2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 152 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-06-2012, 07:00 PM   #1511
theshrewz
Fan#: 103228
What I Drive: 2012 Silver Se Focus
Points 2,185, Level 28
Points: 2,185, Level: 28 Points: 2,185, Level: 28 Points: 2,185, Level: 28
Level Up 24% Completed
FF Reputation: 2 theshrewz Good Standing Member
Gonna be swappin bolts like Zillion tonight and seeing how that works, Have new strut tops and bearings as well if the bolts and re aligning the struts doesnt solve the issue.
I had a theroy that torqueing to the higher numbers might be crushing the bearigs and casuing the creaking so Im gonna torque the better bolts to stock numbers and see if that helps if not try out Zillions 35-37 Ftlbs torque specs.
FINGERS CROSSED
theshrewz is offline
Old 11-06-2012, 07:21 PM   #1512
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Originally Posted by zx3matt View Post
Thanks. I kind of figured that. Couple more questions... I am getting wider tires soon, so what size did you end up with and what offset on the wheels? I am thinking either 225/50/17 or 235/45/17 on my Drag wheels (17x7.5").
I'm on 18x8 +45 wheels with 235/40 tires. From a driving standpoint, I kind of regret not going with a proper 17x8 wheel with a 235/45. I might be considering selling them in the spring, they're too form > function for me. But damn, they really do look good.
I'd go with 235/45s. Right diameter, and less sidewall.
Anyways, back on topic.
Shrewz, the bearings themselves aren't held in place by the strut mount bolts, so while the additional torque might be causing my occasional creaking, it's not from the bearings binding. The bearings are actually held in place by the tension provided by the compressed coil. You are using the OEM bolt spacers for your install, right? Washers will collapse into the holes in the strut towers.
Let me know what you find after the install.
Joined the dark side.
Zillon is offline
Old 11-06-2012, 11:36 PM   #1513
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,652, Level 97
Points: 26,652, Level: 97 Points: 26,652, Level: 97 Points: 26,652, Level: 97
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 9 TORQUERULES Good Standing Member
Just hope my +42 offset will not be too much.
TORQUERULES is offline
Old 11-06-2012, 11:44 PM   #1514
Zillon
Zillon's Avatar
Fan#: 17393
On 17x7.5 wheels? Nah. Your wheels will actually sit in 3mm further than mine; you'll have plenty of clearance for meaty tread.
Zillon is offline
Old 11-06-2012, 11:44 PM   #1515
theshrewz
Fan#: 103228
Well I upgraded and Swapped all the strut bolts and Just torqued them to 35 ftlbs and It didn't make the creaking go away :( the never ending quest to fix this damn issue.
I just used 6 washers under the bolts I used to make it the same height as the stock bolt.
I totally spaced and didn't try this set up with stock Torque, Im kinda over it but I really hope ford fixes this some how.
I really think Steeda or some company could make a better strut topper with a sealed bearing and it solve this issue and WED ALL buy that in a heartbeat. For now I turn the radio up a little louder so I don't notice it.
Untitled by theshrewz, on Flickr
I got My Steeda CAI and short throw and my ST wing in today so I installed the CAI to make me feel better ahha.
It looks red cause I oiled it with the K&N Oil my dad had left over from his filter he has on his Mustang
Old 11-07-2012, 12:36 AM   #1516
Zillon
Zillon's Avatar
Fan#: 17393
I just found this.
TSB: 02-11-04
2010-2012 MAZDASPEED3 - SQUEAK OR KNOCK NOISE FROM FRONT STABILIZER
APPLICABLE MODEL(S)/VINS
2010-2012 Mazdaspeed3
DESCRIPTION
Some vehicles may exhibit a squeak or knock noise from the front end of the vehicle when passing over a bump. This is caused by dust entering between the stabilizer bar and stabilizer bushing and damaging the coating applied to the bushing, resulting in excessive clearance.
To stop the noise, the left and right front stabilizer bushings are replaced with new ones and dust covers with bands are installed.
2010 Mazda 3
TSB: 02-10-05
2010 MAZDA3 - KNOCK / CLUNK NOISE FROM FRONT WHEN GOING OVER BUMPS
2010 Mazda3 vehicles with VINs lower than JM1BL336667 (produced before June 1, 2010)
DESCRIPTION
Some vehicles may experience a knock / clunk noise from the front of the vehicle when going over bumps. Typically the noise occurs at the right front of the vehicle with only the right front tire. Due to the impact while going over bumps, a vertical force is applied to the crossmember through the stabilizer which causes crossmember movement on the bushing. This movement is caused by the change of the surface characteristics of the bushing during hot ambient temperatures in summer. Less holding force during cold temperatures results in movement and stick-slip noise at the bushing (A) near the front (F) of the front crossmember. The bushing is now modified to reduce the movement.
NOTE: This concern is best duplicated with cold ambient temperatures below 12.8 degrees C (55 degrees F). Once the vehicle has warmed up, the concern may be difficult to duplicate.
2007 - notes this
MTOL -07/06
MAZDA3, MAZDASPEED3, MAZDA5, MAZDA6-“POP!” NOISE FROM COWL OVER BUMPS
Concern:
Some customers may complain of a ‘POP!’ noise that is heard in the front of the vehicle, particularly when going over large bumps. The noise comes from the under the hood in the upper front strut tower area, and can easily be mistaken for a front suspension noise. Upon further investigation, the front suspension components are not the cause of the noise.
Contact and movement between the cowl panel and the vehicle body may be the cause of the noise and the mounting bolts for the cowl panel need to be re- torqued .
Veddy interesting.
Zillon is offline
Old 11-07-2012, 12:42 AM   #1517
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
What I Drive: 2012 Ford Focus SE Sport - 5 Speed
Points 15,443, Level 80
Points: 15,443, Level: 80 Points: 15,443, Level: 80 Points: 15,443, Level: 80
Level Up 19% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 10 Shade-010 Great Standing Member
Things to make you go hmmmmmmmmmmm?
2012 Ford Focus SE Sport-5 speed-203A package
Basline 1 -155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter.
Dyno 4 -177.17 hp 157.28 tq - 93 oct. RDC 2.5" Catback & RD-X Prototype CAI + Tune.
http://www.rebeldevil.com
Shade-010 is online now
Old 11-07-2012, 04:23 AM   #1518
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,152, Level 96
Points: 26,152, Level: 96 Points: 26,152, Level: 96 Points: 26,152, Level: 96
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
So we're back to the sway bar, but at the frame mounts-not the endlinks...interesting indeed.
It would kind of explain why the noise disappears for a bit after unloading the suspension, though I'm curious as to how they would be covering them with dust boots.
I guess I will go back up on the jacks tomorrow...
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 11-07-2012, 07:33 AM   #1519
Zillon
Zillon's Avatar
Fan#: 17393
Well, the creaking I have, I believe is linked to the sway bar bushings. Easy fix, generally speaking.
The clunking, though, could just be the subframe bolts/isolators, which was a thought of mine a long time ago.
Certainly not a cheap issue to take care of, though; the isolators are 20-30 bucks each. And there are 4 of them. Bolts are at least cheap, though.
However, for those who claim the strut bearing/strut mount/spring/strut replacement did nothing, I've seen nothing said about checking the subframe connections to the chassis.
Zillon is offline
Old 11-07-2012, 09:15 AM   #1520
TORQUERULES
The Professor
Fan#: 1083
That's what I wanted to hear.
