Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Ti-VCT Performance (2012-2013)
DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
Old 08-05-2011, 06:12 PM   #1
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 4 newmission Good Standing Member
2012 Focus Custom Ram Air How-To
I've always been the type to have pride in the fact that I do my own work. And with that sometimes comes a better product. I knew I wanted an intake on my new Focus. I wanted a K&N filter. And I wanted it to be functional without being too "ricey", or have too much over-powering intake noise. So this is what I have been dreaming about the last few months.
Start by jumping on the net, or head to your local auto parts store, and order Gates part #22274. What you get is a 3" inside diameter, right angle heater hose. With very little trimming, it becomes the perfect fit! It runs about $37. I found mine for $23 on Amazon shipped!
While you're waiting for that to come in. Remove your airbox, along with the resonator you'll find under it bolted to the frame. I find it easiest to keep the MAF sensor attached to the box, and remove the hose clamp and wire harness to the MAF sensor.
Remove the front air dam plate by pushing it out back towards the engine bay. You can take your time to push each snap out of the way. Or just use a little extra force and it pops right out. I found this best. :)
I laid out a line across the center of each opening, and spaced out each hole I wanted to drill. Then over to drill the holes.
Finished. Of course you can drill your holes any way you like. I was going for a clean, not too obvious look while maintaining good airflow.
This is the area you want to run the hose through. It's a tight squeeze, so it will take some suggesting.
Should look like this once it's in place. Note, at this time the hose is uncut. What a nice fit eh! :)
Here's one of what she looks like from the top. (uncut)
From the first hose picture you'll notice it runs on a bit of an angle to the right. Measure back 2 inches, and cut a notch to act as a scoop. I used just a simple straight razor blade.
Here's a fun part. Remember that factory airbox we removed? Yeah well to buy one new it runs about $130. But that's ok, cause in a couple years people will be throwing them away when they buy their CAI. So you'll be able to pick on up down the road if you want to go back. But today we're going to drill a 3 1/2" hole in it! :) Get out your 3 1/2" hole saw, and cut a hole as close to the old resonator hole as possible. Always clean up your cut edges too! :)
Now put the box back in, and fully seat it in place. You want to adjust the hose so it feels relaxed. Then mark a line around the hose about a 1/4" from the bottom of the box. Remove the box, and cut the marked line.
After the hose is all cut. Reinstall your freshly drilled air dam plate, and then reinstall the hose. It may take a couple times of replacing the airbox to get the hose in the relaxed state again so you can make your bracket. I used 3/4" by 1/8" aluminum bar I get from the hardware store. While you're at the hardware store, pick up a nice stainless steel 3" hose clamp! My clamp looked like this when I was done. Depending on how you drilled your 3 1/2" hole in your airbox, yours may look different. You're going to use the hole that the resonator was using.
Now bolt your bracket in place, and install your hose clamp. BEAUTIFUL! Nice work! You're almost done!
Put your airbox back in, and adjust your hose to fit snugly in place.
Put your air filter back in, and bolt the air box cover back on. I chose to use a Outerwears pre-filter with this setup to prevent any water from getting in the engine. It also keeps bugs out of your pleats. Start her up and enjoy! Maybe roll her out on the driveway and give her a wash, cause you know you're going to want to go for a drive. :)
A little custom vinyl work to show off the Griffin Ram Air mod. :)
Now I know everyone is going to ask HOW DOES IT SOUND?!?!?! CLEAN! Not ricey at all! Not even as aggressive as a regular CAI. It has a very mellow throaty growl to it at WOT. However, which I like, it doesn't over power the engine note with LOUD intake noise. If you like LOUD intake noise, this won't cut it. If you like to hear your engine and intake compliment each other, this is it baby!
