Eibach Springs for 2012+ Focus - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2012, 10:38 PM   #41
Bwill9886
Bwill9886's Avatar
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by FocusBoy58 View Post
I went H&R
AFTER
Looks like you may have a bit of the "boat look" (When the front looks higher than the rear) going on or is it just the angle of the picture?
Bwill9886 is offline
Old 01-04-2012, 11:38 PM   #42
Ghost71
Ghost71's Avatar
Fan#: 91701
What I Drive: 2012 black Ti hatch
FF Reputation: 1 Ghost71 Good Standing Member
No boat look to me. Love the drop. That's more my style. ...
Looks good:-)
Ghost71 is offline
Old 01-05-2012, 01:24 AM   #43
FlankerDFR
FlankerDFR's Avatar
Fan#: 90863
What I Drive: 2013 Blk ST2
Points 562, Level 11
Points: 562, Level: 11 Points: 562, Level: 11 Points: 562, Level: 11
Level Up 24% Completed
FF Reputation: 1 FlankerDFR Good Standing Member
Not sure if I'd ever consider any lowering kit in my part of MI. Crumby roads combined with way to many asphalt divots (&*%$&^ there are so many you'd think they were from a mortar barage)...............leaves me wanting all the suspension travel as my Focus comes with! Same reason I'm hesitent to come down much off the stock 50 aspect ratio on m tires.
2013 ST2-Tux Blk, FSW 93 Oct tune & 3" cat back, Steeda R sway bar & CAI, Sparco rims, Centric ceramic pads, Luminix Ti White bulbs
2007 ZX14 Sato Ti exhaust, PC III, CF bits 'n pieces
FlankerDFR is offline
Old 01-05-2012, 08:45 AM   #44
herbz
Fan#: 84909
What I Drive: 2012 SE Hatch 5MT Sterling Grey
Points 7,973, Level 60
Points: 7,973, Level: 60 Points: 7,973, Level: 60 Points: 7,973, Level: 60
Level Up 12% Completed
FF Reputation: 1 herbz Good Standing Member
Encouraging to see they have some parts in development, especially the camber adjustment kit.
However, I'd never put springs on the car without also installing heavier duty dampers (shocks, struts, sway bars). So until those come out, stock suspension for me. Also, coilovers would be nice for winter time around here.
2 years left on the warrantee however, so, plenty of time for that.
herbz is online now
Old 01-05-2012, 09:46 AM   #45
cobie56
Fan#: 84403
same issue here.. roads in no. NY and VT and Quebec are often bad from winter weather, frost heaves, pot holes and such... it'd be great to just have the better control of a good suspension w/o the lowering. Up here in frost country we need all the suspension travel we can get.
cobie56 is offline
Old 01-05-2012, 10:12 AM   #46
Ghost71
Ghost71's Avatar
Fan#: 91701
You can safely lower without upgrading struts and shocks. Only up to 1" or so. Any more than that, you should upgrade.
Ghost71 is offline
Old 01-06-2012, 02:41 PM   #47
cmanatam
Fan#: 85855
What I Drive: 2012 Focus Titanium Black
FF Reputation: 1 cmanatam Good Standing Member
Advice on install
I will be installing the Eibach Pro Kit springs this weekend. My initial "walk around" of the suspsension tells me the rears will be cake but the fronts look like a little tougher task. Any helpful hints for getting the fronts on. It looks like you'll have to disconnect the stabilizer bar and un-clamp the lower strut from the control arm the disconnect from upper strut mount and remove. Was this easier than it looks? Thanks in advance!
cmanatam is offline
Old 01-06-2012, 04:59 PM   #48
Ghost71
Ghost71's Avatar
Fan#: 91701
Anything connected to the strut must come off. Pretty simple:-)
My question would be how do you get to the nuts on top in the engine bay that bolt the strut to the body. Just by looking, I don't see sh••. It would be where your strut bar would bolt to. Lmao
Ghost71 is offline
Old 01-07-2012, 02:37 AM   #49
Eurofordfan
Fan#: 87186
What I Drive: 1985 Moto Guzzi T5 850 NT
FF Reputation: 1 Eurofordfan Good Standing Member
It's not just the operating range of the dampers that is at issue, i.e. using OEM struts versus sport struts.
The lowering springs, almost invariably, are a higher spring-rate spring. As such, it is harder to control, from a damping perspective -- and that demands more effective dampers.
As for me, I would be really pleased if Koni (Yellow) rebound-adjustable sport struts were available for the car. Pair these (which are optimized for moderate lowering) with the Eibach's and you're definitely good-to-go.
Eurofordfan is offline
Old 01-07-2012, 09:05 AM   #50
Ghost71
Ghost71's Avatar
Fan#: 91701
Stock shocks are pretty much the same as an after market. As you know they only make your ride as smooth as possible. After market shocks offer that extra travel for a lowered car. Buying shocks for a small drop is a waist of $ as it doesn't travel far enough to bottom out. Most companies suggest upgrading only after so many inches.
Ghost71 is offline
