Installed steedas rear sway bar - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2012, 11:35 PM   #41
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
Originally Posted by Bwill9886 View Post
Were you the one that made a thread for this idea a while back?
I know I saw one and meant to find it to ask about updates, but I'd forgotten about it until now.
It's a great idea, as mine are starting to squeak again and I'd REALLY rather not have a repeat of my Accord where I was regreasing every month or two.
Unfortunately the Teflon tape trick doesn't work well with the Steeda RSB because it shifts back and forth due to Steeda placing the blocking rings too close together. It just rips the tape up after a while.
I think there are three threads on the Steeda bar. lol But this seemed to be the original where everyone was discussing tricks to stop any squeak.
As far as I can remember, this is the first time I mentioned the idea of tapping the bushings for a grease fitting. I wanted to see if I could do it successfully before putting it out there. Plus it's always nice to be first with a fresh idea.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 06-23-2012, 02:29 PM   #42
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Originally Posted by newmission View Post
Finally joined the ranks and installed the Steeda rear swaybar. I remember reading this thread about everyone's solution for future squeaks. Well here is mine.
Look like Energy Suspension poly? Nope. Just what came with the bar. I drilled and tapped a hole for a grease fitting, and then took a cutter bit with my Dremel and ground a grease groove all the way around the inside like Energy Suspension does.
That is a good idea. Haven't heard any squeeking from mine yet but will have to make this mod. in the future. Used silicone grease so should last a while.
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
Old 11-27-2012, 08:28 PM   #43
satcomtim
Fan#: 99074
What I Drive: 2012 Race Red SE 5MT 5 door 203A
FF Reputation: 1 satcomtim Good Standing Member
Installed the MS3 RMM today and then got stuck doing the Steeda RSB.
I can't figure out to remove it from the endlinks. I have the 18mm bolts off and the 4 bolts holding the factory bar removed. Now the factory bar is just hanging there and I can figure out how to get it off. The instructions just say remove it. Thanks for any help!
Tim
satcomtim is offline
Old 11-27-2012, 08:34 PM   #44
Bwill9886
Bwill9886's Avatar
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Tim
Remove one of the end links from it's mounting point on the car. There is a nut and you'll need an allen wrench to hold the bolt/endlink at the top so you can loosen the nut.
Bwill9886 is offline
Old 11-27-2012, 08:38 PM   #45
satcomtim
Fan#: 99074
Thanks Bwill!
I tried to removed that top nut (15mm) but it just spun. Didn't see a way to hold it still. Missed the allen wrench. Will get back out in the morning when it's light and try again. Thanks again!
Old 11-27-2012, 10:40 PM   #46
satcomtim
Fan#: 99074
That worked, decided to go out and finish tonight, thanks again!
Old 11-28-2012, 02:30 AM   #47
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,318, Level 46
Points: 5,318, Level: 46 Points: 5,318, Level: 46 Points: 5,318, Level: 46
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Sweet. Looks tough. Is it adjustable? Or any stats on how stiff is is? The Ford Racing.sways are adjustable, is this adjustable?
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 11-28-2012, 08:02 AM   #48
Bwill9886
Bwill9886's Avatar
Fan#: 93444
No problem at all! Glad you got it installed.
I believe the only stats for how stiff it is are on their website. You can go bigger (MS3 aftermarket/stock RSB's), but this is stiff enough for me without inducing any unwanted handling characteristics. I know that after getting used to it that I really notice how much the front is moving around haha! I'll be glad to get some time to install the FSB.
It is not adjustable.
