2012 Focus Custom Ram Air How-To - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-25-2011, 02:20 AM   #31
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
FF Reputation: 4 Tony407 Good Standing Member
Overall, a great project!!! And it sounds very nice. That microphone is almost as big as your car!
Now that you've had a chance to drive it awhile, I'm very interested in hearing how the throttle response is. The Focus is one heck of a slug off the line until you're up to 3k or 4k rpm. Has the intake made much of a difference in the initial responsiveness at low rpm?
Tony
Tony407 is offline
Old 08-25-2011, 09:12 AM   #32
pra2veen
pra2veen's Avatar
Fan#: 86954
What I Drive: 2012 Focus SE Hatch (Kona Blue)
FF Reputation: 1 pra2veen Good Standing Member
Originally Posted by newmission View Post
http://farm7.static.flickr.com/6075/6075008082_4841e5a417_z.jpg
Oh, and a little custom vinyl-age.
http://farm7.static.flickr.com/6064/...d26332cb_z.jpg
you should add these pics to the OP too. Looks great btw. I wish I had the patience to do all that :)
pra2veen is offline
Old 08-25-2011, 10:57 AM   #33
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
Good call! Done. :)
Tony
lol The mic is a standard 1" diaphragm cardioid condenser studio mic. But may be big if you're not used to seeing one. :)
The audio the mic picked up was VERY bassy. I had to EQ it back just a bit to point out the details at WOT. Just noting that to point out this setup is very throaty. :) NO JDM :)
I have noticed right off the bat actually that the engine seems to run through out the RPM band more smoothly. Response is quicker certainly! And once you're up around 50mph and hit WOT it's taking in all the fresh air it can handle. I've scared myself a couple times just holding the throttle enjoying the pull. :) I have also jumped up about 5 mpg too. I was averaging 28.5, and now around 34.5 if I go easy. ;)
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 08-25-2011, 10:47 PM   #34
matthoma
Fan#: 88033
What I Drive: 2012 Ti Hatch
FF Reputation: 1 matthoma Good Standing Member
I'm loving this project! You pretty much have me convinced it's going to get done when I have some time.
matthoma is offline
Old 08-30-2011, 11:56 PM   #35
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,314, Level 77
Points: 14,314, Level: 77 Points: 14,314, Level: 77 Points: 14,314, Level: 77
Level Up 66% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
It is hard to know WHAT the airflow over the front of the 2012 Focus is.
The Nascar and other types use theose strange "V" like cuts INTO the body for air. NOT a hole in the front of the body. (and for a good reason.)
Now if you had a wide hood scoop and the airflow up over the hood went right at the scoop. yeah.
I had played with a hole in the front bumper on my SVT Contour, took OUT the driver side Fog light and stuck a gizmo there to add to the air pressurization of the fender well where the SVT intake sucked it's air from. Both ouside guiding in, and inside to 'bend' the airflow up (and remove water)
As nice as the cool looking mod is, no way to actually know if it does any good without some airflow tests. (mine either, i was just messing around...).
Sorry.
(I do have to agree the tube is narrow for the purpose..) Maybe a 4" inner diameter tube would be more effective, but then it would not fit?... The sides of the tube itself restrict flow at the boundary, and with that small of a circumference, ??
I plan on just getting the K&N filter for the intake.
Since i no longer plan on going 140mph.. (getting too old to fool around THAT much) The K&N should give me a better intake sound, and power? over the average.
i would have to look in the area the air is pulled in to see if any added air could be available to the air cleaner.. But not HOT AIR, or give a better sound.
((the HOT AIR is NOT meant as an insult, it really is just avoid the hot air in the engine compartment..honest.))
I had a V6 Mystique before the Contour SVT, and THAT car had a fantastic sound adding the Contour SVT intake to it. The cool moan of the intake (with a lot of throttle) could and DID scare pedestrians..LOL
Added; polishing the throttle body outer lip to a bell to avoid any lip or edge, and if the inner is not lined up perfectly , fix it to be so with no lip or protruding edge... could also do a lot to assist in making a little power. NOT the full inner surface, as it is coated to not get sticky. Only the very outer or inner 1./4 inch or so,
Line up those surface mating lines for perfect smooth flow.!
Elizabeth is online now
Old 08-31-2011, 05:32 AM   #36
newmission
newmission's Avatar
Fan#: 84688
Sorry.
I have no idea what you just said. (in my best Napoleon Dynamite impression)
Not to be rude, but every post that I have read by you Elizabeth has been confusing. And so far this one takes the cake. First you brought up a good argument about the difference between a circle and slotted intake port. I have seen slotted intake ports on ram air of the new Cobra. But then you got lost in the woods talking about hot air and sound? We're catching cold air rushing at the front of the car, where is the hot air coming from? And if your argument is all performance minded, then who cares about sound? Start with a well designed intake first, sound is just a benefit.
Hatch Nation #110
Get you some!
Old 08-31-2011, 05:37 AM   #37
Tony407
Tony407's Avatar
Fan#: 85289
Not knowing what Elizabeth intended, but an intake for me is 75% for the sound and the other 25% is performance.
Tony
Tony407 is offline
Old 08-31-2011, 10:31 AM   #38
CrazyDave
CrazyDave's Avatar
Fan#: 86019
What I Drive: 07 Shelby Mustang GT, 2012 Focus
FF Reputation: 1 CrazyDave Good Standing Member
Not sure if this makes sense. Is there a way to channel some nice dense
cold air produced by the cars A/C into the intake?
That would boost performance for sure, I think. It sure makes a difference in
NHRA Pro Stock. Those carb cars perform much better in cool weather.
2012 Hatch SE, 5-speed, Rapic Spec 203A, Sport Package, 17's, Silver, Tuscany.
CrazyDave is offline
Old 08-31-2011, 10:32 AM   #39
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Forum Activity 20%
Yes, the intent is 'to catch cold air rushing at the front of the car' but the reality may be very different. Wanting and wishing is not doing. that airflow may even be negative for all you know at the exact point this modified intake is located.
I just wanted to mention that very real possibility.
Just becuse you think it is in the front so the air will be pushed in, is not true.
It MIGHT be true, but you have zero way of knowing if so or not. Theair off the front end past the angled front may just as well be negative air pressure over the opening at speed.
Old 08-31-2011, 11:50 AM   #40
newmission
newmission's Avatar
Fan#: 84688
lol You have a very broken way of expressing your thoughts there Elizabeth. lol
However, from what I gather, you are trying to describe a venturi. lol If that is the case, your point would only be valid if the hose was on a perpendicular angle to the point of draw. And would require a "passing" air flow to that point. This is true with many cold air "intakes" that are located in the fender. They become cold air "sucks", as you pointed out.
I have very real proof that this intake is not "negative" by the rather large amount of bugs that gather in my pleats, air box, and on the front of the vehicle for that matter. This is the reason for the Outerwears pre-filter, of which FSWerks is now providing on their website. You're welcome FSWerks.
Any more questions? Physics class dismissed. lol
Hatch Nation #110
Get you some!
