What neat tricks and tips have you've found since owning? - Page 125 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2013, 02:03 PM   #1241
Userdenied
Userdenied's Avatar
Fan#: 116334
What I Drive: '13 Black Ti Hatch 5-Speed
Points 839, Level 15
Points: 839, Level: 15 Points: 839, Level: 15 Points: 839, Level: 15
Level Up 39% Completed
FF Reputation: 5 Userdenied Good Standing Member
Originally Posted by TheHumbleGeek View Post
Uh... What? Unless one's focus is equipped with citystop, fuel to the engine is never cut off otherwise rpms would be zero. In neutral, mine ran at around 600rpm at minimum...
Sent from SGH-I747M Via FF Mobile, Care of CSIS ;-)
I'm speaking while in gear. My understanding was that on modern engines if you were in gear but coasting (Foot off the throttle) the computer would stop feeding fuel because you aren't asking for power? I've no source for this other than having read it various places whenever this exact subject comes up.
Userdenied is offline
Old 10-07-2013, 02:10 PM   #1242
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
Points 522, Level 10
Points: 522, Level: 10 Points: 522, Level: 10 Points: 522, Level: 10
Level Up 44% Completed
Forum Activity 3%
FF Reputation: 3 MetalMuffins Good Standing Member
What they are saying is that when in gear, but off the gas, the engine's fuel is cut, but the momentum of the car keeps the motor spinning. If you put the car in neutral, the engine is than supplied fuel to idle.
2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, 180 Stat, Custom SCT Tune by Tom @ Focus-Power
MetalMuffins is online now
Old 10-07-2013, 02:47 PM   #1243
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,814, Level 76
Points: 13,814, Level: 76 Points: 13,814, Level: 76 Points: 13,814, Level: 76
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
To the best of my understanding, this is correct.
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 10-07-2013, 03:19 PM   #1244
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
True above 1500 RPM.
Hatch Nation #90
TboneZX3 is offline
Old 10-07-2013, 04:18 PM   #1245
Gi_Jo_Nathan
Gi_Jo_Nathan's Avatar
Fan#: 98931
What I Drive: 2012 Sonic Blue 5Door MTX
Points 368, Level 7
Points: 368, Level: 7 Points: 368, Level: 7 Points: 368, Level: 7
Level Up 36% Completed
FF Reputation: 3 Gi_Jo_Nathan Good Standing Member
And at certain speeds I believe..
Jonathan
12 SE HB MTX, IE Tuned, Snorkel DLT, Green Filter(Gray), custom 2.5" cat-back w/borla, Steeda RSB & Short Shift Bracket, JBR Solid Shifter Bushing's, MS3 RMM w/Corksport Inserts, Ti Heads, Redline Tuning Hood Struts, De-chromed
Gi_Jo_Nathan is offline
Old 10-07-2013, 05:03 PM   #1246
Romans5.8
Fan#: 119488
What I Drive: 2014 Tuxedo Black Ford Focus SE
Points 582, Level 11
Points: 582, Level: 11 Points: 582, Level: 11 Points: 582, Level: 11
Level Up 64% Completed
FF Reputation: 4 Romans5.8 Good Standing Member
That's true of most modern, completely computer controlled engines. Basically turns your engine into a giant, gravity powered air pump.
I do wonder though; which is more efficient. Not burning any fuel BUT slowing the vehicle with the drag of the engine, OR idling the engine with small amounts of fuel whilst in neutral (or with the clutch in) with less drag and thus the ability to coast longer without needing to apply throttle?
2014 Ford Focus SE, Tuxedo Black (Sport pkg, 5spd manual)
2014 Ford Mustang Premium Convertible
2006 Kawasaki Vulcan 900 Classic LT, Thunder Blue / Graphite Two-Tone
2011 Honda Shadow Aero, Candy Red (Wife's Bike)
Romans5.8 is offline
Old 10-07-2013, 07:06 PM   #1247
Userdenied
Userdenied's Avatar
Fan#: 116334
Using the engine to slightly slow you down while saving fuel is better before coming to a stop then idling the engine to give yourself a longer coast distance. Given that most of the time people spend coasting is before a stop I would think the current setup is the most efficient.
Old 10-10-2013, 02:28 AM   #1248
roderunner
Fan#: 108779
What I Drive: 2014 White Plat. Fusion 1.6L stick
Points 113, Level 2
Points: 113, Level: 2 Points: 113, Level: 2 Points: 113, Level: 2
Level Up 26% Completed
FF Reputation: 1 roderunner Good Standing Member
With a manual, it depends on the circumstance. In situations where you will not need the brake, coasting is more efficient. In a series of repeated 0.8* mile downhill runs (resetting the MPG ahead of each run), I got a 4.1 MPG gain by coasting and a 3.3 MPG gain by idling, then throttling as necessary to maintain comparable ETs. Engine braking adds unwanted drag ~ more fuel consumed.
BUT if you need the brake to slow (steeper hill or stop ahead), it is better to take the foot off the throttle and leave it in gear. The closed throttle will save gas and brake wear.
(* 3.3 mile loop including .8 mi. downhill; reset MPG 1/4 mi. ahead of run; start and end MPG noted for each run and averaged; beginning speed 55 MPH, end speed 45 to 50 MPG, temp. 63degrees F, 87 Octane gas; no traffic effect. Results were consistent over 4 runs.)
roderunner is offline
Old 10-10-2013, 07:25 AM   #1249
MetalMuffins
Fan#: 107135
Forum Activity 3%
Interesting. Good work on trying to get repeatable data driven results. The only thing i would be wary about is how accurate the built in MPG calculation would be.
It would be nice to see a data log of the tests that would be able to tell us exact fuel consumption for the runs, and allow us to get (possibly) more accurate results.
Like I said through, good work on the tests / data gathered so far. Nice to see someone actually testing this.
Old 10-10-2013, 07:54 AM   #1250
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
There is a discussion about coasting to a stop in gear and in neutral with logs there are a few pages on this topic.
Found Here
Seminoles is offline
