Alarm going off, windscreen wipers juddering, interior lights flashing. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2011, 06:20 AM   #1
Larryevans81
Fan#: 89567
What I Drive: 2005, Blue, Focus Zetec
FF Reputation: 1 Larryevans81 Good Standing Member
Hi,
New to this and not an expert on cars, so was wondering if anyone can help.
I have a 1.6 Ford Focus Zetec 55 plate, approx 60,000 miles.
Last night, at 12:30 am, my car alarm suddenly started to go off. Went outside as thought someone had broken in. No sign of a break in, all I saw was the windscreen wipers in a working position, so switched the alarm off and went back to bed.
Alarm went off again, turned it off and looked inside. Could hear a ticking sound from the fuse box, some of the interior lights kept flashing quickly, windscreen wipers juddering, indicators going off. When I turned the ignition, it stopped, car was running fine. Took it for a quick spin, stopped the engine, turned the ignition off, everything started flashing again, setting the alarm off. Eventually, just unplugged the fuse box and went to bed.
It was raining when I drove back last night before this all happened. Spoke to one of my friends who said that he had something similar.
Anyone ever experienced this, or heard about it, and how do i go about fixing it?
Larryevans81 is offline
Old 09-06-2011, 12:44 PM   #2
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Originally Posted by Larryevans81 View Post
Hi,
Hi Larryevans81,
Wow, it must have been quite irritating to have the alarm repeatedly going off! I'm not a technical expert either, but I can recommend visiting your dealer, as they are the experts on your Focus. Electrical concerns can be difficult to diagnose, and they have the right tools for the job, so they can ensure your peace and quiet. Have a good day!
~Natasha
FORD SERVICE
p: 800.392.FORD
FordService is online now
Old 09-06-2011, 12:55 PM   #3
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
don't go to your dealer... people on here can help you.
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 01-27-2013, 05:46 AM   #4
David030454
Fan#: 109134
What I Drive: Silver focus c-max
FF Reputation: 1 David030454 Good Standing Member
Hi,
I believe your problem is the battery, I have a focus c-max and have had this problem before and was told that it is a typical warning with Focus cars hat your batter is knackered
David030454 is offline
Old 01-27-2013, 12:09 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
Check the negative battery terminal wires- not the big one, but the little ones, remove those from the terminal, and make sure that the ring connectors (if yours uses rings) are not cracked and are complete. This is hard to see unless you remove those. Then also check the termination on the chassis and wiring harness. You have a bad ground somewhere and those circuits are finding a ground through the alarm system. This is setting the alarm off- because it senses voltage, and allowing those other circuits to work- although at lower voltage because of series resistance.
I had something similar happen in my car- fortunately I'm an electrician- and the small negative wires at the battery terminal that make the chassis ground connections were the problem. One of those had a cracked ring terminal that looked like it was connected until I removed it and it fell apart. My case was different because it required the key to be turned to ACC or ON- then the radio came on full blast, the wipers came on high, and something else happened that I can't remember right now. I was able to repair the problem in about 5 mins from when it happened, but like I said, I'm an electrician so I have handy access to ring terminals, strippers (female kind too ), and crimpers.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