Audio: http://youtu.be/bh2LVJJNXQg
Also, I can hear people already complaining about dirt and water, etc etc. Easy fix. Of which I don't have pictured because it is still on order in the mail. Outerwears Pre-filters! With hydrophobic water shield. Either have one custom made for your filter, or hop on eBay and pick up one for an ATV and just slap it on the top side of your hose before it enters the box. I'll post pictures when I get mine in. And what about puddles and hydro-lock and all that CAI intake worries.... You're in luck. By leaving your existing factory pipes, they will act as your vacuum bypass. Aren't you smart! All your friends are going to love you! ;)
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Fan#: 1
Old 08-05-2011, 06:25 PM   #2
brown7
brown7's Avatar
Fan#: 84107
What I Drive: 2006 DSG Zx5, 2003 DSG Mach1
FF Reputation: 1 brown7 Good Standing Member
People always ask "how does water not get in your engine?"
Well it just doesn't :)
So if I don't have a problem with water running down my shaker, I'm sure you won't have an issue of water traveling uphill in yours. Looks good
brown7 is offline
Old 08-05-2011, 07:45 PM   #3
wildweed
Fan#: 87890
What I Drive: 2012 frosted glass metallic SE
FF Reputation: 1 wildweed Good Standing Member
Looks good. I may have to try that myself. Thanks for the post !
wildweed is offline
Old 08-05-2011, 08:11 PM   #4
Albarry
Sonic Crew #016
Albarry's Avatar
Fan#: 87877
What I Drive: 2012 Sport completely stock, DCT
FF Reputation: 6 Albarry Good Standing Member
Great post man looks awesome. good job.
Albarry is offline
Old 08-05-2011, 09:58 PM   #5
Titanium12
Titanium12's Avatar
Fan#: 86295
What I Drive: 2012 Sterling Gray Titanium
FF Reputation: 1 Titanium12 Good Standing Member
That is some great work! Thanks for sharing!
2012 Sterling Gray/Titanium/Sport Handling Pkg/NAV/Winter Pkg/Rapid Spec/Remote Start/K&N
Order Date: May 23, 2011
Born Date: June 20, 2011
Delivery Date: June 29, 2011
Titanium12 is offline
Old 08-06-2011, 12:39 AM   #6
Rod Knock
Fan#: 88184
What I Drive: 2009 WRX
FF Reputation: 1 Rod Knock Good Standing Member
Is it a factory cone air filter on these?
If not, then I'm failing to see how a drop in air filter will do any good after the mod.
2012 Ford Focus Titanium 400a Package 5 door
Sterling grey metallic, 17" Polished Alloy Wheels
Tentative build date: 8/22
Tentative deliver date: 9/5
Rod Knock is offline
Old 08-06-2011, 03:46 AM   #7
cuke2u
cuke2u's Avatar
Fan#: 87358
What I Drive: It's in my sig..
FF Reputation: 2 cuke2u Good Standing Member
Hi, I dunno but to me it is alot of work for little gain, maybe some more noise, and a invalid engine warrenty. However if you like it then fine, beauty as they say...
Chris
Mk3 Focus Titanium X, 1.6 Ecoboost 150ps + Bluefin Remap
Candy Red
Appearance Pack
18" 5 Spoke Alloy Wheels
Manual 6-speed gearbox,,,
cuke2u is offline
Old 08-06-2011, 05:30 AM   #8
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
FF Reputation: 4 Tony407 Good Standing Member
Pretty snazzy!!!
Tony
Tony407 is offline
Old 08-06-2011, 09:07 AM   #9
newmission
newmission's Avatar
Fan#: 84688
Thanks y'all!
Chris
How does the SVT box and snorkel add any gains? This is a typical Ram Air set up. I don't have a way to test air flow. But with any CAI you're still SUCKING through that long tube. I don't see better gains with those things other than a temperature drop. Here you get both. But hey. It is what it is! I'm not here to argue. :)
However I was wondering about factory warranty, and how far one can go before it's void. Doesn't one void warranty with a CAI?
Hatch Nation #110
Get you some!
Old 08-06-2011, 11:15 AM   #10
cuke2u
cuke2u's Avatar
Fan#: 87358
Originally Posted by newmission View Post
Thanks y'all!
Hi, apologies but I think we are both saying the same, I was using the usual english politeness in regards to any gains. In reality there might be losses.
Chris
Candy Red
Appearance Pack
cuke2u is offline
