Changing battery in Titanium key fob? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-27-2012, 10:48 PM   #11
abstang
Fan#: 87352
What I Drive: 2012 Candy Blue Titanium Hatch
Points 114, Level 2
Points: 114, Level: 2 Points: 114, Level: 2 Points: 114, Level: 2
Level Up 28% Completed
FF Reputation: 1 abstang Good Standing Member
Originally Posted by primetime View Post
Hey guys, sorry to resurrect an old thread, but I'm wondering what you guys used to pry open the fob.
I'm trying to replace the battery on mine, but I can't seem to pry the two halves apart.
Yes I am wondering the Same thing. I started getting the low battery warning today on both key fobs. Funny that I started getting the warning on both fobs the Same Dayand just After the Dealer finished doing an oil change....
abstang is offline
Old 12-27-2012, 11:05 PM   #12
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Take out the key from the FOB (slide the lever in pic):
Then place the key like this:
There is a little beefy plastic piece, twist key. FOB back pops off.
Replace battery, snap back, back on
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 12-27-2012, 11:24 PM   #13
abstang
Fan#: 87352
Points 114, Level 2
Thanks but unfortunately my titanium key fob does Not look like that. The key just sits inside the fob. The instruction manualhas me remove the key from the fob, but then IT is unclear how to get the fob apart.
abstang is offline
Old 12-27-2012, 11:59 PM   #14
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Mine is a Ti FOB as well, from a 2013.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 12-28-2012, 12:00 AM   #15
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I just gave you a step by step to do exactly that. Remove the key. Follow steps as pictured.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 12-28-2012, 08:13 AM   #16
primetime
primetime's Avatar
Fan#: 100063
What I Drive: 2012 Silver Ford Focus Titanium
FF Reputation: 1 primetime Good Standing Member
Mine is a 2012 fob.
It's different from yours because I have to remove the faceplate then the key.
The part where I'm having problems is where I try to separate the two halves of the fob apart. The manual says to twist at a certain area of the fob and then pry the halves apart, but it doesn't seem to work.
Sent from my Nexus 7 using FF Mobile
primetime is offline
Old 12-28-2012, 10:33 AM   #17
abstang
Fan#: 87352
Points 114, Level 2
Yes, mine is the same. After removing the key, I can not figure out how to separate the 2 halves of the fob either.
abstang is offline
Old 12-28-2012, 10:36 AM   #18
abstang
Fan#: 87352
Points 114, Level 2
My fob looks very different. I do not have the slide lever, and there is no "beefy" part on the edge, or anywhere else that I can see.
abstang is offline
Old 12-28-2012, 10:39 AM   #19
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I fail. Don't know how else to help you other than to recommend you have the dealer do it and show you for next time. They break it they buy it, right?
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 12-28-2012, 11:17 AM   #20
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
You'll see two notches cut out of each side of the remote. Insert a small screwdriver into that notch gently force the blade between the two halves, & twist. The two halves snap apart, and you can replace your battery. Don't be afraid..it won't break. Mine ran through the washer and dryer before I had to take it apart & dry it out. Still works great.
cbdallas is offline
