2012 Titanium Front Strut Low Speed Noise (Clunk/Rattle) - Page 140 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2012, 10:37 AM   #1391
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
All good points. Thanks.
Hatch Nation #90
TboneZX3 is offline
Old 10-26-2012, 10:48 AM   #1392
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Absolutely! If I can help the community, I'm all for it.
I've been every bit as frustrated as everybody else with this issue, perhaps even more so.
Joined the dark side.
Zillon is offline
Old 10-26-2012, 02:53 PM   #1393
TiPilot
TiPilot's Avatar
Fan#: 93667
What I Drive: 2012 Ingot Silver Ti Hatch
FF Reputation: 1 TiPilot Good Standing Member
Originally Posted by Shantheman2012 View Post
Crap. Well...at least we can have each other's backs at the same dealer. This is unbelievable.
Yeah, I've just started to hear it again. I'll try and pay attention and do some slow-speed, parking lot turning/driving to confirm before I take it back in.
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg
Build Date: 12/2/2011 | New APIM: 4/4/2012
MFT: Factory v2.11, 3/14/12 Web -> v3.0.2, 9/24/12 Web -> v3.2.2, 1/24/13 Web -> v3.5.1, 8/13/13 Web -> v3.6
TiPilot is offline
Old 10-27-2012, 01:23 PM   #1394
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I just performed the procedure, and I think you might be onto something Zillon. It's not quite cold enough here right now to be sure, but my initial impression is positive. I will report back with more definite feedback after a cold morning drive.
This procedure is simple, and should be easy for anyone who has even minor wrench-turning experience and a torque wrench. The only difficulty I encountered was removing the wiper arms. No amount of wiggling is going to get mine loose. However, it is not a necessity--the cowl cover can be slid up over the arms and out of the way while the arms are in a nearly vertical position. If I do the procedure again, I will be sure to have a puller on hand.
Hatch Nation #90
TboneZX3 is offline
Old 10-27-2012, 02:10 PM   #1395
BlazeFocus
BlazeFocus's Avatar
Fan#: 104991
What I Drive: _
FF Reputation: 2 BlazeFocus Good Standing Member
Good feedback!
BlazeFocus is offline
Old 10-27-2012, 02:27 PM   #1396
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,282, Level 95
Points: 25,282, Level: 95 Points: 25,282, Level: 95 Points: 25,282, Level: 95
Level Up 94% Completed
Forum Activity 4%
I did the same thing this morning. I didn't remove the wiper arms or upper cowl, just slid a deep-well under it to do the work. Unfortunately, I didn't have perfect results but I can assure you that it is much, much better. Idk if putting 10k on the mounts being incorrectly aligned may have caused an issue, but I am going to end up replacing some parts anyways and maybe even trying the procedure again in 1k miles.
Before doing this, my front end sounded like it was going to literally fall apart on both sides (with the right being much worse). Now, the left clunk is gone and the right sounds like it did at about rhe 2k mile mark. I will probably drop both struts after trying this again and retorque the strut nut if the next attempt doesn't resolve it.
Hopefully this yields positive results on more vehicles. Thanks again for doing the leg-work, Zack
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 10-27-2012, 04:06 PM   #1397
Zillon
Zillon's Avatar
Fan#: 17393
Something else I'm going to try, is to see if the strut mount bolts and/or torque specs for the ST are any different, since I have not seen any complaints on either FocusST.org or FordSTNation.com regarding clunking/rattling/banging suspension yet.
I'm really glad that I've been able to help you guys out, even if it didn't entirely cure your issues.
Zillon is offline
Old 10-27-2012, 04:35 PM   #1398
hand-filer
hand-filer's Avatar
Fan#: 90895
What I Drive: One less Ford
FF Reputation: 1 hand-filer Good Standing Member
Zillion,
Appreciate your efforts and will give this a shot next weekend when I install my winter wheels. My only concern would be the ultimate yield strength of the studs.
Did you check the torque value before you loosened them? That to me would be of interest. I will check mine and report back what they were tightened to when my springs and bearings were replaced.
h-f
2012 Mustang Brembo GT - Kona Blue
2013 Acura RDX - Alabaster Silver
hand-filer is offline
Old 10-27-2012, 04:35 PM   #1399
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 4%
Silence>less clunk>lots'o clunk>what I freaking had
^^^Sound evolution. I am now at less clunk
Have any '13 non-ST owners been having the issue?
September '13 ROTM
2014 FiST-
Old 10-27-2012, 06:20 PM   #1400
Zillon
Zillon's Avatar
Fan#: 17393
Originally Posted by hand-filer View Post
Zillion,
h-f
Factory torque spec is 25 ft-lbs.
Zillon is offline
