JRSC install - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-10-2011, 10:01 PM   #51
ThatOneFocusGuy
ThatOneFocusGuy's Avatar
Fan#: 59087
What I Drive: 13 RR ST3 #5427, 00 Kona Edition
Points 10,739, Level 68
Points: 10,739, Level: 68 Points: 10,739, Level: 68 Points: 10,739, Level: 68
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 7 ThatOneFocusGuy Good Standing Member
Buy-Sell-Trade Rating: (29)
The reason for lower psi is because of a free flowing exhaust. If you had a cat your psi would increase. Stock pulley should make 5 psi.
FocusFactor FocusXtreme
ST Nation Cincy Area
IG @battle_stance_st
ThatOneFocusGuy is offline
Old 10-10-2011, 10:24 PM   #52
xy0s08
xy0s08's Avatar
Fan#: 65298
What I Drive: 00 ZX3 Kona, 00 ZX3, 04 SVTF
Points 4,386, Level 42
Points: 4,386, Level: 42 Points: 4,386, Level: 42 Points: 4,386, Level: 42
Level Up 18% Completed
FF Reputation: 7 xy0s08 Good Standing Member
so i am switching to an SVT header will that increase the boost?
MARCH ROTM 2010 Midwest crew #58
9/11 was an inside job! fluoride is poisoning all of you! The Federal Reserve is a private bank that is making fake money and bankrupting America! Open your eyes to what is going on in the US! Infowars.com
xy0s08 is offline
Old 10-10-2011, 10:37 PM   #53
ThatOneFocusGuy
Fan#: 59087
If used with a stock cat it would. Not sure if it would increase with an orp.
Old 10-11-2011, 08:28 AM   #54
xy0s08
xy0s08's Avatar
Fan#: 65298
I am going with an orp so we shall see
xy0s08 is offline
Old 10-11-2011, 10:26 AM   #55
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,797, Level 100
Points: 51,797, Level: 100 Points: 51,797, Level: 100 Points: 51,797, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
I dont know if I agree with that , the stock jrse I though I have had many with 5-6 psi and no cat and better exh
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 10-11-2011, 10:34 AM   #56
xy0s08
xy0s08's Avatar
Fan#: 65298
It makes sense to me that out would flow better without the cat but I don't know maybe its eliminating all of the back pressure, but even then it doesn't make sense why it would drop the boost
xy0s08 is offline
Old 12-13-2011, 08:25 PM   #57
xy0s08
xy0s08's Avatar
Fan#: 65298
okay so i think things are getting better, but at the same time i am not sure about that. i cannot get more then 3 psi of boost, at idle there is only 17 InHg, the belt i have installed is the same one that everyone on here has recomended yet i still think belt slip is why i am not getting full boost, yet the next smaller belt will not fit (hits the side of the tenshioner), today when i dove it it had a weird idle issue, no low end power. I dont know what to do about this SuperCharger problem, i think it might be a bad SC but i dont know, any help will help!!!
xy0s08 is offline
Old 12-15-2011, 12:19 PM   #58
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 919, Level 16
Points: 919, Level: 16 Points: 919, Level: 16 Points: 919, Level: 16
Level Up 19% Completed
FF Reputation: 3 forddorf Good Standing Member
When you bought your manifold studs where they threaded all the way (some come with no threads in the middle of the stud)? Did you check your manifold studs for tightness? What kind of manifold gasket did you use and how thick was it? Does the super charger feel strong at times and then down on power other times or does always seem under powered?
forddorf is offline
Old 12-15-2011, 05:02 PM   #59
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
check your bypass valve. might not be any good.
BigRed03 is offline
Old 12-15-2011, 08:24 PM   #60
xy0s08
xy0s08's Avatar
Fan#: 65298
the studs were not threaded all the way. i did check them for tightness i also sprayed card cleaner all the way around the mating surface checking for a vacuum leak. (didnt find one) I made a gasket out of gasket material. it always seems under powered as when i go WOT i can only get 3 psi of boost and then when i shift gears it doesnt seem like i have any bottom end power. I checked the bypass valve with a vacuum pump and it was opening so i think it is good but i dont know.
xy0s08 is offline
