What neat tricks and tips have you've found since owning? - Page 37 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 10-22-2011, 03:36 PM   #361
JRicky
Fan#: 84998
What I Drive: 2012 Kona Blue SE Sport
FF Reputation: 1 JRicky Good Standing Member
I wish the electric steering had more weight at speed though...compared to driving my mustang it doesn't make you feel like you're going as fast as you are until you get tire squeal and traction control ( yes, I've pushed the car a bit..) :)
JRicky is offline
Old 10-22-2011, 03:38 PM   #362
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Originally Posted by diesel_travis View Post
OK, I'm pretty sure that this isn't in the manual...
One thing I noticed while running cables to the trunk was the massive amount of sound deadening material (at least compared to my previous cars):
* There's a big thick layer of padding under the carpet in front, (I also noticed that the dead pedal area was just a wedge of styrofoam stuck under the carpet, ha)
* Probably not designed for sound-deadening, but under the first layer in the trunk there's about about a 1.5" layer of styrofoam (to match the height of the spare) but it has rectangles built-in that seemed to be designed to be cut out for audio equipment, my amp fit perfect in one
* Under that styrofoam layer, you can see various spots where vibration-damping material has been attached to the body
* In the rear wheel areas, in the trunk, beneath the carpet, you can see a large piece of foam inserted between the outside body panels
Explains why this car is so much quieter than my previous cars which had none of this nice stuff.
On models with a full-size spare (Titanium-only, maybe?) the foam is much thicker (to match the height of the bigger tire). My tires are 235, so fairly wide. Those pockets are a good 5" deep.
With the upgraded sound system the amp actually *does* sit in one, from the factory.
hotleadsingerguy is offline
Old 10-22-2011, 05:45 PM   #363
Elizabeth
Elizabeth's Avatar
Fan#: 89280
What I Drive: '12 Yellow Focus SE stick, 17"rims
FF Reputation: 14 Elizabeth Great Standing Member
I saw a vehicle with 'puddle lamps' last night. (not a Focus)
What a useless feature? IF the lamp had a directional beam to the full door sides and bright enough to really see anything on ground anywhere near door. but they just seem to be little 'puddles' of light. not worth much.
Maybe in a pitch black area they would be of some use?
Also saw a Focus SEL sedan with the added interior LEDs. nice. I liked.
Elizabeth is offline
Old 10-22-2011, 06:32 PM   #364
fatfocus
fatfocus's Avatar
Fan#: 90985
What I Drive: 2012 Frosted Glass SEL Sedan
FF Reputation: 1 fatfocus Good Standing Member
Did some playing around
Where I live, DRL's are required by-law. My previous Focus had the foglights modded so the fogs were the DRL's. My 2012 SEL has the automatic feature for the headlights, but i did some playing around, turned the lights to the Parking Lights setting, and turned on the Foglights.....it's kinda cool if you ask me.
Now: 2012 SEL Sedan, with Selectshift Transmission, 17" Polished Aluminum Rims, K&N Air Filter
Previously: 2000 White ZTS, 15" Painted Aluminium Rims
www.focuscanada.net member
fatfocus is offline
Old 10-23-2011, 11:38 AM   #365
wilsonfocus86
wilsonfocus86's Avatar
Fan#: 23099
What I Drive: 14 Fusion 2.0
FF Reputation: 3 wilsonfocus86 Good Standing Member
Originally Posted by hotleadsingerguy View Post
Err...how? I can't turn on my foglights unless the headlights are on. The icon never displays and the foglights don't turn on.
You turn the "dial" over one to put the parking lights on, then press the fog lights button on, BAM!!!!! (titanium model..not sure on the others)
Posted via FF Mobile
wilsonfocus86 is offline
Old 10-23-2011, 11:41 AM   #366
feta_mgp
feta_mgp's Avatar
Fan#: 88210
It's this way with the SEL too.
Sonic Crew #28
feta_mgp is offline
Old 10-23-2011, 02:36 PM   #367
dasilvarsa
dasilvarsa's Avatar
Fan#: 89551
What I Drive: 2012 2.0 Gdi Trend
FF Reputation: 2 dasilvarsa Good Standing Member
Puddle lamps or reflectors on the doors are for safety.
If you are parked and open the door, the driver of a vehicle driving in the lane next to you will see the lamps and will hopefully avoid crashing into your door.
They are not meant to be for illumination.
2012 Focus 2.0 GDI Trend (RHD Euro Focus with US Engine)
dasilvarsa is offline
Old 10-23-2011, 04:10 PM   #368
Fine Focus
Fine Focus's Avatar
Fan#: 88092
What I Drive: 2012 Sonic Blue Focus 5 Door
FF Reputation: 1 Fine Focus Good Standing Member
Same on the SE
2012 Sonic Blue SE 5 Door
5 Speed, sport, winter packages
Fine Focus is offline
Old 10-23-2011, 04:13 PM   #369
Fine Focus
Fine Focus's Avatar
Fan#: 88092
Same with the SE.
Old 10-23-2011, 04:17 PM   #370
wilsonfocus86
Fan#: 23099
Originally Posted by Fine Focus View Post
Same with the SE.
Cha Ching, so no one should have problems [bootyshak
"If in doubt.. Flat out." - Colin McRae
