2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 191 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 01-25-2013, 04:28 PM   #1901
Dysan911
Fan#: 95746
Originally Posted by thejordan View Post
if the bushing is too thin or the bolt hole too wide, i could see it being a suspect. you'd have to measure the bushing dimensions and call around to find an aftermarket one to fit in (or cut one to size).
if you jack up the car on one side and try to shake the wheel, it should be reproducible. it's the same trick when checking the wheel bearings.
Agreed. I am curious what the LCA bushing setup looks like on the ST.
2012 FF Ti HB Platinum White Tricoat, Built 12/11, 401A + Parking Technology Package and MFT w/NAV at 3.5.1
Dysan911 is offline
Old 01-25-2013, 04:30 PM   #1902
Dysan911
Fan#: 95746
ST suspension walk around.
http://www.edmunds.com/car-reviews/t...alkaround.html
Dysan911 is offline
Old 01-25-2013, 04:33 PM   #1903
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 974, Level 16
Points: 974, Level: 16 Points: 974, Level: 16 Points: 974, Level: 16
Level Up 74% Completed
FF Reputation: 4 thejordan Good Standing Member
ST is a few hundred pounds heavier, so I imagine the components are beefier. A bad bushing could lead to it shifting front/back in the bushing (ex: when hitting a driveway dip). Ball joints also demand suspicion. Not sure if the Focus has greased filled ones or not.
thejordan is offline
Old 01-25-2013, 04:37 PM   #1904
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,235, Level 35
Points: 3,235, Level: 35 Points: 3,235, Level: 35 Points: 3,235, Level: 35
Level Up 24% Completed
Forum Activity 28%
Activity: 28% Activity: 28% Activity: 28%
Originally Posted by Dysan911 View Post
Cory, Thanks but I'm not sure if you realize I've already taken my car into my local dealer's service dept and they've made an attempt to repair it already. When I told them it didn't fix the issue I got told basically that they want to see I'm completely satisfied and that I have plenty of warranty left, they will talk to the technician who worked on my car and get back to me...
Dysan911,
Ah, thanks for the update. It sounds like they’re getting to the bottom of it for you.
Cory
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 01-25-2013, 05:10 PM   #1905
Dysan911
Fan#: 95746
This is regarding the rear LCA bushing on the ST.
The bigger and more visible one at the rear is primarily tasked with handling acceleration and brake torque reactions and the fore-aft component of pothole strikes. Such a load entering at the ball joint is turned through 90 degrees by the L-shape of the arm so it can be absorbed in the rear bushing as an inward force. Here in the ST this bushing is firmer than the base car because of the ST's much greater acceleration and braking potential and a somewhat lessened need to deliver a plush ride.
Dysan911 is offline
Old 01-25-2013, 05:21 PM   #1906
Dysan911
Fan#: 95746
Originally Posted by FordCustomerService View Post
Dysan911,
Cory
Oh yeah. They just called me and gave me the official "At this point we've done all we can and will have to wait for the Engineers to give us a resolution".
Also I was told that my first repair was after all BOTH SIDES!. So all this time I thought this was just the left side coming due for the issue. Its actually not the case. I wondered why the parts on the first repair were in quantities of 2 and this time half the items were replaced.
Dysan911 is offline
Old 01-25-2013, 05:26 PM   #1907
BlazeFocus
BlazeFocus's Avatar
Fan#: 104991
What I Drive: _
FF Reputation: 2 BlazeFocus Good Standing Member
There's your sign..
BlazeFocus is offline
Old 01-25-2013, 09:49 PM   #1908
Lipshurt
Fan#: 92314
What I Drive: 2012 blue focus SE
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 2 Lipshurt Good Standing Member
Not sure about you guys, but my sound is such that it is loudest when the car is stressed the least. Like when it is coasting over really small bumps at very low speed. It also does it when shifting suddenly, or suddenly letti g out the clutch when coasting. That points toward mounts maybe. It does it while accelerating and also while braking and turning or not turning.if it were the bushings then it would mainly do it when the car is stressed....right?
My sound is for sure the sound of something that is loose. As it gets warmed up that sound becomes tighter until it goes away completey. It's its 45 degrees outside it does not go away completely.
After many times poking around under the only things that make the sound that I have found so far are: (and these are not the problem as determined by insulating them)
1) the hood prop rod
2) the manual shift lever at a the top of the tranny. The one with he counterweight. When you jiggle up and down its the EXACT same sound. Hard to insulate it though so maybe I did not do a good job of insulating it. My mic did not pick it up though even when I put the mic right next to the lever.
3) the battery cover. Removing all the battery cover pieces did nothing
4)the hood it self. I put rubber all around the hood and it was quiet as can be when tapping all around the hood.nitbhad no effect on the noise. I really thought that was it though for about a half hour:)
5) the front license plate...nope
The only thing I've found that makes he sound and I have NOT ruled out is the play in the driveshafts/cv joints. Jiggling those side to side makes the exact same sound. How would those respond to heat? My thinking is that they wound heat up slow, cuz they get heat from the ends of the shafts. From both ends (brakes and tranny). That would explain how long it takes for the sound to go away when heating up. It also explains the fact that when it is making the sound I seem to be able to feel play in the wheels, or get the vibe that the wheels are loose.
This week I drove my old 2001 jetta that we still have in the family, and it has almost 300 THOUSAND miles, on all the original suspension pieces, and that thing is tight as a drum and silent in the front. I'm gonna jiggle the driveshafts on it. If they jiggle back and forth, then that theory get dumped:)
I'm pretty relaxed about the noise now, in my mind I have concluded that its a minor thing, but one that shold be fixed. I have spent many hours on it. No money so far though:)
I found a set of chassis ears for 120 bucks......tempting
Lipshurt is offline
Old 01-25-2013, 10:08 PM   #1909
thejordan
thejordan's Avatar
Fan#: 107706
Wait, your axles should have 0 play in them... they should only rotate, not wiggle. This may suggest center diff problems or some other onslaught.
The cv boots are loaded with grease, this heats up as use increases.
Old 01-25-2013, 10:16 PM   #1910
thejordan
thejordan's Avatar
Fan#: 107706
EDIT: comprehensive list, refer to all TX-____ part numbers.
apparently they are different part numbers for 2012 models and 2013 models.
2012 models:
3B436
(TX-565)
CV Joint Axle Shaft Assembly
5-Speed Manual Trans - MTX75 ; RH
$276.80
Vehicle Build Date before: 12/14/2011
3B436
(TX-566)
6 Speed Auto Transmission DCPS ; RH
$266.38
3B436
(TX-639)
$223.38
Vehicle Build Date after: 12/15/2011
3B436
(TX-640)
$222.06
3B437
(TX-568)
5-Speed Manual Trans - MTX75 ; LH (Left)
$179.06
Vehicle Build Date before: 12/15/2011
3B437
(TX-569)
6 Speed Auto Transmission DCPS ; LH (Left)
$182.46
3B437
(TX-641)
$144.36
Vehicle Build Date after: 12/16/2011
3B437
(TX-642)
$147.16
2013 models:
3B436
(TX-565)
$276.80
3B436
(TX-566)
$266.38
3B436
(TX-639)
$223.38
3B436
(TX-640)
$222.06
3B437
(TX-568)
$179.06
3B437
(TX-569)
$182.46
3B437
(TX-641)
$144.36
3B437
(TX-642)
$147.16
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
