2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 142 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2012, 09:31 PM   #1411
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
What I Drive: 2012 Ford Focus SE Sport - 5 Speed
Points 14,940, Level 79
Points: 14,940, Level: 79 Points: 14,940, Level: 79 Points: 14,940, Level: 79
Level Up 18% Completed
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
FF Reputation: 10 Shade-010 Great Standing Member
$13 bucks each for BOLTS? WTF? are they titanium bolts?
2012 Ford Focus SE Sport-5 speed-203A package
Basline 1 -155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter.
Dyno 4 -177.17 hp 157.28 tq - 93 oct. RDC 2.5" Catback & RD-X Prototype CAI + Tune.
http://www.rebeldevil.com
Shade-010 is offline
Old 10-29-2012, 09:36 PM   #1412
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,038, Level 66
Points: 10,038, Level: 66 Points: 10,038, Level: 66 Points: 10,038, Level: 66
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 24%
One time use item, safety/ steering/ suspension/ etc, idk, but still.
suss6052 is offline
Old 10-29-2012, 09:53 PM   #1413
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Forum Activity 43%
can we spec out a Grade 8 bolt to replace into it, or do they need to be stock bolts?
Old 10-29-2012, 09:56 PM   #1414
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
Without knowing the specs of the stock bolt I can't recommend changing them for something else that may not behave in the same manner when loaded or in the case of an accident.
suss6052 is offline
Old 10-29-2012, 10:51 PM   #1415
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Forum Activity 43%
Good point, they may have a shear spec in case front collision.
Old 10-30-2012, 03:25 PM   #1416
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by TboneZX3 View Post
I just performed the procedure, and I think you might be onto something Zillon. It's not quite cold enough here right now to be sure, but my initial impression is positive. I will report back with more definite feedback after a cold morning drive.
UPDATE:
After a few cold morning drives (below 35F), I can say that I have no strut noise. YMMV--mine had just started making some noise so my mount and bolts might be in better shape than those who have a more dramatic noise for a longer period of time.
Thankfully, I also got rid of my door rattles over the weekend so, except for a heat shield rattle that I will soon fix, my car is nearly quiet again.
Hatch Nation #90
TboneZX3 is offline
Old 10-30-2012, 03:56 PM   #1417
BlazeFocus
BlazeFocus's Avatar
Fan#: 104991
What I Drive: _
FF Reputation: 2 BlazeFocus Good Standing Member
UPDATE:
What was the nature of the heat-shield rattle?
BlazeFocus is offline
Old 10-30-2012, 03:59 PM   #1418
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
It's a bit hard to explain, but I'm not sure it would do any good to anyway, because I'm not 100% sure it's a heat shield. It has a tin pan-like quality, and it goes away very quickly as this warm up.
Hopefully I'll know more after looking at it this weekend.
Hatch Nation #90
TboneZX3 is offline
Old 10-30-2012, 06:36 PM   #1419
ChrisRyan
Fan#: 97815
What I Drive: '12 SE Sterling Grey(5door) 5M 203A
FF Reputation: 2 ChrisRyan Good Standing Member
Mine clunks hot, cold and in between. The left was the original culprit and now I hear the right chiming in. I am going to wait to see if Ford or an aftermarket bearing redesign comes to market. If not then I will replace with OEM mounting hardware/bearings with better springs and dampners. Mine actually sounds worse when it is cooler outside.
ChrisRyan is offline
Old 10-31-2012, 07:44 AM   #1420
Dann0
Fan#: 105476
What I Drive: 2011 Mk3 Focus Zetec 1.6 125
FF Reputation: 1 Dann0 Good Standing Member
MK3 Focus - Noise when riding over speed bumps?
Hi I have recently bought a used 2011 Mk3 Focus (1.6 125 zetec).
I have noticed that when riding over speed bumps/ramps (i always take them pretty slow :)) that there is a kind of crunch/scraping noise but i cannot identify what it may be. Although it does seem to be comming from the front of the car.
The car is in good condition and has done just over 4000 miles (bought used from Ford Dealership).
I have had a look under the car and cannot see what would be causing it, there is a cover underneath the engine bay but this does not seem to be loose as far as i can tell.
In all other respects the car drives and handles fine, the tyres are at the correct pressure also. My concern is there may be some sort of underlying issue with the suspension.
Has anyone else experienced this? If so did you manage to track down the casue?
Thanks for taking the time to read through...
Dann0 is offline
