2012 Focus Custom Ram Air How-To - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2011, 04:06 PM   #131
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,013, Level 33
Points: 3,013, Level: 33 Points: 3,013, Level: 33 Points: 3,013, Level: 33
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 11%
Originally Posted by SimonSellsAustin View Post
Ok guys, I just pulled my airbox and I have an active shutter ram air!
I need to go look at my car!
PratoN is online now
Old 10-07-2011, 04:22 PM   #132
SimonSellsAustin
SimonSellsAustin's Avatar
Fan#: 90594
What I Drive: 2012 Sonic Blue SE hatch.
FF Reputation: 2 SimonSellsAustin Good Standing Member
I could be wrong but that's what this looks like.. it looks like an active shutter system that allows air to go through the radiator.. It also appears to direct air flow up and through the airbox. It appears to pull air from behind the ford grill logo as well. That's alot of ram air already designed by ford engineers. Again, I could be speculating and be completely wrong but I think this ram air from the factory should be more than enough.
On the Last 2 times I made a ram air system I actually used a 4inch to 3inch adapter to collect air in a header fashion 4 into 1 with the 1 being a 3 inch to 2 inch pipe going into the air collector/ stock box.
example of previous collector design using a header as the inspiration=
"May the wind always be at your back and the sun always upon your face and may the wings of destiny carry you aloft to dance with the stars."
~ Boston George
SimonSellsAustin is offline
Old 10-07-2011, 05:03 PM   #133
STL 314
STL 314's Avatar
Fan#: 87196
What I Drive: 2012 Ti
FF Reputation: 2 STL 314 Good Standing Member
that is not a ram air, that's the active shutter system. could be wrong, but i don't think it has anything to do with the intake
I'm an Eco Champion
STL 314 is offline
Old 10-07-2011, 05:53 PM   #134
SimonSellsAustin
Fan#: 90594
It appears to force air up and into the intake channels. It also appears to intake air from behind the ford emblem.
~ Boston George
Old 10-07-2011, 08:31 PM   #135
Craig9080
Fan#: 89667
What I Drive: 2012 Titanium, Sterling 401A 18"
Points 720, Level 14
Points: 720, Level: 14 Points: 720, Level: 14 Points: 720, Level: 14
Level Up 20% Completed
FF Reputation: 1 Craig9080 Good Standing Member
This has already been talked about previously in this same thread. The active part wasn't mentioned, but how he stock air box gets its air has already been thoroughly discussed...and every stock airbox intake system is the same. It is still an abhorrently small channel for the air to some through and is akin to breathing through a straw. Whether or not newmission's mod actually induces pressure is debatable, but the fact of the matter is the temperature of the air in the airbox drops to almost to dead ambient with his mod as opposed to much higher without.
Craig9080 is offline
Old 10-08-2011, 09:12 AM   #136
SimonSellsAustin
Fan#: 90594
Craig9080= I went back and re-read the thread for this.. and it's touched on for one post without much inspection. Elizabeth started getting into a noise reduction within the stock system behind the ford emblem but didn't go into detail on how to modify it to perform better.
Some people are simply removing the resonator and that's what I began to do but quickly decided it would make noise and loose effectiveness.
Has anyone really looked at the way it's taking in air from behind the ford emblem? What about the interaction with the active shutter system? Can that be modified or enhanced to be better used?
I'm not debating that adding a scoop and toob will increase the amount of air going in but I'm wondering if the stock air intake should be deleted or modified to help increase airflow. If it is actually a detriment then maybe a stock air intake delete is in order (just hacksaw the toobs and cover with duct tape). Then the stock air could simply direct cool air into the engine bay.. and the new ram system will serve the modified airbox.
*update- I pulled back the shroud and inspected the air intake further...
From what I'm seeing here if you don't delete this stock intake it will just screw up your new ram air system. Looks like a cold air intake that's feeding off of air leaks in front. No ram system at all.. not pulling air from the grill section. Flaps keep fresh air from going up while directing air towards the radiator. Simple solution would be to use duct tape over the tube between air pipe and airbox (That way the inlet is covered and engine suction won't pull your tape off the inside of the box. It also keeps the ram air from blowing out the tube into the grill section.
~ Boston George
Last edited by SimonSellsAustin; 10-08-2011 at 10:26 AM. Reason: *update- I pulled back the shroud and inspected the air intake further...
Old 10-08-2011, 12:22 PM   #137
Craig9080
Fan#: 89667
Take some measurements with and without the stock intake blocked off when you get your ram-air up and running and we can make a comparison.
Old 12-30-2011, 07:13 PM   #138
Ghost71
Ghost71's Avatar
Fan#: 91701
What I Drive: 2012 black Ti hatch
FF Reputation: 1 Ghost71 Good Standing Member
Maybe I'm missing something. The 3" hose is in the bottom of the airbox, leading down to the front. But the KN filter is connected directly to the induction hose/throttle body. With out the top of the airbox sealed it is not sucking through the 3" hose. Just engine bay hot air???
The 3" hose should have the filter on the end and connected to the MAF.
Ghost71 is offline
Old 12-31-2011, 01:01 PM   #139
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
WHOA! Definitely not without the top airbox cover! Has anyone else found the instruction or explaination confusing? Should I add a "completed" photo maybe? The photo will just look like everyone else's engine bay though. ...Which is really the point of having a clean mod done right.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 12-31-2011, 01:22 PM   #140
Ghost71
Ghost71's Avatar
Fan#: 91701
Okay. I didn't see any pics with the airbox cover. All good:-)
Great mod tho
Ghost71 is offline
