
Old 01-17-2012, 12:42 PM   #7
JBotone
JBotone's Avatar
Fan#: 78479
Steve put the kit together, it is a Contour thermostat housing, and he includes everything you need in the kit except for the brass plug you will need for the extra sensor hole. I picked mine up at Lowe's.
CFM sells one as well, but theirs is pricier and from what Steve told me they got the idea from him.
JBotone is offline
Old 01-17-2012, 02:36 PM   #8
runun
runun's Avatar
Fan#: 57192
What I Drive: 2003 Orange EAP SVT 3-Door
FF Reputation: 2 runun Good Standing Member
JBotone - Thanks for the how-to guide! Could you please edit step 16 to say a 19mm or 3/4" wrench will fit the sensor, since 3/4" is within a hairs width of 19mm. I don't own a 19mm wrench, but I do have a 3/4" wrench and remembered from various past encounters with 19mm nuts and bolts that my 3/4" wrench fits nice and snug. Thankfully, I remembered this before buying a wrench I didn't actually need. By the way, I have my Tousley receipt in front of me and I paid $104.15 + $10 shipping ($114.15 total). Also, be sure to mention special internet pricing if you order by phone. The brass plug should be 1/8 inch pipe thread. When I brought my housing into the hardware store, the 1/8 inch would only thread in 2-3 turns by hand before tightening up. However, once you get the Teflon tape on it, it will turn smoother into the extra port. Also, I found a counter sunk 1/8 inch pipe thread brass plug that IMO looks and works the best. The plug is just over 7mm tall and fills the extra port neatly without sticking out. I will also list the part numbers as a convenience to anyone checking out this thread.
F8RZ 8592 AG - Thermostat Housing
F5RZ 8592 A - Thermostat Cap
F8CZ 12A648 B - Sender Assembly
W500015 S309 - Screw (requires 3 of these)
W700319 S300 - Thermostat O-ring
F8RZ 8575 CA - Thermostat
runun is offline
Old 01-18-2012, 10:24 AM   #9
JBotone
JBotone's Avatar
Fan#: 78479
Originally Posted by runun View Post
JBotone - Thanks for the how-to guide! Could you please edit step 16 to say a 19mm or 3/4" wrench will fit the sensor, since 3/4" is within a hairs width of 19mm. I don't own a 19mm wrench, but I do have a 3/4" wrench and remembered from various past encounters with 19mm nuts and bolts that my 3/4" wrench fits nice and snug. Thankfully, I remembered this before buying a wrench I didn't actually need. By the way, I have my Tousley receipt in front of me and I paid $104.15 + $10 shipping ($114.15 total). By the way, be sure to mention special internet pricing if you order by phone. Also, the brass plug should be 1/8 inch pipe thread. When I brought my housing into the hardware store, the 1/8 inch would only thread in 2-3 turns by hand before tightening up. However, once you get the Teflon tape on it, it will turn smoother into the extra port. Also, I found a counter sunk 1/8 inch pipe thread brass plug that IMO looks and works the best. The plug is just over 7mm tall and fills the extra port neatly without sticking out. I will also list the part numbers as a convenience to anyone checking out this thread.
Thanks for posting the part #'s and the price. I couldn't find a counter sunk plug the day I looked, but that would work very well too.
You can get away with the 3/4 on the sensor because it's not torqued down very tight. If you use one a 3/4 socket on the lug nuts or something torqued down a little tighter it could round off the bolt or nut. I always go with the correct size, but my OCD won't let me do anything else. :)
JBotone is offline
Old 01-19-2012, 05:16 PM   #10
runun
runun's Avatar
Fan#: 57192
Haha, yeah my OCD restricts me on a lot of things, too. However, I have an adjustable wrench with metric on one side and standard on the other. When I set the metric side to exactly 19mm the standard side says exactly 3/4 inch. So of the few intersections between metric and standard, I believe this to be one of them.
runun is offline
