2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 150 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 11-04-2012, 05:48 PM   #1491
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
What I Drive: 2012 Ford Focus SE Sport - 5 Speed
FF Reputation: 10 Shade-010 Great Standing Member
Originally Posted by Zillon View Post
Well, preliminary verdict is that this works, and it's safe.
I cut the heads off of the factory bolts to salvage the spacers and drill them out to fit the 12.9 grade bolts.
I ended up using a 5/16" carbide bit, with a second person dripping cutting oil around the bit, to drill them out. The spacers are hardened, so beware. They will take some work to ream out to the right size.
That's the final setup. I torqued them to 35 ft-lbs, and used a bit of anti-seize between the spacer and the bolt, to inhibit corrosion. I did not use anti-seize on the threads.
The only issue I seem to have is a little bit of groaning, but I think it's because I need to re-align the struts in the towers, which I'll do at work tomorrow.
Cool man, keep up informed.
2012 Ford Focus SE Sport-5 speed-203A package
Basline 1 -155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter.
Dyno 2 -161.86 hp 151.6 tq - 93 oct. RDC 2.5" Catback & K-N Drop in filter.
http://www.rebeldevil.com
Shade-010 is online now
Old 11-05-2012, 06:59 AM   #1492
quasireversible
Fan#: 105686
What I Drive: 2012 Ingot Silver SEL
FF Reputation: 1 quasireversible Good Standing Member
Checking in with the strut noise issue. I had the car fixed about a month ago and it reappeared gradually -- first as a squeak and now as a clunk.
I'm fairly disappointed as there is no fix currently (although the recent post gives some hope), but such is the deal with new model year cars I suppose.
quasireversible is offline
Old 11-06-2012, 08:31 AM   #1493
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 GTI
FF Reputation: 27 Zillon Great Standing Member
Well, I did some more tweaking last night in the shop - I replaced the 30mm bolts with 25mm bolts of the same grade, since there was a lot of excess bolt showing underneath the strut mount when I took a peek from below. I wanted to ensure that there would be no possible interference between the bolts and the strut bearing. I also realigned the struts in the tower.
Additionally, I bumped the torque spec to from 35 ft-lbs to 37 ft-lbs. This is my final torque revision; now I'll put some miles on the car and see how the setup holds up.
For now, I'd say this is a success. It may take a small bit of work to salvage the stock bolt spacers from the factory bolts, but if this holds up and keeps the clunking at bay, I'd say it's well worth the work.
The weather has also gotten much colder in the past few days, so I'm hoping that doesn't have much to do with my suspension being quieter. Regardless, I'll be sure to keep you guys updated on any developments.
Joined the dark side.
Zillon is offline
Old 11-06-2012, 09:08 AM   #1494
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Some people have heard it more in cold weather, and some in warm weather, I normally hear it all the time no matter the weather lol
Old 11-06-2012, 09:10 AM   #1495
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
FF Reputation: 9 TORQUERULES Good Standing Member
Originally Posted by suss6052 View Post
The Mazda 3 used the exact same parts and has the same risk for clunking, ZX3Matt's wife's 2012 3 was also experiencing the suspension clunk/ rattle or so he had mentioned a while ago before dropping off the forum for awhile.
Short of cross referencing a bearing size and load chart it would be hard to guess as to what bearings would work best in aftermarket situations.
SKF, INA/, and other bearing manufacturers may make something suitable, but its going to be hard to keep swapping parts until you find something that works. If its always just the one side is it really the bearing or something to do with that side of the car?
My wife's 3 clunks worse than my Focus.
TORQUERULES is offline
Old 11-06-2012, 09:11 AM   #1496
TORQUERULES
The Professor
Fan#: 1083
Well, I do happen to have my old bearings...
I'll pry one apart tonight, perhaps.
I have had mine apart. Not much there...
Old 11-06-2012, 09:13 AM   #1497
Zillon
Zillon's Avatar
Fan#: 17393
Nope, there really is not. I pulled mine apart accidentally when removing them from the strut shaft. Glad I had new ones ready to go on, because those ball bearings really do scatter everywhere.
Zillon is offline
Old 11-06-2012, 09:31 AM   #1498
TORQUERULES
The Professor
Fan#: 1083
LOL, yes they do. I had to replace a couple of mine with ones from a transmission repair kit I had. Much better quality I am sure.
It looks like I will be replacing the bolts.
How are the ST struts? Also, I thought you got ST shocks too?
Old 11-06-2012, 09:50 AM   #1499
Zillon
Zillon's Avatar
Fan#: 17393
ST struts are actually pretty good. I'm rather impressed so far; they are stiff, though. Paired with the Eibachs and the Koni Yellows in the rear, they handle very well.
The rear ST shocks ended up being too short for the non-ST rear suspension. Luckily Steve from Tousley was willing to work with me on returning those, given that I was the first to attempt a ST damper retrofit. Ford changed the rear knuckle for the ST; entirely different lower mounting point on the rear knuckles.
Let me know how your bolt replacement goes, I'm looking for input.
Zillon is offline
Old 11-06-2012, 10:20 AM   #1500
hand-filer
hand-filer's Avatar
Fan#: 90895
What I Drive: One less Ford
FF Reputation: 1 hand-filer Good Standing Member
My clunking stopped entirely about 1 week ago. This coincided with temperature drop which has been just above freezing.
2012 Mustang Brembo GT - Kona Blue
2013 Acura RDX - Alabaster Silver
hand-filer is offline
