How to: 08-11 OEM fog light install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-31-2011, 01:42 PM   #1
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
Level Up 0% Completed
FF Reputation: 7 VonKrause Good Standing Member
All right then, here we go with the how to install the OEM fog light kit from ford. Now during the installation I ran into a few snags and missed photo opportunities so there will be a few spots where I will go through two steps with one picture. The instructions that came with the kit are confusing at times and down right annoying. So without further stalling here we go.
Step one is to make sure you have everything you will need, parts, tools, and drinks. (alcoholic or not is up to you)
Tools required are a socket set, flat and Phillips screw drivers, a drill, drill bits, electrical tape,zip ties, and if you do the optional stuff a soldering iron and solder. (I did the step but ended up undoing it)
I'll take the next step right out of the book as it's really REALLY hard.
Step 3 is disconect the battery from both terminals.
Next step is remove the old plastic covers from the fog light position, this is easily done by grabbing the inside and pulling out and to the outside of the car. Then repeat for opposite side.
Next take the fog lights and bolt them into the fog light position.
Then place the new covers over the fog lights.
Jack up the drivers side of the car and insert a Jack stand
Now for the fun part, remove the front driver side tire and the protective cover in the wheel well. There are a lot of little plastic clips that are annoying and one star bolt.
Next get under the car and remove the air dam, more annoying plastic clips. You will notice once you pull down the air dam that the passenger side of it is attached to the passenger wheel well, leave it alone if possible, it's one less thing you have to mess with if you do.
Next run the fog light wiring down the drivers side and plug in the drivers side fog light.
Then take the passenger side line and run that along the metal beam keeping in mind that the air dam has to go back so keep it clean, neat, and out of the way. Then plug it into the fog light and zip tie the wires to the beam.
Next you run the wire up toward your battery keeping it as neat as possible.
Then down behind your fuse box and tower strut.
You will have to fish a little to get it through but this is why you took the cover out of the wheel well.
Some one said they went in through the place where the clutch would have been but since I have a Manual I went through this little piece of rubber right here. Also the instructions say to drill through the metal but there is no reason to since the rubber is right there.
NOTICE: I discovered that the plug in this picture was actually situated incorrectly, make sure that the leads coming into the plug are where they are supposed to be. My kit was manufactured with one of the leads in the wrong position. Save hours of trouble shooting by checking this first!
Attach the plug leads correctly and run the wires into the car, you can now reassemble the front end of your car and put the wheel back on.
Pull this section of the dash down and pull it out of the way
From behind the switch push out until it pops out and remove it
Sadly this is where I ran into some issues with understanding the directions and didn't take any pictures. But unlike the directions I have words to walk you through the process that are WAY easier to understand than the pictures they provide.
1.remove the red cover from the end of the plug
2.CAREFULLY push/pull out the Gray/Violet wire in pin#6
3.CAREFULLY push/pull out the brown/yellow wire in pin#7
4.Take both wires and fold them back and tape them to the existing wires (they are no longer used)
5.Take the Gray/violet wire from the new wiring from the fog lights and insert it into pin #6
6.Take the Brown/Yellow wire from the new wiring from the fog lights and insert it into pin #7
7.replace the red cover for the front and insert plug into new OEM switch.
8.place switch back into the dash and you are done with that
9.take the two relays and insert them into their plugs and hide the wires up out of the way.
10.optional for the White/orange wire see bottom. *
attach the positive and grounds for the wire as shown and you should be good to go. Please ignore the two other wires as those are for my LEDs
I hope that this has been a help to anyone trying to do this project and I hope it was what you were looking for, if you have any questions regarding anything in here just PM me or drop a comment and I will get back to you.
Optional steps!
The following takes place after installing the switch and is designed to turn OFF the fog lights while the High Beams are on, I installed it and then took it off after coming into a electrical issue that was non-related.
Take apart the steering column cover and locate this bundle of wires and strip back the tape. Locate the White/Orange wire and cut it.
Then take the White/Orange wire from the fog lights and solder the three together and wrap in electrical tape.
Since I don't have a working scanner I took a picture of the wiring diagram for you to look at. Hope it helps.
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
Old 08-31-2011, 02:22 PM   #2
StaX
StaX's Avatar
Fan#: 60442
What I Drive: 2008 Blue S MTX
FF Reputation: 2 StaX Good Standing Member
good write up man. this should be stickied in the how to section, for future references.
Mods in Profile
StaX is offline
Old 08-31-2011, 03:24 PM   #3
KyleQ
KyleQ's Avatar
Fan#: 84296
What I Drive: 2008 Focus Coupe 5 Speed
Points 978, Level 16
Points: 978, Level: 16 Points: 978, Level: 16 Points: 978, Level: 16
Level Up 78% Completed
FF Reputation: 3 KyleQ Good Standing Member
very nice, what a PITA to get the fogs to work... I wonder if I could just be a lazy bastard and run a relay off the parking lights...
2008 SE Coupe MTX
2000 Contour SVT 3L
MSDS Headers/Weapon-R Y-pipe
Torsen T-2/Clutchnet Stage 3
Fidanza 8lb 131 of 2150
KyleQ is offline
Old 08-31-2011, 04:21 PM   #4
StaX
StaX's Avatar
Fan#: 60442
on my 02 i just t-spliced into the head lights and it worked fine. but when i get fogs ill probably do it this way.
Mods in Profile
StaX is offline
Old 08-31-2011, 06:47 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Nice write up, so how are they now?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 08-31-2011, 07:39 PM   #6
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Once it gets dark out I'll get some pics, oddly haven't done that yet... then again haven't been driving while it was dark since they started working
"2nd Gen problems"
SR #233
Old 08-31-2011, 10:28 PM   #7
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Quite well if I do say so myself.
I took a picture with parking and low beams and couldn't tell the diference between the two on film so I said "F" it and posted just the one.
"2nd Gen problems"
SR #233
Old 08-31-2011, 10:43 PM   #8
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
Points 8,314, Level 61
Points: 8,314, Level: 61 Points: 8,314, Level: 61 Points: 8,314, Level: 61
Level Up 55% Completed
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
THIS^^
needs moar low[bootyshak
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 09-01-2011, 01:32 AM   #9
Phokus
Shiny Metal Titanium
Phokus's Avatar
Fan#: 60433
What I Drive: 2013 Performance Blue Titanium Seda
Points 12,717, Level 73
Points: 12,717, Level: 73 Points: 12,717, Level: 73 Points: 12,717, Level: 73
Level Up 67% Completed
FF Reputation: 7 Phokus Good Standing Member
Buy-Sell-Trade Rating: (9)
holy crap. that actually doesn't seem THAT bad...
1965 Mustang Coupe 289 4spd
2003 Land Rover Discovery II SE
2013 Lincoln MKZ Hybrid
Phokus is online now
Old 09-01-2011, 01:35 AM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
So all that was wrong was that one connector?
Moderator for
Technical Chat
