SEL Switchblade Key. - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2013, 10:42 PM   #121
Seldomseenkid
Seldomseenkid's Avatar
Fan#: 89757
What I Drive: Ford Focus SE 2012 Hatchback
FF Reputation: 1 Seldomseenkid Good Standing Member
Is this it?
How To Do It!
Time Required: 5 minutes
Tools Needed: Hands. The key you use to start your car. All remotes you plan to use on your car (not just the new one)
Procedure:1) Gather all the remotes you plan on using with your car.
2) Get in car, fasten seatbelt, and close doors to make sure it doesn't beep when you turn on the ignition to "Run"
3) Place key in the ignition.
4) Turn the ignition to "Run" (Not Start), then back to "Off" at least 4 times in 6 Seconds, stopping at "Off"
5) The car will make one "BONG!" tone, like when you leave the car door open with the keys in the ignition.
6) Hit "Unlock" on each remote you wish to use. Wait about 1 second between each remote. You only have a window of 10 seconds to add your remotes. Only 4 can be added at a time, and if you add any remotes, then all the ones that used to work for the car that you did not program will not work.
Seldomseenkid is offline
Old 09-06-2013, 10:48 PM   #122
Gi_Jo_Nathan
Gi_Jo_Nathan's Avatar
Fan#: 98931
What I Drive: 2012 Sonic Blue 5Door MTX
Points 368, Level 7
Points: 368, Level: 7 Points: 368, Level: 7 Points: 368, Level: 7
Level Up 36% Completed
FF Reputation: 3 Gi_Jo_Nathan Good Standing Member
Yep.
Jonathan
12 SE HB MTX, IE Tuned, Snorkel DLT, Green Filter(Gray), custom 2.5" cat-back w/borla, Steeda RSB & Short Shift Bracket, JBR Solid Shifter Bushing's, MS3 RMM w/Corksport Inserts, Ti Heads, Redline Tuning Hood Struts, De-chromed
Gi_Jo_Nathan is offline
Old 09-06-2013, 10:52 PM   #123
Seldomseenkid
Fan#: 89757
Thx GI_JON. Imma try it first thing in the morning and let you know.
Old 09-06-2013, 10:53 PM   #124
Gi_Jo_Nathan
Fan#: 98931
Points 368, Level 7
Good deal!
Anytime!
Jonathan
Old 09-06-2013, 11:07 PM   #125
rickdarris2004
rickdarris2004's Avatar
Fan#: 108926
What I Drive: 2014 Mazda 6 Touring
Points 191, Level 3
Points: 191, Level: 3 Points: 191, Level: 3 Points: 191, Level: 3
Level Up 82% Completed
FF Reputation: 1 rickdarris2004 Good Standing Member
Originally Posted by SilverPony2001 View Post
Wondering the same.
I am wondering the same, the Fusion key looks great. I will even go to the dealer for it if I have to!
rickdarris2004 is offline
Old 09-07-2013, 12:47 PM   #126
vegachicago
Fan#: 89988
What I Drive: 2012 Focus SEL Sterling Grey
Points 1,004, Level 17
Points: 1,004, Level: 17 Points: 1,004, Level: 17 Points: 1,004, Level: 17
Level Up 4% Completed
FF Reputation: 2 vegachicago Good Standing Member
Is this it?
How To Do It!
Try this if nothing works:
http://www.focusfanatics.com/forum/showthread.php?t=269688
vegachicago is offline
Old 09-07-2013, 04:22 PM   #127
Seldomseenkid
Fan#: 89757
I tried both option 1 aseveral times. No luck. vegachicago. i will try this http://www.focusfanatics.com/forum/showthread.php?t=269688
and keep you posted. i'm starting to be discouraged. what's the use of having a key if i can't lock or unlock the doors remotely. :-(
Old 11-07-2013, 07:03 PM   #128
Seldomseenkid
Fan#: 89757
Hi team
IVe lost all hope in programming my Flip key that i got of ebay. it seems that my 2013 Focus won't take any of the below steps. I can start the car with the key but can't seem to program the remote part of it to lock/unlock the doors. Any other ideas or recommendation. Would be so grateful. thanks again
and also tried this procedure:
Follow the manual as to the basic procedure, however do this also:
1. First, the vehicle must be opened electronically with your remote.
2. Open the door and leave it open.
3. Just before inserting the first key, press the lock button on the key, and the locks should lock and then immediately press unlock and insert the key and turn to the on position for three seconds or when the chimes start and then remove the key. Now within ten seconds....
4. Press lock and then unlock buttons on the second key. Insert and turn again to the on position for three seconds or until the chimes start then remove.
5. Insert the third key and turn to on for at least 6 -8 seconds and turn to the off position.
Key should be left in for about 5 seconds. Remove new key and then reinsert and start the engine to verify that programming took.
Old 11-07-2013, 11:18 PM   #129
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 131, Level 2
Points: 131, Level: 2 Points: 131, Level: 2 Points: 131, Level: 2
Level Up 62% Completed
FF Reputation: 1 Lite12 Good Standing Member
Quite tempted myself....
But afraid the end cost would be high.
I LOVE the Fusion key though
2013 SE 5dr w/sport appearance, race red, 5mt
Amber LED frt markers, LED backups
Lite12 is offline
Old 11-30-2013, 04:47 PM   #130
Spitfire22
Spitfire22's Avatar
Fan#: 120066
What I Drive: 2012 Focus SEL SGM HB
FF Reputation: 1 Spitfire22 Good Standing Member
anyone have any success with a fusion key?
Current Rides:
2012 Taurus SE
Spitfire22 is offline
