What neat tricks and tips have you've found since owning? - Page 96 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Focus
Old 07-05-2013, 06:34 PM   #951
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 957, Level 16
Points: 957, Level: 16 Points: 957, Level: 16 Points: 957, Level: 16
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Originally Posted by jims shadetree View Post
Driving n fog lights aren't to shine down the road but at area infront of car.our 11 fiesta headlite switch has off, park, n headlites(ol school style) the fogs come on with park lites n stay on with lo n hi beams.lo are on with hi beam also.would sure like that with my focus....it gets awful dark here in Missouri
With the fog lights on if you pull back on the dimmer switch both low, high beams, and fog stay on only thing is you have to hold it not bad unless it a winding road some one will come out with a hack or adapter. Use to be able to pull up wiring diagrams but now they want so much money for them.
Seminoles is offline
Old 07-06-2013, 08:05 PM   #952
valmundo
Fan#: 89368
What I Drive: 2012 Focus SE & 2013 ST2
Points 3,900, Level 39
Points: 3,900, Level: 39 Points: 3,900, Level: 39 Points: 3,900, Level: 39
Level Up 67% Completed
FF Reputation: 12 valmundo Great Standing Member
CD Player in MFT equipped cars - compressor
Not sure if this was mentioned before but I just discovered this feature today. When playing a CD (remember those?) there is an option button that takes you to a screen where you have the option to turn on the built in compressor. This is only available in the Sony stereo system. It is not available when you play music through USB. It is actually quite effective. Does a good job of boosting the signal. There is only an on off switch and no other parameters though.
The bass and midrange is boosted effectively.
valmundo is offline
Old 07-06-2013, 10:17 PM   #953
joshuafail
joshuafail's Avatar
Fan#: 115261
What I Drive: 2013 Ingot Silver SE w/MFT
Points 458, Level 9
Points: 458, Level: 9 Points: 458, Level: 9 Points: 458, Level: 9
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 9 joshuafail Good Standing Member
This seems to be a feature on all of Ford's upgraded sound systems. My '08 Milan had the 8-speaker system, and had the same feature. Ditto with my mom's Mustang, with the Shaker 500.
joshuafail is offline
Old 07-07-2013, 12:08 PM   #954
Anthony2816
Fan#: 116150
What I Drive: 2013 Tangerine Scream ST w/ST3 pack
Points 547, Level 10
Points: 547, Level: 10 Points: 547, Level: 10 Points: 547, Level: 10
Level Up 94% Completed
Forum Activity 2%
FF Reputation: 1 Anthony2816 Good Standing Member
Originally Posted by TheHumbleGeek View Post
...This is because fog lights do not have a cutoff inside the light and can therefore shine into oncoming drivers eyes....
If your fog lights can shine into oncoming drivers' eyes, they aren't aimed correctly. Fog lights should be mounted low, and aimed no higher than parallel to the ground, so that they light up the road with minimal lighting up of the fog. If they're shooting upwards to the point that they'd bother oncoming motorists, then they would also be lighting up the fog directly in front of you, reflecting into your own eyes, and making matters worse than if they weren't on at all.
Anthony2816 is offline
Old 07-07-2013, 12:13 PM   #955
Anthony2816
Fan#: 116150
Forum Activity 2%
Originally Posted by cappa View Post
Sync commands:..."Navigation, 'I am hungry'" It lists the restaurants in your current area on the map.
On my Focus, if I instead say "I am VERY hungry", it only shows all-you-can-eat buffets on the map.
(Okay, that isn't true...but it should be.)
Old 07-07-2013, 03:39 PM   #956
Userdenied
Userdenied's Avatar
Fan#: 116334
What I Drive: '13 Black Ti Hatch 5-Speed
Points 813, Level 15
Points: 813, Level: 15 Points: 813, Level: 15 Points: 813, Level: 15
Level Up 13% Completed
FF Reputation: 5 Userdenied Good Standing Member
Does anyone know what the two slits next to rear defrost and passenger airbag light are for? I saw a photo somewhere on the forums where someone was using them to store cards of some kind.
I checked with my debit card and a parking garage ticket and they fit perfectly. Is this the intended purpose? I couldn't find anything in the manual on it. I wouldn't want to fill them with something if they ended up being vents or something however.
Userdenied is offline
Old 07-07-2013, 03:45 PM   #957
Anthony2816
Fan#: 116150
Forum Activity 2%
Yes, that seems to be the consensus. I have a similar slit in the inside of my glove compartment door, next to the pen holder...do you?
Old 07-07-2013, 03:46 PM   #958
joshuafail
joshuafail's Avatar
Fan#: 115261
Points 458, Level 9
They're called "feature fillers". They're where the active park assist buttons would be, if equipped.
I don't think it's a coincidence that credit cards fit there, though- more like a nice design feature for student ID's, gym membership cards, things of the like. I don't have parking assist on my car (since I can park by myself just fine, thank you very much!) and I keep my Sam's Club membership card in there. Works perfect!
Old 07-07-2013, 04:02 PM   #959
Userdenied
Userdenied's Avatar
Fan#: 116334
I will have to look. I've not looked around inside the glove box beyond stowing the manuals and a few shop towels in there. I'll check that next time I'm in the car. I also need to check to see if there is an AUX port in there, though I'm starting to think after reading that the Ti didn't get one. :(
Originally Posted by joshuafail View Post
They're called "feature fillers". They're where the active park assist buttons would be, if equipped...
I was wondering where Auto Park would be if I had it. Not that I would, I'm with you. I can park on my own just fine. Though the reverse camera is kind of spoiling me. :P
Old 07-07-2013, 04:09 PM   #960
joshuafail
joshuafail's Avatar
Fan#: 115261
Points 458, Level 9
The Aux-in port is in the armrest, next to the USB...
..wait... *runs out to car and checks*
..damn! I've had this car for a month and a half now, and JUST realized that I don't have an AUX port. Shows you how much I would have used it.. Bluetooth streaming audio FTW!
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
