Old 08-24-2011, 06:12 AM   #11
Esteban
Fan#: 54267
What I Drive: 03 ZX3 5spd
FF Reputation: 1 Esteban Good Standing Member
UPDATE ;
I had saved the old original wires & put those back on . World of difference ! I ordered a set of new Motorcraft wires & will replace the fuel filter, too. If that doesn't completely solve the problem , I will make another NEW thread .
Thanks for the help, guys !
Esteban is offline
Old 01-02-2013, 02:24 PM   #12
xerics
Fan#: 86621
What I Drive: 2012 focus sedan se
FF Reputation: 1 xerics Good Standing Member
I have the same sudden drop in mileage. Went from 30.5 average in mixed town highway driving to 29. Worse, the highway mileage went from 45 to 38. (I'm a fairly slow driver)
Could it be transmission reprogram which I had done last fall?
2012 focus with 15,500 miles total.
xerics is offline
Old 01-02-2013, 05:34 PM   #13
elsolo
elsolo's Avatar
Fan#: 96835
FF Reputation: 9 elsolo Good Standing Member
It could also be "winter gas blend" as many cars see a drop in mileage.
elsolo is offline
Old 01-02-2013, 05:44 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
FF Reputation: 6 Magus2727 Good Standing Member
a change from 30.5 to 29 is not a large or even sudden drop. Winter blends impact it but that should have been used sine November time frame for most gas stations. How do you measure your MPG? did you fill up the exact same station same pump? did you let it auto click off and leave it at that or did you fill more in? if you fill up at a different station, and are a a slightly different incline you can put more or less fuel in. the auto turn off will vary with temperature and with pump. You need to trend it over time. I would not trust a MPG change unless it showed constantly lower for more than 3 repeated fill ups at the same station using the same pump.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 01-02-2013, 07:29 PM   #15
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
Do you buy fuel at same place every time? Just because they went to 10% ethanol means nothing. Here in Texas they can put anything around that number, dealers routinely check ethanol percentages in fuel to verify warranty violations so customer complaining has to pay for the work, of course customer has no idea what's in the fuel. Even though the federal mandated max amount is supposed to be 10%, very often it is more, as high as 20 in some cases. They tilt the fuel with more alky to make your mileage drop so you have to buy more fuel and faster. Occasionally it even gets high enough to cause engine problems, Walmart stations went through that a while back. The finger pointing between Walmart and Murphy Oil was pretty funny.
Try different station for fuel, the problem has been covered by newscasts here in the D/FW area. New cars get good mileage, then suddenly they don't........
If they ever allow 15% as legal watch out. The fuel suppliers claim it will not hurt cars, but they already know since they have been doing it in some cases for years. At first they hated ethanol, but they have learned to embrace it and even love it, just one more hard to trace method for ripping off the public.
amc49 is offline
Old 01-04-2013, 08:58 PM   #16
xerics
Fan#: 86621
A drop from 30.5 to 29 is not so great, but a drop from 45 to 38 is. Now, This is my second winter with this car and the mileage problem is new. It could be ethanol but I don't know. I buy fuel at Arco which is a sub of BP.
Who controls the ethanol content of fuel?
xerics is offline
Old 01-04-2013, 09:07 PM   #17
Magus2727
Magus2727's Avatar
Fan#: 62897
What's your 2012 rated to get on the freeway? Lots of factors can do that, say you have unusually windy days and always have a strong head wind. Or your tires have dropped 1/2 a psi due to an extra cold front, or the salt on the roads causing a little more rolling resistance. You did not fill up all the way, or might have had a small % more of ethanol in that tank.
Is ARCO really a sub of BP? I HATE ARCO with a passion and refuse to go to their stations when I am in CA. Its the refinery I believed that does the blend, but I think the stations may have some say on what they order. It should be a MAX % of possible ethanol but I don't think its regulated or can be since it can vary by fuel truck delivery.
Hatch Nation #42
Old 01-04-2013, 11:14 PM   #18
amc49
Fan#: 96610
Supposed to be 10% but the recent congressional debacle over going up to 15% has some places thinking they can legally go to 15 now. EPA sets it but different in different areas based on pollution readings. Big cities more likely to have it and rural maybe not unless their air swept by city air to pollute it. Here in Texas it was like 7 major counties around Houston and Dallas, recent non-attainment expanded that to many more surrounding counties. The station fuel pumps should have a sticker on side saying they have ethanol in fuel. Refineries control the actual amount but sometimes after the fact blending goes on out in the field.
amc49 is offline
