General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#91 | ||||
Gets more V8
hmm wish I could be there.. 19-21 I will be
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish) Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics |
#92 | ||||
.Flat Out.
Alright, I've got a question on vacuum sources and set up.
I'm running the AEM Tru Boost electronic boost gauge, Turbonetics Evo wastegate, and Greddy BOV. I'm not sure how the vacuum lines are supposed to be routed. here are some pics of what I've got. where do I route the vacuum line? ![]() Boost solenoid- two vacuum ports? where to..? ![]() BOV- this vacuum line goes where?? ![]() I don't have my piping all buttoned up, but it seems my BOV is going to hit the hood.. Do i have it at the wrong angle? thanks..
The Rich Get Richer Until The Poor Get Educated. Do Vegetarians eat Animal Crackers? Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics |
#93 | ||||
Gets more V8
doesn't look like the wrong angle unless you can rotate that pipe a bit.
Second pic is the wastegate. Vacuum source for that should be closest to the turbo I do believe. BOV should be after the throttle plate.
#94 | ||||
.Flat Out.
I've seen some wastegates route the vac to the turbo, but my turbo doesn't have a fitting for it.. where else can i route this?
With my set up, am i going to have to tee off 4 spots or 3? Should i consider a vacuum manifold?
#95 | ||||
Gets more V8
my waste gate is routed to manifold vacuum.... I guess its supposed to be more responsive if its at the turbo.
#96 | ||||
.Flat Out.
gotcha. so considering my turbo doesn't have a nipple on the compression housing, i can either drill one, or drill one on the charge pipe near it.. right?
since i'm using an electronic boost gauge i'll have to use both ports on the wastegate, right?
#97 | ||||
.Flat Out.
Figured it out.
Top wastegate fitting tees off to turbo and boost solenoid. bottom wastegate fitting goes to the other side of the boost solenoid. I went and got a hose fitting for the top of my wastegate.. but it doesn't fit!! couldn't find anything that would. gonna call Turbonetics and see if they have em..
| Thread Tools | |
| Display Modes | |
