grinding noise when turning wheel + hard steering - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-15-2011, 12:15 AM   #1
oblivion2kx
Fan#: 61764
What I Drive: 2004 Twighlight Blue 2.3l ZX5
FF Reputation: 2 oblivion2kx Good Standing Member
Ok so here is what I have. I left my car with my girlfriend for 3 months as I went away for the summer. When I came back the car makes a grinding noise when I turn the wheel (while parked), it gets the loudest when I turn the steering wheel to the max turn radius when parked and winds down when I adjust the wheels to be straight again. The car is hard to steer (very stiff steering) almost feels like I lost my power steering.
So, other than not leaving your car with your girlfriend, where should I start looking for the problem???
Thanks guys
A few years ago, I went to the gym for several months and lost 30 pounds. That must be worth about 1% more fuel economy in the city.
oblivion2kx is offline
Old 08-15-2011, 01:39 AM   #2
sparky34kv
Fan#: 63383
What I Drive: 2004 Blue ZTW Wagon, 2.3 L Duratec
Points 365, Level 7
Points: 365, Level: 7 Points: 365, Level: 7 Points: 365, Level: 7
Level Up 30% Completed
FF Reputation: 1 sparky34kv Good Standing Member
Check the level in your power steering fluid resevoir, as well as looking over the pump and system for a leak. Most likely it has nothing to do with her, unless she hit something while driving that was able to damage a line to the steering rack.
2004 Blue ZTW, 2.3 L Duratec, Stock Everything
68,000 miles, Autolite 103 Copper Gapped .051,
Fram PH3600 Oil Filter, 5-20w Full Synthetic Oil,
General Altimax HP-Best Tires Ever!
sparky34kv is offline
Old 08-15-2011, 01:40 AM   #3
ferby20
Fan#: 48673
What I Drive: 03 SVT Focus
FF Reputation: 1 ferby20 Good Standing Member
i would suspect the p/s pump itself is bad.
ferby20 is offline
Old 08-15-2011, 06:52 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Your PS fluid is likely low or in need of being changed.
I'm going to say this again, and I will provide Ford part numbers to prove it later when I can get to my manual. Use Type F ATF which sometimes comes in bottles that simply have ATF on it or use generic power steering fluid. Do not use a Dexron/Mercon ATF those are thinner fluids.
After refilling the PS fluid reservoir, crank the steering back and forth- lock to lock, and then check the level again. Continue to fill to max until it no longer goes down. That's how you bleed a PS unit. If the PS pump itself is bad, you will hear rattling from it. Otherwise, you merely need to bleed and replace fluid.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-15-2011, 08:25 AM   #5
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
Not like this really needs to be said, but before you start cranking the steering wheel left and right, put your car on jacks stands so you can save your tires.
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Old 08-15-2011, 01:21 PM   #6
oblivion2kx
Fan#: 61764
I checked the ps fluid and the reservoir is at the max level. Could it maybe a belt issue?
I'm changing the tires in the next two weeks anyway
Old 08-15-2011, 09:04 PM   #7
oblivion2kx
Fan#: 61764
ok so I've narrowed down from where the noise is coming from. Seems to come from the black box right next to the top most pulley on the passenger side of the engine. I'm guessing this is the power steering pump?
Also I connected my obd2 scan tool and no codes came up.... until I ran a ford diagnostic check, these 4 codes popped up..
P1000
p1550 power steering pressure sensor out of range
p1703 brake switch out of range
p1780 transmission control switch out of range
Old 08-15-2011, 10:01 PM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Belts squeal.
PS pumps groan.
Is the sound you're hearing a high pitched noise like a screech or more midrange like the groan description?
Be eclectic.
Old 08-16-2011, 12:51 AM   #9
oblivion2kx
Fan#: 61764
Belts squeal.
PS pumps groan.
sounds like a moaning noise, not exactly belt squeal.
I went ahead and ordered a power steering pump. Let's see if that helps.
Old 08-16-2011, 12:53 AM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,345, Level 75
Points: 13,345, Level: 75 Points: 13,345, Level: 75 Points: 13,345, Level: 75
Level Up 24% Completed
Forum Activity 99%
X2 - and YES that IS the power steering pump & reservoir...
sailor is online now
