What neat tricks and tips have you've found since owning? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-11-2011, 11:30 PM   #31
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
I really love driving in S mode now, downshifts more aggressively when braking instead of keeping you under 2k RPM ALL the time, and doesn't shift nearly as quickly when accelerating. I now drive in S until I'm cruising and then I slide the shifter into D, no trigger needed.
Also... I don't know if that feature is new to many of you guys but Automatics have been able to slide without the button depressed from N or R to D for YEARS...
Also, this car can't go from D to N without depressing the trigger like other Auto's... my reasoning is that since our car doesn't coast in neutral when decelerating, it downshifts and uses engine braking (how cool, right?) that putting it into N would be detrimental to the dual-clutch setup.
Sonic Crew #28
feta_mgp is offline
Old 08-12-2011, 11:25 AM   #32
pra2veen
pra2veen's Avatar
Fan#: 86954
What I Drive: 2012 Focus SE Hatch (Kona Blue)
FF Reputation: 1 pra2veen Good Standing Member
Originally Posted by Armen View Post
Can I ask, why do you do this?
Just out of habit from using the manual and I keep my foot on the brake anyway. I just don't like that normal autos usually keep trying to pull you forward (hard to explain) :)
Originally Posted by elwood125 View Post
doesnt amount to much but today i discovered i could use the "pockets" made to the rear hatch trim panel to shut the hatch without having to put my hands on the outside of it. Hey, its the little things that matter..
I discovered the handles too and have been trying to use them ever since. Quite helpful and a nice touch
pra2veen is offline
Old 08-12-2011, 11:44 AM   #33
KMT100612
KMT100612's Avatar
Fan#: 88312
What I Drive: 2012 Sterling Gray Ford Focus SE
FF Reputation: 1 KMT100612 Good Standing Member
Originally Posted by Albarry View Post
I found a trunk button on my se sedan sport its really hidden above the licence plate light. and the dealer told the only way to open the trunk is to use the button on the key. it pritty sweet.
My Dealer told me the exact same thing! I was thinking that it was weird there was no trunk latch/button somewhere else, until like you I found it.
KMT100612 is offline
Old 08-12-2011, 05:14 PM   #34
TitaniumGero
TitaniumGero's Avatar
Fan#: 88508
What I Drive: 2012 White Platinum Titanium Focus
FF Reputation: 3 TitaniumGero Good Standing Member
Originally Posted by TitaniumFred View Post
I found that every window, when controlled from the driver's side, has one-touch up and down.
My SE Sport doesn't have this. I believe it's only on higher trims
TitaniumGero is offline
Old 08-12-2011, 05:46 PM   #35
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
Someone should try the roll up/roll down all windows trick!
1. Put the key in the driver's side door (is there even a keyhole anymore?).
2. Turn the key to the unlock position and hold it there for a few seconds to unroll all the windows
3. Turn the key to the lock position and hold it there for a few seconds to roll up all the windows.
Not a clue if it will work, but it seems to be catching on with lots of cars that I've seen. Doesn't work on my 2011, though :(
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Old 08-12-2011, 05:54 PM   #36
lscrx
Fan#: 41668
What I Drive: 2012 Focus SE hatch 5mt
FF Reputation: 2 lscrx Good Standing Member
True, the SE only has one-touch down on the drivers window.
Posted via FF Mobile
lscrx is offline
Old 08-12-2011, 05:58 PM   #37
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,083, Level 34
Points: 3,083, Level: 34 Points: 3,083, Level: 34 Points: 3,083, Level: 34
Level Up 22% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
Originally Posted by 2011 SE View Post
Someone should try the roll up/roll down all windows trick!(
I just stumbled upon this today on another forum. I'm curious if the Titanium (push-start) has this feature. Because it doesn't have a key, I think I can hold the door lock/unlock buttons on the key fob? I'll be back with an update when I get off work.
PratoN is online now
Old 08-12-2011, 06:06 PM   #38
MGDeftones
Fan#: 86854
What I Drive: 2012 TI
FF Reputation: 1 MGDeftones Good Standing Member
It doesn't work. I'm sitting at my desk at work looking at my car that is right outside the window (about 15 feet away).
MGDeftones is offline
Old 08-12-2011, 06:08 PM   #39
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,491, Level 21
Points: 1,491, Level: 21 Points: 1,491, Level: 21 Points: 1,491, Level: 21
Level Up 91% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Originally Posted by eyeballeater View Post
I never knew about it either till my daughter found it! I was like "why did you touch the keys?" I didn't daddy, you just push right here. Nothing like being schooled by a 7 year old!
I found it buy being lazy and just messing around i went to put something in the trunk and left my keys in my shop and i just tried to open it anyways and it worked lol i use it all the time now.
Hah, finally found it. Even after all of you described the location it took me a while. Really well-hidden but convenient as hell!
copernicium112 is offline
Old 08-12-2011, 06:16 PM   #40
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 3%
Bullocks! I'll try taking the key of out my key fob and holding it in lock/unlock.
Or holding the door unlock handle? There's got to be a way! (Or not... 1-press window opening is fairly luxurious as it is.)
