2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 34 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2012, 05:38 PM   #331
Crypticracer
Crypticracer's Avatar
Fan#: 95672
What I Drive: 12' Sterling Grey Titanium Hatch
FF Reputation: 1 Crypticracer Good Standing Member
Took my Ti into the dealer this morning for the wiper and trans recalls. Also had them repair my headliner noise as well said I heard a slight noise up front at low speeds. They called me back telling me that they are going to replace all the front suspension, they told me they know of a problem with the struts so I said fix it. Ill get the car back this Friday, keep you all posted
Sent from my Desire HD using FF Mobile
Mike
12' Ti Hatch - DD
05' Chevy Tahoe z71 - Wifes Rig
72' 440ci Dodge Dart - Street/Strip
69' Ford F250 4x4 - Camping/Hunting Rig
Crypticracer is offline
Old 05-30-2012, 06:01 PM   #332
fcbaldwin
Fan#: 97264
What I Drive: 2012 Ingot Silver Titanium HB
FF Reputation: 1 fcbaldwin Good Standing Member
Holy Moly! Can't wait to hear how it goes for you.
fcbaldwin is offline
Old 05-30-2012, 07:23 PM   #333
HornedFrog05
HornedFrog05's Avatar
Fan#: 97892
What I Drive: 2013 Tuxedo Black ST2
FF Reputation: 6 HornedFrog05 Good Standing Member
Had it done. Sounds better for a couple weeks then gradually worse. I'll keep my fingers crossed for you!
HornedFrog05 is offline
Old 05-30-2012, 07:25 PM   #334
Crypticracer
Fan#: 95672
What exactly did they change? Just the struts?
Mike
12' Ti Hatch - DD
Old 05-30-2012, 07:25 PM   #335
HornedFrog05
Fan#: 97892
Originally Posted by TboneZX3 View Post
It's not likely that the Mazda "rear engine mount" (actually a roll restrictor) will fix your issue. The roll restrictor only limits the roll of the engine fore/aft, it doesn't support the weight of the engine. If that part was bad, you would have a loud knock during acceleration/takeoff and deceleration, not going over bumps.
Just a shot in the dark. I'm trying so hard to figure out what's rattling in there, it seemed like the engine was a good culprit. There's so much extra space in the front end, so frustrating. Thanks though, saved me $50 and 30 mins of install time.
Old 05-30-2012, 07:40 PM   #336
HornedFrog05
Fan#: 97892
Here's what the service work sheet says from the first time it was in the shop for the noise:
"Customer states there is a rattle noise in front suspension when going over bumps 20mph and under mostly:
TSB 11-11-2
5310/CC07
111102B 2.1
111102C 1.5
Verified concern. Pinpointed noise to both front strut assy. Replaced both front strut springs and strut bearings per TSB. Checked caster, camber, and toe. Test drove to verify repair. Ok..."
This time the sound went away for a couple weeks then came back.
Then I took it back (it was in the shop for 21 days) and this is what was done and said on the sheet:
"Customer states there is a rattling noise at front sups at any speed bumps. Test drove to verify concern. Contacted tech line for known concerns. None present. Peformed abnormal noise diagnosis, pinpointed noise to from t struts. Replaced both front struts. Test Drove. Some noise still present. Performed further diagnose. Replaced both front sway bar links. Test. Drove. Some noise still present. Test drove two other vehicles same year/model, same noises present. Normal characteristic to vehicle..."
When I got the vehicle back it was the same as when I took it in the shop. Now you can see why I'm frustrated and why I have a strong distaste for Ford at this time.
I recently took it back to a different dealer to get my rear seat replaced (part is on order) and they told me that everything looked ok in the suspension and that it's just a characteristic of the vehicle. (horse shit, you've been manufacturing cars for over 100 years and this is the best you've got?)
Ford CSM, where's a reply to that?
Old 05-30-2012, 07:49 PM   #337
HornedFrog05
Fan#: 97892
What about a side engine mount?
Old 05-30-2012, 07:57 PM   #338
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
I might be onto something here...
I will need to remove my struts and re-align my strut bearings to test it, though. Not sure when I'll be able to get the car up on a lift to do this.
There's a nub on the spring side of the strut bearing that needs to be lined up with the very end of the coil spring. If this isn't lined up, according to Mazda3 and C30 owners, it will cause a clunking that I imagine is very similar to ours because the strut bearing is unevenly loaded.
Mine currently aren't lined up, and my passenger side is further out of alignment than my driver side. Granted, I've replaced my springs myself and failed to note the position of them when I disassembled the factory setup, but I have a strong feeling this could be the culprit.
It's easy to check, if you know what to feel for.
Joined the dark side.
Zillon is offline
Old 05-30-2012, 08:28 PM   #339
Crypticracer
Fan#: 95672
^^ makes sense to me
Mike
12' Ti Hatch - DD
Old 05-30-2012, 09:06 PM   #340
HornedFrog05
Fan#: 97892
Zillion,
I filled out the google docs survey. Hopefully that will help.
