#1911 | ||||
Sonic Crew # 010
Sonic Crew #10 Shade|Sedan Revolution #250|Rally Revolution #27 2012 Ford Focus SE Sport-5 speed-203A package-155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter. 1954 Ford F100 - Shop truck in process Rebel Devil |
| Sponsored Links | |||
Advertisement | |||
#1913 | ||||
Really? Zero play? That does make sense.
Mine you can move about .030 or more (1/32 inch) and they make sound. I'm taking about lengthwise side to side. Not a twisting kind of play. So in other words you can move then toward the wheel and away from the wheel, and that makes sound when it hits the end of its travel in each direction. Somebody else here said theirs does that too. |
#1914 | ||||
Sonic Crew # 010
#1915 | ||||
the up/down play would only be due to the play in the spring as it is unloaded (just look and you'll be able to see if the spring is causing the play or not or slightly load the spring and see). the axles/shafts/cv themselves should NOT have ANY play (they shouldn't wiggle at all), they should only rotate. |
#1916 | ||||
The play is on the axis parallel to the shaft. Parallel to the centerline of the shaft actually.
So not up/down not forward/back Not twisting Only inboard/outboard. Both sides do it. |
#1917 | ||||
why else would 2012s have different part numbers than 2013s? everything else related to steering/suspension/handling seems to match up between '12 and '13 besides the spring. Front Spring BV61-5310-NF* Left Front Coil, BV61-5310-NF* Right Front Coil (Front) $28.87 Vehicle Build Date between: 3/29/2012 and 12/5/2012 5310 Front Spring BV61-5310-NG* Left Front Coil, BV61-5310-NG* Right Front Coil (Front) $28.87 Vehicle Build Date between: 3/27/2012 and 12/5/2012 5310 Front Spring BV61-5310-NF* Left Front Coil, BV61-5310-NF* Right Front Coil (Front) $31.60 Vehicle Build Date after: 12/6/2012 5310 Front Spring BV61-5310-NG* Left Front Coil, BV61-5310-NG* Right Front Coil (Front) $31.40 Vehicle Build Date after: 12/6/2012 |
#1918 | ||||
Joined the dark side. |
#1919 | ||||
here you go: ![]() regardless, it still doesn't answer why the 12s have different axles/cvs compared to 13s. |
#1920 | ||||
Zillion is 100% correct ... otherwise it would rip the halfshaft out of the trans as it moved up and down with the bumps in the road.
Every halfshaft I've ever seen has that lateral play. REV |
| Thread Tools | |
| Display Modes | |
