2000 Focus SE... NO START - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2011, 10:20 AM   #21
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,059, Level 27
Points: 2,059, Level: 27 Points: 2,059, Level: 27 Points: 2,059, Level: 27
Level Up 40% Completed
Forum Activity 2%
Originally Posted by banzaibullitt View Post
The dash isn't working.
The attempt at the dash diagnostic test doesn't work or the dash itself is non-functional?
No, an OBDII reader won't display those codes.
Your description of the problem seems to be leaving out some critical pieces of information.
Did you check the fuses? If not, check them all.
BC_ZX3 is offline
Old 08-28-2011, 11:54 AM   #22
banzaibullitt
banzaibullitt's Avatar
Fan#: 89164
What I Drive: 2000 Go Platinum Sony Edition SE
FF Reputation: 1 banzaibullitt Good Standing Member
Smile Success!!!!!
YOU'RE THE MAN!!
I checked the fuses earlier this morning.. It was fuse 8 (IGNITION) that was fried. I had no idea that this fuse was hooked up to so many circuits.
Yesterday, I found a wire under the hood that had melted against a hot metal tube on the D/S of the engine (something to do with exhaust?). I fixed the insulation and secured it to the side of the battery box. That must have been the cause of this headache.
Thank You!!
banzaibullitt is offline
Old 08-28-2011, 11:58 AM   #23
banzaibullitt
Fan#: 89164
Another Rep point for you!!
Old 08-28-2011, 02:32 PM   #24
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 2%
Glad it was something simple...as usual.
BC_ZX3 is offline
Old 08-28-2011, 02:58 PM   #25
banzaibullitt
Fan#: 89164
Thumbs up
I am saving the cluster diagnostic link... good info.
2000 Sony Ed. Focus, 1986 Mustang LX
Old 08-30-2011, 04:40 PM   #26
Gatrbait
Fan#: 89385
What I Drive: Red 2001 Focus SE Wagon
FF Reputation: 1 Gatrbait Good Standing Member
Same exact problem
Went to start car for work this morning and the exact same problem occured...battery is good..alt is good...starter is new and checked all connections before posting here...when key is turned to start..only constant chime...no dash lights..no radio..nothing except for dome..door locks and trunk...when brake is depressed and key to on...shifter is still locked out...no power there either...key works fine with no hangups...any ideas anyone?
Gatrbait is offline
Old 08-30-2011, 05:09 PM   #27
alz focus
Fan#: 67546
What I Drive: 2002 Blue SE
Points 975, Level 16
Points: 975, Level: 16 Points: 975, Level: 16 Points: 975, Level: 16
Level Up 75% Completed
FF Reputation: 5 alz focus Good Standing Member
Did you check your fuse #8?
What is your PATS doing?
Al
2002 Focus SE Zetec ATX
2000 Focus SE SPI ATX
2006 Freestyle SEL AWD
alz focus is offline
Old 08-30-2011, 05:55 PM   #28
boogie101us09
Fan#: 89390
What I Drive: 2006 ford focus
FF Reputation: 1 boogie101us09 Good Standing Member
i have the same problem with my 2006.but when i turn the key to the on position everything goes dead except for the passenger air bag lite,the antitheft lite,and the check oil lite all start blinking real fast and i can hear clicking coming from the engine compartment.and the radio comes on even when the key is off.i can change or stop the noise and blinking lites when i press the hazards button.please help!!!anyone?thanks
boogie101us09 is offline
Old 08-30-2011, 06:34 PM   #29
benkap
Hatch Nation #136
benkap's Avatar
Fan#: 86366
What I Drive: 2003 Mineral Grey Metallic ZX3
FF Reputation: 14 benkap Great Standing Member
Gatrbait & boogie,
You should start your own threads. While you may be experiencing similar problems, you have different cars and different circumstances.
You'll get better troubleshooting.
Posted via FF Mobile
benkap is offline
Old 08-30-2011, 09:55 PM   #30
StayFocusedSon
Fan#: 83947
What I Drive: '03 Infra Red SVT
FF Reputation: 3 StayFocusedSon Good Standing Member
sounds like a bad neutral safety switch, i'd look there next
xtremeperformance.info
StayFocusedSon is offline
