What neat tricks and tips have you've found since owning? - Page 79 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Focus
Old 11-28-2012, 12:55 PM   #781
halfmoonclip
Fan#: 87235
What I Drive: '12 Ingot Silver SEL
FF Reputation: 1 halfmoonclip Good Standing Member
Originally Posted by stang74shelby View Post
Yes they do, as for the Mrs and Daughter refusing... well the daughter ya have control over lol... I think everyone should learn to drive a manual just like the rest of the world does... the US is the only country that as long as you can drive a go cart you can get a license
Stang, you are preaching to the choir. I've a 10 year old Wrangler (that's been in and out of places I could barely walk) with a manual, and I still love to drive the thing, even tho' she's an old girl and you don't want to hurry the shifts our of consideration for the synchros. In low range, you can start in 5th if you wish.
halfmoonclip is offline
Old 11-28-2012, 12:59 PM   #782
halfmoonclip
Fan#: 87235
Originally Posted by suss6052 View Post
All 2012+ Ford Focus models with the automatic transmission use the Powershift DCT with or without select shift. They all also have advancetrac stability control to meet the federal guidelines.
Suss, I'm starting to suspect that two things are going on with mine.
One may be the clutches, as I'm getting rough engagement, but I'm also starting to think that the stability/traction/antilock is kicking in when is should not be. Maybe one is feeding the other; the clutch engages roughly, and the stability discovers wheelspin and buzzes the brakes.
Now if the rocket scientists at the dealership can figure it out...
Thanks,
Moon
Old 11-28-2012, 01:12 PM   #783
suss6052
suss6052's Avatar
Fan#: 95752
Points 9,615, Level 65
Points: 9,615, Level: 65 Points: 9,615, Level: 65 Points: 9,615, Level: 65
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
Thanks,
Moon
If the clutch is slipping and there is a sufficient difference between the input and output shaft speeds this could cause the traction control at least to over react and try to reign in the "wheel spin" which would cause a feedback loop. A quick inspection first by removing the undertray/ aero shield would look for an external sign of the internal leak, but that might not show anything unless the leak had gotten sufficiently bad enough to show outside the case and the bell housing.
That is if its a clutch issue and not a mechatronic actuation issue, but the more common failure point has been the input/ output shaft seals weeping transmission fluid onto the clutch plates destroying them. However at least one rear main seal leak was also reported to have destroyed the clutch pack as well.
suss6052 is online now
Old 11-28-2012, 05:49 PM   #784
halfmoonclip
Fan#: 87235
Suss, the issue has gotten progressively worse over time; (I'm at 13K); would that follow the 'leaking seals' theory?
Thanks,
Moon
Old 11-28-2012, 06:21 PM   #785
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,310, Level 35
Points: 3,310, Level: 35 Points: 3,310, Level: 35 Points: 3,310, Level: 35
Level Up 74% Completed
Forum Activity 6%
FF Reputation: 13 PratoN Great Standing Member
Take off the aero shield on the bottom of the car and check for an oil leak where the bell housing is. It would be slick - not thick/honey-colored (that's rust inhibitor). If there is an oil leak, take it to the dealer for TSB 11-12-13, if not... you're SOL.
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 96k miles and counting...
PratoN is offline
Old 11-28-2012, 06:27 PM   #786
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 33%
Thanks,
Moon
From what I've heard it seems to be the case that if something is going wrong with the seals it gets worse over time. I can't diagnose the car over the internet though, and its likely that the dealer will try to claim its normal, but a slipping clutch and or other drivability issues seem to be signs that something is badly wrong.
Old 11-28-2012, 06:35 PM   #787
halfmoonclip
Fan#: 87235
The car is currently in my dealer's clutches; the service manager seems a decent enough guy, but the shop is kinda clueless. They managed to screw up an oil change if that tells you anything.
As noted in some of the above, the loaner I'm currently using displays none of the unpleasant stuff.
I'll touch base with the garage soon (the use of the loaner is pretty open ended) and discuss the clutch thing; it's been on my suspicion list.
Unhappily, the first time they tried it for a day or so, they claimed they couldn't find any problems. I'm afraid this time the company line will be 'they all do that'.
Moon
Old 11-29-2012, 01:28 PM   #788
TiPilot
TiPilot's Avatar
Fan#: 93667
What I Drive: 2012 Ingot Silver Ti Hatch
FF Reputation: 1 TiPilot Good Standing Member
Originally Posted by gtncpa View Post
There is a setting to turn the voice off on the navigation. All you get are the "bongs". I find this very helpful if I sort of know where I am going but I am not 100%. If I am going to a new place I leave the voice on.
How?
I know you can turn off ALL noises, but how do you get rid of Sync Lady and keep only the chimes?
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg
Build Date: 12/2/2011 | New APIM: 4/4/2012
MFT: Factory v2.11, 3/14/12 Web -> v3.0.2, 9/24/12 Web -> v3.2.2, 1/24/13 Web -> v3.5.1, 8/13/13 Web -> v3.6
TiPilot is offline
Old 11-29-2012, 01:30 PM   #789
gtncpa
gtncpa's Avatar
Fan#: 86143
What I Drive: 2012 Black Titanium Hatch
Points 1,526, Level 22
Points: 1,526, Level: 22 Points: 1,526, Level: 22 Points: 1,526, Level: 22
Level Up 26% Completed
FF Reputation: 2 gtncpa Good Standing Member
There are two settings. One turns off her "Say a command" and one turns off the turn by turn. Press the gear button next to the house on the bottom of the screen and look for navigation options. If you dont see it I will check in my car later and take a pic of the screen.
gtncpa is online now
Old 11-29-2012, 01:42 PM   #790
TiPilot
TiPilot's Avatar
Fan#: 93667
Ahh, gotcha. I had a feeling it was buried somewhere in the Settings. I'll have to take a look when I drive home tonight. Good catch!
TiPilot is offline
