What neat tricks and tips have you've found since owning? - Page 101 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-11-2013, 10:51 AM   #1001
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by jims shadetree View Post
Also my focus came with a piece of hard black plastic in glove box that sits on runners n my manual sits on that.its rode up there for 1000 mi so far n still there.im guessing if yalls don't have it probly dealer threw away not knowing what it was
I don't believe that black piece of plastic was in the '12s.
Hatch Nation #90
TboneZX3 is offline
Old 07-11-2013, 11:47 AM   #1002
iAmTitanium
Fan#: 114637
What I Drive: 2012 Silver Focus Ti Sedan
FF Reputation: 0 iAmTitanium Poor Behavior Needs Improvement
Originally Posted by gtncpa View Post
I have MFT in my car. The service loaner I got from the dealer did not. The AC was in dual mode. Without MFT I did not know how to get out of dual mode. All it took was to hold in the driver side control for about 2 seconds and they passenger setting became the same as the driver.
It also works in my car! It is very intuitive and much easier to use then going into the touch screen.
I never use the touch screen for the air con, also single user mode is attained by simply moving the pass side to the driver temp and then just use the driver
2012 Focus Titanium MTX-75 w/Nav
iAmTitanium is offline
Old 07-11-2013, 12:54 PM   #1003
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,227, Level 67
Points: 10,227, Level: 67 Points: 10,227, Level: 67 Points: 10,227, Level: 67
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 26 suss6052 Great Standing Member
As far as I remember this is not true. Once the second zone has been set to a seperate temperature the only way to return it to the same temperature as zone one is to depress the auto button. Simply setting the temperature back to the same as zone one would not return the car to single zone operation.
Temperature Control
You can set the temperature between 60°F (15.5°C) and 85°F (29.5°C)
in 1°F (0.5°C) increments. In position LO, 59°F (15°C), the system
switches to permanent cooling. In position HI, 86°F (30°C), the system
switches to permanent heating.
Note: If you select either position LO or HI, the system does not
regulate a stable temperature.
Mono Mode
In this mode, the driver’s control sets the temperature for both sides. If
you adjust the setting using the rotary control on the driver’s side, the
system sets the passenger’s side to the same temperature.
Switching Mono Mode Off
Select a temperature for the passenger’s side using the rotary control on
the passenger’s side. Mono mode automatically switches off. The
temperature on the driver’s side remains unchanged. You can now adjust
the driver’s side and passenger’s side temperatures independently of
each another. Both temperature settings appear in the display.
Switching Mono Mode Back On
Press and hold the AUTO button. The passenger’s side temperature
changes to the driver’s side temperature setting.
2013 Ford Focus Owners guide 3rd printing page 144
suss6052 is online now
Old 07-11-2013, 04:16 PM   #1004
MrMU13
Fan#: 116171
What I Drive: 2013 Silver Focus Hatch SE 5 speed
FF Reputation: 1 MrMU13 Good Standing Member
I hate that I can't access Bluetooth audio/USB from a physical button and I have to tell Sync every time I want to use either feature. Luckily this morning I discovered that I only have to say it once and then you can switch back from Radio/SIRIUS to Bluetooth/USB/Line In by hitting the AUX button.
MrMU13 is offline
Old 07-12-2013, 08:22 AM   #1005
c5karl
Fan#: 105687
What I Drive: 2013 Hatchback SE, 5-speed, silver
Points 70, Level 1
Points: 70, Level: 1 Points: 70, Level: 1 Points: 70, Level: 1
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 1 c5karl Good Standing Member
Huh. My AUX button always reverts to USB when I restart the car. But that might be because I have a thumb drive plugged into the USB jack. Now I want to test what happens if I yank the thumb drive.
It would be nice if it remembered the last source without my having to do this, though.
My car is a Job 1 2013 SE with SYNC but no MFT.
c5karl is offline
Old 07-12-2013, 10:32 AM   #1006
MrMU13
Fan#: 116171
I don't use a jump drive, just plug my iPhone in for longer trips. When I do have it plugged in, the AUX button acts the same as yours and goes to USB automatically. I then use the controls on the steering wheel to switch between USB, Line In, and CD.
Focus SE SYNC, no MFT
MrMU13 is offline
Old 07-17-2013, 10:27 AM   #1007
OhFFS
OhFFS's Avatar
Fan#: 114209
What I Drive: 2013 Ingot Silver Focus SE
FF Reputation: 1 OhFFS Good Standing Member
I ended up creating my own shelf by cutting down an old license plate to keep my manual in place.
It's fitting, since that license plate was on my Mk I Focus for seven years. That car almost never let me down; here's hoping that old license plate acts like a good luck charm for the new car.
OhFFS is offline
Old 07-17-2013, 11:07 AM   #1008
jims shadetree
jims shadetree's Avatar
Fan#: 116036
What I Drive: 2013 tuxedo black 5 spd hatch se
FF Reputation: 1 jims shadetree Good Standing Member
Great idea...like I always say...quality shadetree baby.I used one of the original california black plates from my ol dart to mount the stereo in its glove box.
Hatch nation #66
Gettin my kicks on route 66!
jims shadetree is offline
Old 07-17-2013, 04:37 PM   #1009
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,213, Level 28
Points: 2,213, Level: 28 Points: 2,213, Level: 28 Points: 2,213, Level: 28
Level Up 43% Completed
Forum Activity 3%
FF Reputation: 3 FordIVTteam Good Standing Member
Originally Posted by joshuafail View Post
... It's definitely not in the glovebox, I just checked- maybe it's deleted in favor of the A/V ports- use and RCA to 3.5mm cable instead? ...
Hello, joshuafail,
The MyFord Touch system does not come equipped with an AUX port, but using an A/V adapter should work fine. Only the video functionality is limited by vehicle motion - audio should be unaffected.
Antonio
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 07-17-2013, 08:34 PM   #1010
joshuafail
joshuafail's Avatar
Fan#: 115261
What I Drive: 2013 Ingot Silver SE w/MFT
Points 484, Level 9
Points: 484, Level: 9 Points: 484, Level: 9 Points: 484, Level: 9
Level Up 68% Completed
FF Reputation: 9 joshuafail Good Standing Member
Originally Posted by FordIVTteam View Post
Hello, joshuafail,
Antonio
Great to know, thanks Antonio!
joshuafail is offline
