2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 32 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 05-24-2012, 10:22 AM   #311
FGLLMX
Fan#: 98526
What I Drive: 2013 Audi A1 Ego 1.4TSFI S-Tronic
FF Reputation: 1 FGLLMX Good Standing Member
The noise is completely gone in mine. However, at the time of the body adjustments, I only had put about 200 miles on the Focus, mostly driving alone, so I donīt know if a passenger would have changed the situation. If anything changes in the comming miles I will post it.
Good luck!!!
FGLLMX is offline
Old 05-25-2012, 10:24 AM   #312
HornedFrog05
HornedFrog05's Avatar
Fan#: 97892
What I Drive: 2013 Tuxedo Black ST2
FF Reputation: 6 HornedFrog05 Good Standing Member
Took my vehicle into a different dealer and they told me, "nothing seems to be wrong in the front-end where the replacement parts were installed, this might just be a characteristic of the vehicle."
UNACCEPTABLE! I F-ING HATE FORD!!!!
HornedFrog05 is offline
Old 05-25-2012, 07:23 PM   #313
12FOCUS S
Fan#: 98622
What I Drive: '13 FOCUS ST/'12 Mustang GT BBP
FF Reputation: 1 12FOCUS S Good Standing Member
Question
I have yet to receive a response as well. I sent the requested info 5/14 via PM. The shock and/or shock mounts are suspect as well with rattle over certain road surfaces. The EPAS system needs constant correction required driving down a new Tollway here in Texas. Cross winds play big time in the required constant correction factor.
The front rattles on undulated surfaces like it has 60,000 miles. This vehicle has less than 1500 miles........
12FOCUS S is offline
Old 05-27-2012, 01:39 PM   #314
Lipshurt
Fan#: 92314
What I Drive: 2012 blue focus SE
FF Reputation: 2 Lipshurt Good Standing Member
Mine has been getting worse, but only for about he first 20 minutes of driving.
That should be a huge clue right here.
So this week I washed it twice, and after each wash the noise was very prominent, even though it was pretty much gone going to he car wash because of driving for about two hours. So then yesterday I sprayed the wheels with water, and that made the noise very prominent and very often.
So I started kicking the wheels (done this many many times over the last few months!) and found a way to kick the wheel which makes the rattle happen loudly and really rattle-ey.
Seems like it should be really easy to locate the sound when you can just make it happen.
It's coming from an area slightly behind the wheel, and slightly inboard... At least I think so!
I'm gonna get my stethoscope and isolate it.
It's not struts, or any other other major piece of the suspension, that is why the techs can find it. Cooling off the wheel helps to loosen up the sound though, so maybe some of us should try that and see if this applies to other cars as well.
Lipshurt is offline
Old 05-27-2012, 01:42 PM   #315
Lipshurt
Fan#: 92314
Oops I forgot to say how I make my sound happen every time......
I have the sport wheels, and if I kick with my heel downward on the spoke with is horizontal and pointing forward the sound rattles big time. Kicking the tire or wheel kind of hints at he sound, but does not get a nice long rattle
Lipshurt is offline
Old 05-27-2012, 05:49 PM   #316
Dysan911
Fan#: 95746
That might just be the Brake Calipers right? have someone light hold the brake pedal down while you kick the wheel and see if the sound still occurs.
Dysan911 is offline
Old 05-27-2012, 06:10 PM   #317
Lipshurt
Fan#: 92314
Nope it does it when braking or not braking. I insulated the caliper with rubber and felt. Plus the sound is not coming from there.
There are a lot places where it could be. I have not had anyone to help me with his today, but probably tomorrow I can. It will take two people of course, one the make the sound while other finds the sound.
My feeling now is that it's between two parts that should or be touching, not between two parts that do not touch tightly enough. The sound is at a frequency of about 16th notes at 160 beats per minute (I'm a musician:) which means the parts have to be moving about a 16th of an inch, and under not very much tension. Gut feelings of course:)
Lipshurt is offline
Old 05-29-2012, 09:10 AM   #318
Dysan911
Fan#: 95746
Any further luck with this Lipshurt?
Dysan911 is offline
Old 05-30-2012, 05:32 AM   #319
fcbaldwin
Fan#: 97264
What I Drive: 2012 Ingot Silver Titanium HB
FF Reputation: 1 fcbaldwin Good Standing Member
I did some fine tuning (fiddling) with the hood stops. I tried to raise them up just enough so that when the hood is closed, it is supported snugly by the rubber on top of the stops. Maybe it's wishful thinking, but the car seems not to clunk now. One problem that I see with these stops is that they seem to be loose. Is there a way to "lock" them in place after you get them adjusted?
fcbaldwin is offline
Old 05-30-2012, 05:40 AM   #320
MKorn
MKorn's Avatar
Fan#: 97610
What I Drive: 2012, SE, Sport, 5MT, Hatch -Silver
FF Reputation: 1 MKorn Good Standing Member
Maybe a dab of silicone!?!?
MKorn is offline
