Valve cover gasket for Focus Zetec 2.0 2002: with or w/o grommets? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-25-2011, 04:02 PM   #1
compositeFEA
Fan#: 89209
What I Drive: 2002 Red SE Wagon Zetec
FF Reputation: 1 compositeFEA Good Standing Member
Hi all,
The valve cover gasket on my 2002 Focus SE Zetec is leaking, so I am about to change it. The guy at the parts store gave me this gasket: Fel-Pro #VS50553R, which comes without any grommets. After that I found on some web sites that another gasket exists, which is similar to the one I just bought, but with grommets. I also found another one with different shape (Fel-Pro #VS50581R) and with grommets. This last one is also supposed to fit the Zetec 2.0L engine of year 2002... So now I'm wondering what gasket I should use, and will I need some grommets before removing the cover and change that gasket? I mention that the VIN engine code is 3. Any advice would be appreciated! Thanks...
compositeFEA is offline
Old 08-25-2011, 04:19 PM   #2
deezx5
deezx5's Avatar
Fan#: 72153
What I Drive: 2011 Gray Hyundai Elantra GLS
FF Reputation: 3 deezx5 Good Standing Member
I got the one with grommets but didn't use them since the factory vcgasket did not have them. I guess it was fine since I didn't have any more leaks. I used the focushacks guide as a reference http://www.focushacks.com/?modid=83&...%20Replacement
deezx5 is offline
Old 08-30-2011, 09:52 PM   #3
deadend9009
Fan#: 69681
What I Drive: 2003 Grey Focus ZX5
FF Reputation: 3 deadend9009 Good Standing Member
You dont need gromets. You'll see when you take it all appart. That seal is 78$ from the dealer here...how much are you paying?
deadend9009 is offline
Old 08-30-2011, 11:29 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,001, Level 74
Points: 13,001, Level: 74 Points: 13,001, Level: 74 Points: 13,001, Level: 74
Level Up 38% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
I only paid $7 for my Fel-Pro valve cover gasket. I had to get a Contour valve cover gasket since I changed over to the aluminum cover. That kit included the grommets and I wasn't sure if the Focus Zetec one did or not. The grommets aren't all that necessary but if you are replacing one gasket why not replace the grommets since they are pieces that are under direct pressure from the bolts. I know it's a limited chance of happening but the grommet could break apart and completely pop out leaving no pressure pushing down on that one section of the valve cover meaning that the other bolts have to take up more work and more than likely causing them to fail as well. Granted, this is over a longer period of time but a valve cover gasket is not something everyone checks all the time and by the time they do check it, it is generally to replace it since it is leaking. Oh, I have moved this to the Zetec owners section since this doesn't have anything to do with a performance related topic.
My philosophy on the whole deal is...do it right the first time and you won't have any problems with it later on.
zetecDon is offline
Old 08-31-2011, 12:33 AM   #5
redSVT_03
redSVT_03's Avatar
Fan#: 78206
What I Drive: 2003 red SVTF
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 4 redSVT_03 Good Standing Member
Buy-Sell-Trade Rating: (4)
Going to have to re do mine tomorrow. any tips for me and the op? this is the deepest I have gone as far as engine work before lol
redSVT_03 is offline
Old 09-01-2011, 11:00 AM   #6
compositeFEA
Fan#: 89209
I think I paid 70$ for mine. I will do the job next week, I will let you know about the results. Thanks to all of you for commenting!
Old 09-01-2011, 02:30 PM   #7
redSVT_03
redSVT_03's Avatar
Fan#: 78206
why so much? i got mine for around 20 from ford
Old 09-05-2011, 09:44 PM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
Forum Activity 33%
Be sure when you put this on to apply the right amount of torque to it and to work from the center out. In other words starting with the middle bolts first and then torquing them down to specifications outwards. The torque needed is 60 inch pounds.
zetecDon is offline
