2000 Focus SE... NO START - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-24-2011, 01:27 PM   #1
banzaibullitt
banzaibullitt's Avatar
Fan#: 89164
What I Drive: 2000 Go Platinum Sony Edition SE
FF Reputation: 1 banzaibullitt Good Standing Member
Exclamation 2000 Focus SE... NO START
I have a 2000 Focus SE with AT trans. It worked fine last night, but today it won't start. The battery is good.
When I turn the key to start, the door chime is a constant chime, not a "ding-ding"
What doesn't work:
- instrument guages
- wipers/washer
- headlights
- power window power
- can not shift out of park
What works:
- power door locks
- trunk release
- parking lights
- dome light
- horn
Is it the ignition key switch? I read that another member on here had a similar issue with a ZX3.
banzaibullitt is offline
Old 08-24-2011, 05:38 PM   #2
banzaibullitt
Fan#: 89164
Old 08-24-2011, 05:48 PM   #3
foxyl6162
foxyl6162's Avatar
Fan#: 84165
What I Drive: 2002 GREY FOCUS ZTW ZETEC 156K
FF Reputation: 1 foxyl6162 Good Standing Member
either key or ground wire if u ask me but without being there just a shot in the dark. could try disconnecting battery and cleaning it.
All i want is a car that runs perfect and never breaks down is that too much to ask
foxyl6162 is offline
Old 08-24-2011, 06:49 PM   #4
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,262, Level 67
Points: 10,262, Level: 67 Points: 10,262, Level: 67 Points: 10,262, Level: 67
Level Up 53% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
door locks and interior light dont take much voltage even if battery was dead they would still work i would first try and jump start the car then at least you know battery is dead cuold be you left somthing on
pasta is offline
Old 08-24-2011, 07:37 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Use the owner's manual to check the fuse for the PCM. I would also clean and inspect the wiring near the battery terminals- especially the negative battery terminal. There should be one large black wire, and 2 small black wires that connect to that terminal.
I would bet it's the fuse more than the battery terminals. How did you test your battery? If you used a digital multi-meter to check voltage, then you should check voltage while you try to crank the engine. If you want to get the car out of park, then use the key to unlock it manually as directed in the owner's manual.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 08-24-2011, 08:05 PM   #6
banzaibullitt
Fan#: 89164
Nothing happened when I tried to start it. The battery has good voltage. It worked perfectly last night, but this morning it would not turn over at all, even with jumper cables hooked up.
Old 08-25-2011, 12:37 AM   #7
banzaibullitt
Fan#: 89164
anyone?
Old 08-25-2011, 12:45 PM   #8
banzaibullitt
Fan#: 89164
Old 08-25-2011, 12:53 PM   #9
benkap
Hatch Nation #136
benkap's Avatar
Fan#: 86366
What I Drive: 2003 Mineral Grey Metallic ZX3
FF Reputation: 14 benkap Great Standing Member
Does the key not turn, or does it turn and nothing happens? Can you put the ignition into accessory? Is the car trying to crank to no avail?
More info!
Drive it like you stole it.
benkap is offline
Old 08-25-2011, 01:16 PM   #10
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
You keep saying the battery has good voltage. That still does not mean its any good. Even with a jump start, if the battery has a short, or a dead cell. It wont deliver enough amp`s to crank the engine. Put another battery in it. Also put the trans in neutral , make sure the neutral safety switch is good.
iroc34 is offline
