2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 82 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-20-2012, 01:13 AM   #811
Lipshurt
Fan#: 92314
What I Drive: 2012 blue focus SE
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 2 Lipshurt Good Standing Member
So could they see anything wrong with the mount? Or did they just wing it to see what would happen?
I suspect that mine is a combination of strut and mount, simply because, one the engine gets good and hot, like at least 30 minutes, the noise is improved, but not eliminated. That means that something is changing with heat.
Lipshurt is offline
Old 07-20-2012, 08:04 AM   #812
MMarchand
Fan#: 88649
What I Drive: 2012 Tuxedo black Titanium
FF Reputation: 1 MMarchand Good Standing Member
Same clunking/cracking problem here. It is worse if there is passenger in the car. I have the early production ( may 2011). I'm glad that there is a TSB out for this. I will take an appointment with dealer soon for this annoying rattles.
MMarchand is offline
Old 07-20-2012, 08:59 AM   #813
smizak
Fan#: 92058
What I Drive: 2012 Black SEL
FF Reputation: 2 smizak Good Standing Member
Originally Posted by jrn146 View Post
I had the tsb parts replaced today and there's no change in the noise. The service manager said there's nothing more that can be done until Ford comes up with something so it looks like we're on our own. If anyone comes up with a bearing or spring that resolves the noise please post part numbers.
Could you post the part numbers that were installed so we can compare? The TSB took care of the noise in my car for now. Weird.
smizak is offline
Old 07-20-2012, 11:41 AM   #814
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
They are putting the same parts back in to fail again sometime down the road.
Originally Posted by Zillon View Post
The Mazdaspeed3 mount is the same. Already researched.
Any aftermarket MS3 mounts? I could search for a maybe, but you might know for certain.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 07-20-2012, 01:02 PM   #815
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Sure, if you want to go with pillowball mounts, which will lead to noise later on as they wear.
The one aftermarket strut bearing I have found is a Febi/Bilstein unit for the Volvo C30. See HERE.
Technically, it should fit our cars. Not sure about reliability/quality, though. Still looking into that.
Joined the dark side.
Zillon is offline
Old 07-20-2012, 02:56 PM   #816
FGLLMX
Fan#: 98526
What I Drive: 2013 Audi A1 Ego 1.4TSFI S-Tronic
FF Reputation: 1 FGLLMX Good Standing Member
The old mount looked ok, the Service mgr. mentioned that they had performed some sort of test and it seemed the powertrain range of movement was excessive at the mount which is why they ordered the part.
When they removed the old mount, I took it and I moved the attachment points (at chassis and engine) simply by hand I could easily notice that it was very soft and also that the movement range seemed to be excessive. Before the new one was installed, I compared them and the new one was noticeably harder to move and its range of movement was a lot smaller.
The service manager (this is a small faciilty, part of a large Ford dealer in town) mentioned that they had successfully replaced 3 of these mounts already and such replacement has been under FORD Mexico approval. It seems the rubber component or whatever substance it may have inside softens to a degree that it no longer absorbs/limits the powertrain rapid movements from certain road shocks causing "this" noise. I may add that the car is now very smooth, previously some engine vibrations were felt while stopped in "D", well not anymore.
I told the guy that we will have to wait and see if this new mount was the final answer and if it will keep in shape for a long period of time.
I liked that he is very proactive and that he mentioned that he will be attentive to any Ford notice on other new developments in this issue.
FGLLMX is offline
Old 07-20-2012, 04:04 PM   #817
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
Like I have said before, hopefully the ST uses the same mount. Aftermarket support should follow, as Ford will probably sell more then Volvo and Mazda combined.
Hatch Nation#163
Watch out for the D
TiStick is offline
Old 07-20-2012, 04:21 PM   #818
Shantheman2012
Shantheman2012's Avatar
Fan#: 98655
What I Drive: Fmr: 2012 Ti Sedan Now: '13 Taurus
FF Reputation: 2 Shantheman2012 Good Standing Member
I'm going to pick mine up in a few minutes here. The service manager said mine falls under the TSB addressing this issue. So he is ordering the parts and I'll have to take it back when they are in.
I agree with what others are saying...if they are the same defective parts...we're just buying a little time til it returns.
I'll keep you all posted.
2012 Ingot Silver Ti Sedan
Former: 2005 Focus Hatch SES, 2004 Mazda3 5door, 2001 Focus Hatch ZX3
"Son, your ego is writing checks your body can't cash..."
Shantheman2012 is offline
Old 07-20-2012, 05:01 PM   #819
Lipshurt
Fan#: 92314
So when the dealer does a job like this, can we get the old parts? Or do the go to ford somewhere? I'd like to at least take pictures of the surfaces that been in contact to see if there is any wear or evidence of a bad fit etc.
I have an appointment at a different dealer, in Escondido ca, this time. I told the regional rep "Brian" that I want better treatment than I got from North County Ford in vista ca.
We will see I guess. Crossing my fingers
Lipshurt is offline
Old 07-20-2012, 07:01 PM   #820
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
So when the dealer does a job like this, can we get the old parts? Or do the go to ford somewhere? I'd like to at least take pictures of the surfaces that been in contact to see if there is any wear or evidence of a bad fit etc.I have an appointment at a different dealer, in Escondido ca, this time. I told the regional rep "Brian" that I want better treatment than I got from North County Ford in vista ca.
If you pay for it, you get the parts back. If Ford pays for it, they get 'em. If you ask the tech, he may let you see them. But, I'm fairly certain they aren't supposed to. Best bet, play dumb. "Hey buddy, what did those upper mounts look like when they came out?"
Hatch Nation#163
Watch out for the D
TiStick is offline
