Eibach Springs for 2012+ Focus - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2011, 09:21 AM   #31
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 10 2012sel Great Standing Member
Alignment after lowering...the right way to do it?
[QUOTE=matthoma;I was hoping adjustments wouldn't be an absolute must due to the minimal drop. However, I was just looking at the car, and that may end up being untrue. The front doesn't appear too bad, but the rear definitely has a noticeable negative camber angle.[/QUOTE]
Are additional parts necessary to put camber right on a 1" lowered Focus? Anyone who's lowered please chime in and let us know how the right way to do this is. Thanks in advance.
2012sel is offline
Old 11-14-2011, 06:15 PM   #32
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,086, Level 92
Points: 22,086, Level: 92 Points: 22,086, Level: 92 Points: 22,086, Level: 92
Level Up 74% Completed
Forum Activity 12%
FF Reputation: 10 Twenty Great Standing Member
I don't need these I don't need these I don't need these I don't need these.....
Yet.
Maybe.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 11-14-2011, 08:04 PM   #33
underbird10
underbird10's Avatar
Fan#: 88103
What I Drive: 2014 ST3
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 3 underbird10 Good Standing Member
I haven't done any camber work yet on mine. So far I'm at about 1800 miles with the new springs and I'm not detecting any abnormal wear on the tires or any handling issues. My rears have about 2 degrees negative after the install (fronts are within specs), but I don't plan on doing anything about it until I know there's a problem.
Camber is not an easy adjustment on this car. The multi-link suspension requires a pretty elaborate set of adjustments to get them back to factory spec. I've seen kits online just for the rears that cost over $500 and the fronts would most likely be even worse. There is a workaround that could be done on the rears for a few bucks, but it would definitely void your warranty. I won't discuss it here, but if you take a look at the rear setup and are familiar with cam bolts you'll see what I mean. Some cutting and grinding would be required.
UB10
2014 ST3 - Tuxedo Black with Full Leather Recaros, Sunroof, Nav-Sync-MFT
My other rides -2006 Performance White Mustang GT Coupe, 2004 40th Anniversary Edition Mustang Coupe, 2013 Edge Limited
underbird10 is offline
Old 01-04-2012, 11:51 AM   #34
2012sel
2012sel's Avatar
Fan#: 84814
Been a while and want to ask those who used Eibach lowering springs to give feedback on the alignment issues introduced, if any. And to give feedback on how they like it.
Do you think your car will need extra work beyond a standard alignment or is it good for the long term as is? When I lowered my F150 I had to install a camber bolt kit. It worked out great, but I hear the Focus is not going to be easy if a camber kit is necessary.
I really want to do this, but I don't want do surgery on my Focus to make it right. If it's a straight bolt on, I'm doing this modification asap.
UPDATE: I just checked Eibach's website. You should see all the suspension stuff under development. Including a camber kit!
http://performance-suspension.eibach...cation_look_up
.8 inch kit
1.5 inch kit
Rear camber arm
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
Old 01-04-2012, 12:47 PM   #35
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 20,766, Level 90
Points: 20,766, Level: 90 Points: 20,766, Level: 90 Points: 20,766, Level: 90
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
All the rear suspension is the same on 2000-2012 models the camber arms from any company will work.
I went H&R
BEFORE
AFTER
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
Old 01-04-2012, 12:48 PM   #36
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,343, Level 41
Points: 4,343, Level: 41 Points: 4,343, Level: 41 Points: 4,343, Level: 41
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 5%
FF Reputation: 9 darkangelism Good Standing Member
i wonder if their rear camber arm will fix the rear camber back to factory spec after lowering.
darkangelism is offline
Old 01-04-2012, 01:01 PM   #37
underbird10
Fan#: 88103
I now have about 4,000 miles on the car with the Eibach Spring kit and still no wear issues with the tires. If you need to adjust the camber just for aesthetic's sake, the adjustable arm would definitely be the way to go.
My car came with the upgraded suspension, so I would have to say that the ride is slightly harsher, but the cornering crispness and body roll are substantially better. I like it just fine the way it is after the spring kit.
In comparison, I have an 06 Mustang GT with Roush Racing suspension components throughout and it's like riding a bucking horse compared to the Focus. I still love my Stang, but for the long rides I prefer the Focus by far.
UB10
Old 01-04-2012, 01:09 PM   #38
cobie56
Fan#: 84403
Originally Posted by kylesvt720 View Post
Not sure if you guys found this yet, but saw it on their facebook wall, figured I'd shoot it in here...
http://performance-suspension.eibach...gs&sf2049832=1
Nice, however their before/after pic of the black focus makes it difficult to see the difference in ride height... perhaps a lighter colour car would have been a better choice? def up for consideration, tho...
cobie56 is offline
Old 01-04-2012, 01:10 PM   #39
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 5%
did you get the 0.8" or the 1.5" kit?
Old 01-04-2012, 08:04 PM   #40
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
Forum Activity 2%
rear camber is -2 degrees on a 1.5" drop. the front camber is -1
