Speedometer Lighting - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-30-2011, 07:03 PM   #11
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Originally Posted by cobie56 View Post
Imo ford did a poor job with the guages. They are not as well designed as they should be. Ford should consult vw to see how it should b done. Te binnacle should be rounder and higher as tall drivers have difficulty seeing it well. Also the guages should b angled up toward the driver more
With the way you write sentences I'm surprised you can read the numbers on the gauges at all.
They're fine. I'm 6'3" and have *no* trouble at all seeing the gauges and reading them all easily. For the people having problems...you realize the steering wheel can be moved, right? There's no reason you should be having trouble reading the gauges at all.
hotleadsingerguy is offline
Old 08-30-2011, 10:32 PM   #12
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,253, Level 77
Points: 14,253, Level: 77 Points: 14,253, Level: 77 Points: 14,253, Level: 77
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
I LOVE the steering wheel. Small cool as can be. Tons of adjustment. Nice controls on wheel.
Have to say this Focus steering wheel is about as good as it gets.
The only thiing i think might be not so great is the switches on the lower sides seem a bit cheap. IF they hold up to use, then it is great!!!
(The trim glare is just finding the right stuff to dull it. Even if the aluminum were dull, that would be enough. As i mentioned ,I plan on painting the trim with acrylic paint, some clear 'duller' (from artist acrylic will do the job.)
Elizabeth is online now
Old 08-30-2011, 10:57 PM   #13
wag4513
wag4513's Avatar
Fan#: 87744
What I Drive: 2011 Acura MDX
Points 377, Level 7
Points: 377, Level: 7 Points: 377, Level: 7 Points: 377, Level: 7
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 wag4513 Good Standing Member
They make a spray paint to frost glass. That would seem to be good to dull any glossy surfaces. If you don't want to tape off areas to use the spray you might try spraying into a disposable bowl to get pool of paint. Then use a brush to paint the glossy surfaces.
Silver Titanium, 401A, Tuscany Red,
Winter Package, 17" Polished Wheels,
Nav, MFT, Sync, and Parking Assist.
Ordered July 19th, Built August 12th,
Delivery estimate 8/29 Picked Up Car on 9/9
wag4513 is offline
Old 08-31-2011, 12:49 AM   #14
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Forum Activity 20%
Yeah, spray frost coulddo it. i just want it to be easy to remove if i change my mind.
(Also i still have the hots for cars like my prior SVT Contour, the best car i ever owned, and may trade in for a ST when they come out. So i do NOT want to do anything bad to my SE i cannot make whole)
Old 10-17-2012, 02:09 AM   #15
Litterbug
Fan#: 104950
What I Drive: 2013 Dark Grey Focus SE
Points 37, Level 1
Points: 37, Level: 1 Points: 37, Level: 1 Points: 37, Level: 1
Level Up 74% Completed
FF Reputation: 1 Litterbug Good Standing Member
Hello, I just purchased a 2013 Focus SE Hatchback. It was purchased on a cloudy day. I am also having problems seeing the speedometer on sunny Florida days. It needs brighter lights in the cluster gauges. I have bulbs adjusted to the max. setting.. I have to use a GPS for a speedometer.. Ug. ;-(... Does the 2013 Focus's have LED lights in the cluster gauges? If they do have Leds, I am going to try to change them out for super bright led bulbs.... The gauges are set to far back and need more light. My Dealer was not any help.... Maybe a Aftermarket Instrument Cluster could be the answer. I have to find a Fix.. Any Ideas?
Thanks,
Litterbug in Sunny Florida
Litterbug is offline
Old 10-17-2012, 05:54 AM   #16
Guimpy
Fan#: 88333
What I Drive: 2012 Platinum White Titanium
Points 141, Level 2
Points: 141, Level: 2 Points: 141, Level: 2 Points: 141, Level: 2
Level Up 82% Completed
FF Reputation: 1 Guimpy Good Standing Member
There's the clear Plasti Dip. You would be able to just peel it off anytime.
Guimpy is offline
Old 10-17-2012, 07:43 AM   #17
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
Back on the the topic of the speedometer...
I've been driving mine for almost a year and a half. I haven't had any issues reading the speedometer other than a little bit at the top sometimes. That's because of my steering wheel position, but it's the best position for me. And that doesn't always happen. It depends how I'm sitting. I've never had an issue with glare and we all know how bright and sunny it was all summer. The numbers are a little small IMHO, but as stated they're white on a black background with a light blue needle.
Posted via FF Mobile
BetaDnB is offline
Old 10-17-2012, 08:23 AM   #18
cobie56
Fan#: 84403
Well, good on you, 6'3" person. Not everyone is the same, don't you know?
(have you never heard of typos?) Perhaps next time you should not be so critical... I'm sure you have your faults.
cobie56 is offline
Old 10-17-2012, 09:16 AM   #19
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
I've never had an issue with gauge visibility during the day, and I've got mine turned down a bit even.
Joined the dark side.
Zillon is offline
Old 10-17-2012, 05:49 PM   #20
JimsterG
Fan#: 95184
What I Drive: 2012 5 dr SEL in Race Red
Points 131, Level 2
Points: 131, Level: 2 Points: 131, Level: 2 Points: 131, Level: 2
Level Up 62% Completed
FF Reputation: 1 JimsterG Good Standing Member
Anybody who can't easily see the gauges clearly in the new Focus under any lighting conditions should consult an eye doctor. The car is not the problem!
JimsterG is offline
